2012 Fog Lights Solution!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CherryBomb, Feb 16, 2012.
  1. Feb 16, 2012 at 6:10 AM
    CherryBomb
    CherryBomb [OP] Member
    New Hampshire
    2012 DC 4x4
    My first time post. A humble attempt to pay everyone back for the great info I have got from this board.
    After a lot of research I've found a cost effective way to add fog lights to my new 2012 Tacoma. As we know the lights are different from earlier years and there is no factory fog light kit available. After some time snooping the dealership's computer I found the part numbers for the lamps, relay and switch. My truck has the fog light wiring harness installed. I suspect all 2012s have the wiring harness. I noticed the fog light connectors bundled up and zip tied underneath the headlights.
    After cross checking the part numbers I found that the 2012 Tacoma fog lights are the same part number as the fog lights for 2011+ Siennas and 2008-2011+ Avalons (maybe more).
    On ebay you can find OEM Style 2011 Sienna Fog Light Kits for about 115 bucks. (pictured below) You will have to discard the wedge shaped plastic trim piece that is exclusively for the Sienna. The lamp itself is exactly what you need for an OEM fit. Add the Tacoma specific relay and switch assembly and you have an OEM style 2012 Tacoma fog light kit for under 250 bucks. (Im not sure if the relay and switch included with the kit will work for the Tacoma).
    Your other option is to buy the individual parts from the dealer. Its expensive, but not too bad. I'll post the Toyota part numbers and prices below for everyones convenience.
    81210-08020 RH Lamp Assy $185.44
    81220-08020 LH Lamp Assy $185.44
    90080-87026 Relay $73.73
    84160-04020 Switch Assy $54.45
    Grand total from Dealer 499.06
    Grand total using my method roughly 250.00
    You might be able to find a less expensive, after market relay. Im just using dealer pricing.
    BTW, I purchased the Blinglights kit that was supposed to be specific to the 2012. Its not at all. Lens size isnt perfect. Mounting bracket wont work and the switch looks like something suitable for a go-kart. I don't recommend it.
    I haven't installed this kit yet but I will post pics once I get them installed. Judging by the part numbers, it should work flawlessly.
  2. Feb 16, 2012 at 6:53 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Nice find! :thumbsup:
    FWIW, you can use any automotive relay to make this work. They're available cheap at any auto parts store, the only thing that changes is the wiring.
  3. Feb 18, 2012 at 12:09 PM
    gioangn
    gioangn Member
    Did you use OEM relay and switch? I would like to install the fog lights to my 2012 Tacoma. Please elaborate on how to hook up the relay. I thought the relay was included in the prewired cuircuit. This is my last upgrading. So far I added the backup camera, variable windshield wiper, cruise control, power side mirrors, alarm for keyless entry. All are working fine. Without this forum it's impossible for me to do all the upgradings myself. Thanks.
  4. Feb 18, 2012 at 4:27 PM
    CherryBomb
    New Hampshire
    2012 DC 4x4
    I plan to use an OEM relay and switch. The kit for the Sienna has an OEM switch and relay but Im not sure if they are gonna fit the Tacoma. Worst case I go to the dealer and buy the relay and switch. I'll post pics as soon as the kit gets here and I have time to instal it.
  5. Feb 25, 2012 at 4:05 PM
    myersct99
    myersct99 New Member
    Warner Robins, Ga
    Has anyone done this yet?
  6. Feb 25, 2012 at 9:24 PM
    trooper12
    trooper12 Well-Known Member
    Spencer
    Trabuco Canyon, CA
    2012 SR5 PreRunner
    maxtrac 4" lift spindles, wheelers 1.5" 3 leaf pack. nothin special...
  7. Feb 26, 2012 at 6:00 PM
    holokai
    holokai Well-Known Member
    Honolulu
    '12 PreRunner SR5 Access Cab
    Installed: OEM Bed Mat, Secondary Air Filter Delete/AFE/stock CAI elbow mod, LEDs ( Rear License Plate, Map, and Dome Lights), Ceramic Tint (Front 35%, Rear 27ish%), Viper Security, Image Dynamics Front Components, 4 channel Arc Audio Amp (rear channels bridged for sub), Kicker CVT 6.5 (yes, it's a tiny sub but it's enough to keep me happy), Headunit (Bluetooth and iPod/Pandora), EGR Window Visors, OEM Door Sill Protectors, Roll-N-Lock, Wet Okoles, Fog Lights with 2500k bulbs, UltraGauge EM, Spidertrax spacers, Smittybilt Side Steps, Tooter 2.7 Intake Manifold Spacer Upcoming: LCE Headers?
