2012 Fog Lights Solution!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CherryBomb, Feb 16, 2012.
  1. Oct 24, 2012 at 9:02 AM
    #141
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    Included with SR5 package?
  2. Oct 24, 2012 at 7:44 PM
    #142
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Often.
    Not always.
    I don't think any of the 2.7 are pre-wired.
  3. Feb 13, 2013 at 6:57 PM
    #143
    Armcphail
    Armcphail Member
    Aaron
    Chatham,Ontario
    4 cyl sr5
    Need some help! Dealership has told me over the phone they are almost certain the 2013 Tacoma 4cyl 4x4 is pre wired for fog lamps. So I bought a set of fog lamps, ordered the relay, and ordered a very expensive switch from the dealership.
    My problem is, I cannot find the wiring? Trying to do it myself and stay away from the dealership.
    Can anyone help me find the wiring or a diagram of where the factory has put them?
    The picture in the tread of where the relay goes is different than mine, I do not have a small box attached to the larger box, just one box behind the battery, which appears to have a place for the relay.
  4. Feb 13, 2013 at 7:42 PM
    #144
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    Your truck isn't prewired.
  5. Feb 13, 2013 at 7:54 PM
    #145
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    I have a 2013 2.7 sr5 Access Cab. Not Pre Wired.
    No copper contacts in the relay location either.
  6. Feb 13, 2013 at 7:55 PM
    #146
    Armcphail
    Armcphail Member
    Aaron
    Chatham,Ontario
    4 cyl sr5
    Thanks, already purchased two oem fog light housings, any idea where I can get a wiring harness, relay and switch to fit in one of the blanks?
  7. Feb 13, 2013 at 8:02 PM
    #147
    Armcphail
    Armcphail Member
    Aaron
    Chatham,Ontario
    4 cyl sr5
    Looked at the under hood fuse box, nothing in the diagram about fog lights. So I guess I am out of luck. I currently have two oem fog lights mounted in my brand new tacoma access cab, with no wiring. Now what??
  8. Feb 13, 2013 at 8:55 PM
    #148
    Bmeadow1
    Bmeadow1 Active Member
    Brogan
    Concord, NC
    2013 prerunner
    Maglites, camo seats
  9. Feb 13, 2013 at 10:09 PM
    #149
    Rich91710
    Rich
    Los Angeles
    08 Base
    WOT did not like that site, and it tried to store a cookie "for checkout" that was rejected.
    Funny, because I've been shopping online for months with these settings and have never seen that warning before.
    I wouldn't trust that vendor.
  10. Feb 18, 2013 at 9:30 AM
    #150
    Armcphail
    Armcphail Member
    Aaron
    Chatham,Ontario
    4 cyl sr5
    Well its official my 2013 Taco, 4 cy, 4x4 is not prewired fog lights as the dealership stated prior to purchase, so I purchased a scion lit fog light switch, some H11 connector wires and a relay. Planning on creating a wiring harness, with an inline fuse once the items arrive, crossing my fingers.:rolleyes:
    Anyone know if my Taco would happen to be prewired for the back up camera, and if so where to buy the camera and how to getting it to work?:)
  11. Feb 18, 2013 at 11:55 AM
    #151
    Rich91710
    Rich
    Los Angeles
    08 Base
    If you aren't prewired for fogs, you are not likely prewired for the camera.
  12. Feb 18, 2013 at 5:36 PM
    #152
    Armcphail
    Armcphail Member
    Aaron
    Chatham,Ontario
    4 cyl sr5
    Thanks, it's weird on the right inside of the truck bed there is a warning sticker about removal of the tailgate could cause damage if it isn't disconnected,
  13. Feb 18, 2013 at 6:49 PM
    #153
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    I believe that the wire is on the driver side except it does not run into the tailgate. Should end by the left side of the rear bumper.
  14. Feb 19, 2013 at 5:00 AM
    #154
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    My 2013 base 4x4 4 cyl auto does not have the backup camera option- BUT there is wiring from under my rear end of truck / harness into the bottom of the tailgate via a disconnect. I do not know if the camera is the tailgate or not - but the wiring is there and must be disconnected before the tailgate can be removed.
    Remember - Be sure to put a pipe clamp and or lock on your tailgate to prevent theft !!!
  15. Feb 19, 2013 at 8:16 PM
    #155
    Rich91710
    Rich
    Los Angeles
    08 Base
    Camera is on the tailgate handle on the right end. The "lever" is a bit shorter and the camera occupies the last inch or two. You'd know it if you had it.
    That goes double if you have the camera since a damaged harness is not likely to be cheap to replace.
  16. Feb 20, 2013 at 5:45 PM
    #156
    western88
    western88 Chris b.
    ny countryside
    2014 SR5 4x4 taco Barclona Red
    beather mod Bugsheild backup light mod egr vent
    ok folks.. I brought the kit like trooper12 have. I did a bit differnt but not much. I like to have the on/off swtich for the fog lights so I use it if need to. I set up the lights like Trooper had done. The relays, body ground is attached next to the main fuse box. Run the wires thru firewall. The other end is the switch. put in one of empty slot next to blinker side. Its not nessuery to take off the lower panel off, just snake the wire thru the slot. Make connections. Here the part is only differnt: I ran another wire thru firewall to connect the red wire. The other end which runs to the the socket for the High/low beam plug. look for the red/orange strip wire. which is the low beam, plug the red wire in there. So this way you are 50 state legal spec for low beam with fog light on. high beam/ no fog light on. You can anytime turn off fog light by hitting the switch. Pics to follow this weekend. cam wont work good in windy cold 19 degree NY weather.
  17. Feb 24, 2013 at 5:30 PM
    #157
    Armcphail
    Armcphail Member
    Aaron
    Chatham,Ontario
    4 cyl sr5
    Found the wiring harness behind the tailgate cover on the inside, just wondering if I install the camera if it will work inside somehow on the the touch screen display. Any thoughts folks?
  18. Mar 12, 2013 at 7:58 PM
    #158
    RoosterCogburn
    RoosterCogburn I have ten reputation points
    Vick Vinegar
    Ass Kick USA
    2013 DCSB 4x4
    ^I think there's a thread somewhere here where they've made that happen. Not sure.
    Also, wanted to thank the folks of this thread. I put in the fog lights, relay, and switch yesterday in about thirty minutes. Easy, and for 140 bucks you can't beat it.
    (of course I bought the amber switch on accident and am sending it back:eek:)/story of my life.
  19. Nov 2, 2013 at 3:26 PM
    #159
    skarface
    skarface Active Member
  20. Nov 2, 2013 at 4:24 PM
    #160
    Rich91710
    Rich
    Los Angeles
    08 Base
    Housings, yes. Switch, relay, and harness, no.
    $40 for a new factory switch and $55 for the relay.
    You need those whether buying housings from Toyota ($140 each), or this $100 kit. Buy the kit, and sell the switch (some "Tundrasite" or something asks $60 for these cheap Chinese switches and claims they're factory)
    https://www.partswebsite.com/1sttoy...74&year=2012&p=0&searchkey=yes&i=2&type=parts
