2012 drivers side brake and wheel bearing issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rtcxi, Jul 27, 2017.
  1. Jul 27, 2017 at 9:46 AM
    Rtcxi
    Rtcxi [OP] New Member
    2012 tacoma 4x4
    Hi all,
    Last night I had to get a tow home because my drivers side wheel bearing is shot and my brakes began stuttering then my ABS light and traction control light came on.
    I replaced my drivers side rotor and pads but there's still no brakes. Peda to the floor and it's still sloppy and won't engage. While I'm working on my brakes and replacing the drivers side wheel bearing I want to replace the caliper too if need be. Any recommendations or advice on the lack of brakes still and whether should replace my caliper too would be appreciated.
  2. Jul 27, 2017 at 9:55 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    How many miles on truck?
  3. Jul 27, 2017 at 9:55 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    worn bearing will make the caliper open up and cause pedal to be low
    mbmack1 likes this.
  4. Jul 27, 2017 at 10:32 AM
    Rtcxi
    2012 tacoma 4x4
    It has 174,000 miles are on it
  5. Jul 27, 2017 at 10:40 AM
    mbmack1
    mbmack1 That F'n guy
    matt
    az
    SAVAGE silver '06
    This^^^
    I had the same thing happening when my wheel bearing was shot. I replaced both wheel hubs and everything is fine now.
    Mully likes this.
  6. Jul 27, 2017 at 12:50 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What does that even mean, " Caliper Open Up "?
    Makes no sense to me.
  7. Jul 27, 2017 at 12:55 PM
    Mully
    CA
    Worn bearing causes the rotor to pitch at an angle, pushing the brakes into the caliper, thus they are no longer flat against the rotor. There is nothing wrong with your caliper. Replace wheel bearings and then test drive it. Also post a pic of your truck. Thanks.
    mbmack1 likes this.
  8. Jul 28, 2017 at 4:19 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    OK. The angle of the rotor presses the pistons back into the caliper housing.
    Mully likes this.