    Please let us know when you get them installed. Looks like a bunch of people have bought kits but haven't had the chance to install them yet. Would really like to see how they look. Great find!
  8. Feb 27, 2012 at 6:07 AM
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    do let us know how it went and remember, we like pictures!
  9. Feb 27, 2012 at 7:36 AM
    TNDrew
    TNDrew Well-Known Member
    Drew
    Chattanooga, TN
    '12 Reg Cab 4x4 Silver
    WeatherTech DigitalFit Liners, Bench Seat Angle Fixed, Fog Lights (Nokya 2500k HyperYellow bulbs), aFe ProDry drop in, DeeZee bed mat, UWS black low pro tool box, Marathon Seat Covers (ordered should arrive mid-May). iSimple iPod adapter, Blacked out badges, SockMonkey WhiteTail Toyota Horns decal, LED Dome and License Plate Lights (LEDSolutions), Black Headlight Mod,
    Sub'ed
  10. Feb 27, 2012 at 12:25 PM
    gioangn
    gioangn Member
    Finally I installed the fog light to my 2012 Taco Extended Cab. Thanks to CherryBomb for the huge finding of the fog light which will fit the 2012 model. I bought the kit as he recommended:
    http://www.ebay.com/itm/110776299399?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649.The relay: http://www.ebay.com/itm/180771078124?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 and the switch:
    http://www.ebay.com/itm/Toyota-Tacoma-Fog-Light-Switch-w-o-Harness-/310381448888?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item48442d0eb8
    The installation was pretty straight forward. It took me about 45 minutes. The truck was prewired for fog lights. Just remove the fog light covers and replace them with the fog lights, use the same screws. The lights will fit both sides.If the letters imprinted in the front of the lights are upright, you’re good to go. There is about 1/8 inch gap between the light and its housing, I'm not sure this is normal or not; but looks nice and sturdy. Here are some pics:
    BayRanger likes this.
  11. Feb 27, 2012 at 8:12 PM
    trooper12
    Spencer
    Trabuco Canyon, CA
    2012 SR5 PreRunner
    ^^ :rolleyes:
    those look really good!!
    can't wait to install mine, should be here in a day or two.
    i will be sure to take pics
  12. Feb 28, 2012 at 4:01 AM
    holokai
    Honolulu
    Looks great. Did you by chance try using the switch and relay (looks like one in the picture) that came with the kit? I'm thinking if the switch fits the factory location fine I can save $40 :p Thanks again for posting pics!
  13. Feb 28, 2012 at 6:55 AM
    gioangn
    gioangn Member
    No, switch and relay from the kit won't fit. You can get OEM from Ebay just a fraction of the cost of dealer.
  14. Feb 28, 2012 at 7:35 AM
    WheelinJ91
    WheelinJ91 Well-Known Member
    Edmonton,AB
    2012 TRD DCSB
    Airaid Intake, MBRP Exhaust, Toytec OME 3" lift w/AAL, Flip-kit, LR UCA's, Weathertech Floor mats, hood and window deflectors.
    Wait what? no fog lights? my 12'TRD DCSB came with fog lights.
  15. Feb 28, 2012 at 7:52 AM
    OzarkMK
    OzarkMK Active Member
    Springfield Missouri
    Grey Access Cab. Currently Unmodified
    post some pics when you install them
  16. Feb 28, 2012 at 8:47 AM
    Papa Tac
    Papa Tac Adjunct Anarchist
    Papa Tac
    Codroy Valley, Newfoundland
    '10 Ned Ludd Edition
    Pupped my ride - Dog bench, Black stock rims, Tail Gate antitheft mod, Bed storage and sleeping platform, Action Cap w/Yakima rack and Rola basket, Seatbelt chime off, Tentasaurus
    Well done, OP!
    Should be added to the 2nd Gen Mods Sticky!
  17. Feb 29, 2012 at 8:32 PM
    trooper12
    Spencer
    Trabuco Canyon, CA
    2012 SR5 PreRunner
  18. Feb 29, 2012 at 8:37 PM
    Royce99
    Royce99 Taco Samurai
    Royce
    Houston
    2012 MGM Prerunner SR5 Debadged
    Just getting started.
    Mine did too...I thought they all did.:confused:
  19. Mar 1, 2012 at 7:40 AM
    holokai
    Honolulu
    All 2.7L models and the base V6 models don't have them.
  20. Mar 1, 2012 at 7:56 PM
    gioangn
    gioangn Member
    trooper12, job well done !! To change the title of your thread: go to your thread then use EDIT.
