2012 Fog Lights Solution!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CherryBomb, Feb 16, 2012.
  1. Aug 27, 2012 at 9:36 AM
    #121
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    whoa thats a big gap. mine are no further than an 1/8th, its even all around
  2. Aug 27, 2012 at 10:57 AM
    #122
    PAKraig
    PAKraig Well-Known Member
    Kraig
    Central Pennsylvania
    2017 DCSB 4x4 in Silver Sky
    OME suspension and 285/70R17 BFG KO2s
    I'm in this boat too. I need to do some adjusting on mine but I don't think they're quite as effective as they maybe should be as a fog light.
    B737, what part number did you order and did it come from Ebay or Amazon?
    For reference, this is the Ebay part number I used FOG-TOCA07-CL. The Ebay vendor was out of stock so I Googled the part number and ordered from a different vendor. I trimmed the tabs like in Trooper's thread and even dremeled out the screw holes a bit. They're in, but there is a fair gap between the bumper cover and the light. I'll try to remember to get pics this evening after work.
    Thanks.
  3. Aug 27, 2012 at 4:49 PM
    #123
    B737
    Kevin
    Jersey Shore
    stock
    YES
    please stop Rod, im going to be eating Ramen noodles soon :)
    7-09 Camry fog lights $49 from ebay
    are the ones i used. they fit, but there is about a 1/8th even gap all around the lamp. doesnt bother me as it looks and seems to function just fine. that said, im all in for a real 2012 pair :)
  4. Aug 27, 2012 at 4:51 PM
    #124
    B737
    Kevin
    Jersey Shore
    stock
    PM when you have them Rod i'll send the cash.
  5. Aug 29, 2012 at 12:06 PM
    #125
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    This is a damn good thread on installing fog lights. Very informative and detailed! Thanks everyone that has added info, tip's, etc. on this mod.
  6. Aug 29, 2012 at 2:09 PM
    #126
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Way to sleuth it out!
  7. Aug 30, 2012 at 5:29 AM
    #127
    PAKraig
    Kraig
    Well, got my lights (FOG-TOCA07-CL) aimed apropriately now and they seem to work really well. Definitely not overly pleased by having to trim them, but they do fit.
    All in all I got the lights for $47.99, Duralast relay from Autozone for $23.78 (Part # 20382) and the switch from my dealership for $58.00.
    Less than $130 for fog lights is a steal!
    I'll get pictures up here one of these days.
    Thanks for all the info everyone!
  8. Sep 6, 2012 at 1:43 PM
    #128
    B737
    Kevin
    Jersey Shore
    stock
    i'll go back and edit my posts...
    ATTENTION 2012-2013
    the fog light switch mentioned in this thread has amber back lighting, appropriate for pre 2012 trucks. the switch you need to match the green back lighting of 2012+ is fog light switch 84160-04020
    parts.com for about $45.00
  9. Sep 15, 2012 at 6:14 PM
    #129
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
  10. Sep 17, 2012 at 4:55 PM
    #130
    Spruce Juice
    Spruce Juice Well-Known Member
    Sam
    Vancouver, BC
    2012 4 x 4
    Fold A Cover, Factory Class 4 Hitch with Factory Harness, Cruise, Int Wipers, TRD Alloys, Fogs, K&N Air Filter
  11. Sep 17, 2012 at 7:57 PM
    #131
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    If your truck is not prewired, nothing is plug and play.
    If it is prewired, there's a possibility but you will need additional parts.
  12. Sep 19, 2012 at 2:00 AM
    #132
    5150Bronco
    5150Bronco Well-Known Member
    Bay Area, Ca.
    2013 Tacoma 4x4 Access Cab-Special Order.
    Great Thread. Spent lots of time reading and taking notes.
    I just got 2013 Taco, 4 cyl, 4x4 and want to install fog lights.
    What is the verdict on the oem lights above? Anybody?
    I might have to give them a shot.
    Thanks everybody. Gathering my parts list and will be ordering soon.
  13. Sep 20, 2012 at 6:45 AM
    #133
    Silvertaco19
    Silvertaco19 Member
    pa
    2012 Tacoma 4x2
    X-runner wheels, 15% lumar tint
    I have 2.7l 4 cylnder access cab sr5. Looking at this thread most likely my truck is not prewired. I will check fuse box under hood. So if i buy a relay, switch, oem fogs, where can i get a wire harness for cheap? Ideally plug and play would be.great but the more i read seems unlikely. Seems you can get oem sienna fogs for 150. Thats for the whole kit.
  14. Sep 20, 2012 at 6:46 AM
    #134
    Silvertaco19
    Silvertaco19 Member
    pa
    2012 Tacoma 4x2
    Can anyone verify if a 2.7l ac sr5 is not prewired?
  15. Sep 20, 2012 at 7:05 PM
    #135
    Rich91710
    Rich
    Los Angeles
    08 Base
    If you are not prewired, there is no plug & play option.
    On '05-'11, many AC and DC SR5 were prewired.
  16. Oct 9, 2012 at 8:00 AM
    #136
    zhntr
    zhntr Member
    2012 2.7l 4cy, 4x4, sr5 access cab was not pre-wired.
    Bought this kit from eBay: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170881171730
    The 2012 Toyota fog light switch (part nbr 84160-04020 at parts.com - the switch is not "yet" wired).
    Follow the instructions here works perfectly: http://www.tacomaworld.com/forum/2nd-gen-tacomas/207318-2012-tacoma-headlight-install.html
  17. Oct 21, 2012 at 6:41 PM
    #137
    CLynch
    CLynch Well-Known Member
    Charlie
    Upstate New York
    None
    I have read a ton of threads in lighting. I saw it once but can not find it. How do you know if you if your taco is pre wired? Thanks for the advice.
    2012 access cab
  18. Oct 21, 2012 at 6:50 PM
    #138
    Rich91710
    Rich
    Los Angeles
    08 Base
    Look under the bumper for the connectors.
    They'll be taped up to the harness.
    Open the underhood fuse box, read the graphic to identify which socket gets the fog relay. Look down into the socket and see if the slots in the plastic are empty, or have contacts in them.
    Finally, pull the dash apart and locate a 4-wire connector.
    If you have the first two, you likely have the 3rd and all you need is the lights, relay, switch, and a fuse.
  19. Oct 21, 2012 at 6:59 PM
    #139
    B737
    Kevin
    Jersey Shore
    stock
    is your truck a v6 or the 4? if its the 6 i can almost guarantee your prewired. same truck as mine. i got the Camry lights and relay on ebay ($55), and the OE toyota switch ($50) (dealer or parts.com)
  20. Oct 21, 2012 at 8:14 PM
    #140
    CLynch
    Charlie
    Upstate New York
    None
    Thanks guys and TW
