2012 double cab long bed is bouncing in rear
Discussion in 'Suspension' started by Yapsterdoo, Dec 16, 2011.
  1. Dec 16, 2011 at 9:09 PM
    Yapsterdoo
    Yapsterdoo [OP] New Member
    SR5 Long Bef
    Just purchased. Love the smooth ride up front but when unloaded the truck has excessive bouncing and sways side to side on rough roads in New England. Any suggestions on how to fix this? When I test drove the TRD it was too stiff upfront. If I install new shocks will it fix this? I want to match the feel up front in the back.
  2. Dec 16, 2011 at 9:12 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    how many leaf's in your rear spring set ? The rear spring leafs are stiff and the only way to help that would be to replace the rear with a larger leaf pack that has more than like "2" leafes in it
  3. Dec 17, 2011 at 3:31 PM
    Yapsterdoo
    SR5 Long Bef
    I checked and it has 3 leafs the same length along with a shorter leaf. Wount stiffer shocks help. O can go to back of truck and it's easy to push on bed and make it compress
