2012 Fog Lights Solution!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CherryBomb, Feb 16, 2012.
  1. Aug 10, 2012 at 9:53 PM
    #101
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    You'll still need to run a relay.
    The low beams are on a circuit that was designed to drive the low beams.
    Adding the fogs is doubling that current draw and could blow the fuse or overheat the wiring.
    Use the low beams to trigger the relay, use the relay to power the fogs off of their own fuse.
  2. Aug 11, 2012 at 8:01 AM
    #102
    Spruce Juice
    Spruce Juice Well-Known Member
    Sam
    Vancouver, BC
    2012 4 x 4
    Fold A Cover, Factory Class 4 Hitch with Factory Harness, Cruise, Int Wipers, TRD Alloys, Fogs, K&N Air Filter
    Okay so my RC 4 cyl is not prewired for fogs. I can buy the lamp housings in the form of an aftermarket kit, factory relay and switch. What about the wiring harness? Will I be able to use any part of the harness from the kit? Do I have to wire in the rest or is there a factory harness I can buy?
  3. Aug 11, 2012 at 8:08 AM
    #103
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    spruce i dont think your going to be able to take that route, factory system is dependent on headlamps being on ect... its pretty extensive. i would buy the Camry lights listed for $50, fit those in, then wire the fogs in 'from the ground up'. def very straight forward. you'll just need to use a relay, and power taps. use the harness that comes with the Camry fogs so you can use the factory wire plugs on the fog lights, also has a relay in the kit. but their harness will not be long enough.
    you may be able to use the factory switch if you can find the plug and pigtail for it to tie into...
  4. Aug 11, 2012 at 9:49 AM
    #104
    DBurns
    DBurns Well-Known Member
    Texas
    2012 PreRunner SR5 Double Cab 4cyl
    Yea, I know
  5. Aug 11, 2012 at 10:22 AM
    #105
    Rich91710
    Rich
    Los Angeles
    08 Base
    The only part of the supplied harness that I will be using is the part that runs from the lights to where it was supposed to connect to the harness and tie into the relay.
    The rest of the supplied harness was too short to evenmake it from the radiator support to the firewall, much less the dash, it doesn't use a "standard" relay, and I couldn't even get the thing to plug into the supplied switch (which wouldn't fit the dash cutout anyways).
    Run the battery-to-relay-to lights on 14ga wire using a 15a fuse... that'll cover a pair of standard 55w lamps.
    The add-a-circuit-to-switch-to-relay can be on 18ga wire, and a 3-5a fuse is more than adequate for that. You can use 14ga for everything if you'd like, the smaller fuse won't hurt it.
  6. Aug 11, 2012 at 10:24 AM
    #106
    Rich91710
    Rich
    Los Angeles
    08 Base
    I sent him a link to the FJ Cruiser factory switch and pigtail for $77
    This is a 6-pin switch that has the dash illumination light like the Taco switch, but it also has an amber indicator light.
    http://www.toyotatrdparts.com/scripts/prodView.asp?idproduct=-59
    The 3a fuse is fed from only one source... either a fuse panel or a switched source. I prefer a switched source, if you go hit 24/7, it's only a matter of time before you forget and kill your battery.
    Also, the "from interior light circuit" is optional.
    I never use my dash dimmer, so my installation plan is to use the low beams for the switched power source, and I'll simply "T" pin 6 to pin 3.
  7. Aug 11, 2012 at 11:57 PM
    #107
    DBurns
    Texas
    Ok, I'm getting ready to get things together to do this. I understand all the wiring and stuff pretty good. This may be a stupid question, but what's the best way to get wires from the engine area to the cab? I see the big bundle of wires on top behind the dash but it's wrapped pretty tight. Never had to do this before...
  8. Aug 12, 2012 at 12:19 AM
    #108
    Rich91710
    Rich
    Los Angeles
    08 Base
    Locate one of the rubber grommets where the stock harness passes through.
    Use a soda straw with the end cut at an angle, work through the grommet to create a pathway through and run the wires through that opening.
    A dab of silicone sealer on the underhood side would be a good idea to make sure the cab stays dry.
