2012 door mirrors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boomer6, Jan 29, 2012.
  1. Jan 29, 2012 at 1:17 AM
    boomer6
    boomer6 [OP] Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    I have searched but havent found an anwser. Does anyone know if the 2012 sport mirrors that have the turn signal in them would be a direct bolt on for a 2011 tacoma?I know you would have to wire it in. Need to know if the complete mirror and housing would be interchangeable with the 2011.
  2. Jan 29, 2012 at 1:19 AM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
  3. Jan 29, 2012 at 7:54 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    The mirror should fit on the 2011. You would have the to wire the mirror signal into your other signal lights. I'm sure that it shouldn't be that hard to do.