  9. Aug 12, 2012 at 9:21 AM
    #109
    CDNTACO
    CDNTACO Well-Known Member
    Wayne
    Ottawa Ontario Canada
    2012 DCLB-SR5
    Fog Lights, Pop&Lock Electric, G4 Elite Tonneau Cover, Weathertech Bug Shield and Window Deflectors, Smitty Built Nerf Bars and Bull Bar, WeatherTech MudFlaps, ProEFX Tow Mirrors
    Sorry to hear that. I had to fart around with them a bit but they did slide in no problems for me.
  10. Aug 12, 2012 at 10:41 AM
    #110
    DBurns
    Texas
    Never thought of that, thanks!
  11. Aug 12, 2012 at 12:02 PM
    #111
    larrybbaker
    larrybbaker Well-Known Member
    larry
    South Central PA
    2013 MGM DCLB TRD SPORT 4WD
    OME 885 | Bilstein 5100 x 4 | WeatherTech Window Visors | VAIS Tech SiriusXM Adapter |Alpine KTP-445U Amp | Anytime fog light mod
    Mine did NOT have pre-wiring to the fog lights mounts - dealer had to take care of that with the kit. As stated in my other post, the part number (Fog Light Kit) they listed on the work order was tta-312)
    ALSO - the kit they installed placed the SWITCH into the center console blanks, not the left of steering wheel blanks.
    Installed pics are in my gallery or other thread.
  12. Aug 12, 2012 at 12:21 PM
    #112
    Rich91710
    Rich
    Los Angeles
    08 Base
    Couldn't find your posts in the other thread, and not much to see in your gallery other than a SWEET looking new truck....
    It looks like the dealer used the Scion style fog switch. Is that a pushbutton or a rocker type?
  13. Aug 12, 2012 at 12:29 PM
    #113
    larrybbaker
    larry
    South Central PA
    Ha! Thanks, love it. Almost 2 months old now, fogs, wheels and radio installs done. Probably add tint and a bed cover intense near future.
    The switch is a push button, glows green when on, wired "legal" to be on only with low beams.
    Dealer insisted on the install so it is covered by warranty.
  14. Aug 12, 2012 at 4:01 PM
    #114
    MBTacoma12
    MBTacoma12 Well-Known Member
    12 Prerunner DC
    Installed Fogs today the switch that came with it was not Toyota Tacoma , but I used it and installed it next to AUX. looks and works great.
  15. Aug 13, 2012 at 7:25 AM
    #115
    PAKraig
    PAKraig Well-Known Member
    Kraig
    Central Pennsylvania
    2017 DCSB 4x4 in Silver Sky
    OME suspension and 285/70R17 BFG KO2s
    Any reason these halos for a 2008 Camry wouldn't work?
    Amazon Halos
  16. Aug 13, 2012 at 8:17 AM
    #116
    DBurns
    Texas
    Looks like the lens on those is molded different. Can't really tell by the pic tho.
  17. Aug 14, 2012 at 6:01 PM
    #117
    MBTacoma12
    12 Prerunner DC
    Looks different won't be worth a risk
  18. Aug 27, 2012 at 8:35 AM
    #118
    mccarroll
    mccarroll Well-Known Member
    Newfoundland, Canada
    2012 DC 4X4
    Do they light up the road well? I did the same with the camry lights but mine had to be trimmed. I don't think they throw light in the right place.
  19. Aug 27, 2012 at 8:53 AM
    #119
    B737
    Kevin
    Jersey Shore
    stock
    Where did you trim?
    I've tested them twice, i only use my fogs, in fog or snow ... And there hasn't been any, when I did test them it was clear out it was good illumination down low, filling in the dark spot left by the headlamps BUT I did notice some illumination up higher, when I noticed it passing the overpass I figured my next step will be to take a closer look in rain and pull the truck up to the garage door and see where they're hitting. Overall, it didn't strike me as anything out of the ordinary for stock lamps.
    A note to those doing this w their 2012s... The switch cited in this thread is backlit amber, doesn't match 2012 lighting at night. I ordered 2012 part number from parts.com to see if it's a match.
  20. Aug 27, 2012 at 9:23 AM
    #120
    mccarroll
    2012 DC 4X4
    I had to trim the plastic tabs opposite to the screw locations. That is the only way they would sorta fit. They look good from a distance, but up close I have a half inch gap all way around.
