2012 foglight anytime mod ?
Discussion in 'Lighting' started by Hydrolai, Nov 8, 2011.
  1. Jan 27, 2012 at 1:26 PM
    Rossi396
    Rossi396 Rossi396
    Tony
    Pittsburgh, PA
    2020 Super White TRD Off Road DCSB
    The diagram above (see the green circles) works. Use the top left slot. The only issue is you have to shut off your fog lights. Not really a big deal. The other wiring method works fine, too. You just have to run the wire outside the box. With that method, you can leave the fog light switch on when you shut the truck off.
    Both ways work fine....
    Rossi
  2. Jan 28, 2012 at 12:54 AM
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    Very cool write-ups. Did the mod in a few minutes. Used the diagram with the green circles. Thanks guys.
  3. Feb 9, 2012 at 4:50 PM
    Cobalt719
    Cobalt719 Well-Known Member
    Chesapeake, VA
    '12 4 Banger PreRunner DC
    LED Interior Lights, Tailgate Anit-Theft Mod, OEM Skid Plate, Aftermarket Fogs, Tow Hitch
    So not to completely jack the thread but lets say you want to do the exact opposite and have the fogs cut off with the high beams? I bought some aftermarket fogs and after looking at the wiring it looks like they are independently wired from the lights so they will not turn off when you turn on the high beams. I live in VA and here it is unfortunately a requirement that they turn off with the high beams. Any insights would be great!
  4. Feb 9, 2012 at 5:01 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    You would need an additional relay that opened up when voltage hit it instead of closing. Where it would need to be installed, and what size/type of relay I am not sure.
  5. Feb 10, 2012 at 7:38 PM
    Cobalt719
    Chesapeake, VA
    Cool deal thanks. I think I follow you. Just so I understand I'm gonna recap.
    Add a circuit to the low beam fuse in the box > fog light relay > switch?
    Do I still need to connect the power to the battery using the factory harness?
    Sorry pretend I'm dumb. I'm very new to this.:confused:
  6. Mar 8, 2012 at 4:38 PM
    504taco
    504taco Active Member
    Jacob
    N.O.L.A.
    2011 Prerunner SR5
    -Fog light mod -Yellow laminx fog -shorty antenna -maglight mount -tinted windows -alpine head unit -8" JBL sub -laminx yellow fogs -power inverter installed behind rear passenger seat -TX PRO rims -BFG All Terrain KO
    Does this kill the DTRL's? I noticed in your pic the DTRL's are off...
  7. Mar 10, 2012 at 8:58 PM
    Johnny E
    Johnny E Well-Known Member
    Langley, BC Canada
    2012 Taco TRD DCSB 6MT
    Bilstein 6112 & 5160’s, OME EL096R’s, ARB RD129 Air Locker, PacBrake On-board Air, Anytime Fog Light Mod, Custom Behind the Grill Light Mount, 28” Stealth LED Bar, Headache Rack, Trimmed front Mud Flaps
    doing it this way works well. This is a switched source so the the lights will function only when the ignition is on
    thx cintocrunch
  8. Mar 10, 2012 at 9:11 PM
    Johnny E
    Langley, BC Canada
    Ultra Stealth Mod
    After cintocrunch showed me the easy wayfor a 2012 it occured to me this could be done even cleaner. The image below is the underside of the sub panel. If you were to swap the red/black wire in the upper right corner with the pale green wire in the lower right you would not need the jumper wire or to mess with the relay. Note if you have heated seat the this would be bad as now they would only work with the headlights on lowbeam [​IMG]
    I took a look at this tonight and it seems there is a small clip holding the witing connector in the panel. If anyone know how to release the clipthis would be a super clean mod, heck it would even be fused as it is a factory wire [​IMG]
  9. Mar 23, 2012 at 1:27 PM
    wlandrum
    wlandrum Member
    Pasco, WA
    '12 Tacoma DC/LB, Mag Gray, TRD Sport
    This is the way I did it, and it worked great. Thanks for the info here on this thread.
  10. Mar 24, 2012 at 8:08 AM
    Rossi396
    Rossi396 Rossi396
    Tony
    Pittsburgh, PA
    Anyone have a cleaner pic of this? Having trouble deciphering exactly what was done here...
    Rossi
  11. Mar 31, 2012 at 8:08 PM
    KrispyTaco
    KrispyTaco Member
    Indio, CA.
    Fog light mod, removed mud flaps, window tint
    Rossi396,
    I have a 2012 DC TRD O/R and just finished this mod. I'm getting the 12V from the top left connection. Waiting to see if the fog lights turn on after engine shutdown.
  12. Mar 31, 2012 at 8:43 PM
    KrispyTaco
    KrispyTaco Member
    Indio, CA.
    Okay, I just saw my fog lights turn on for split second, then turn off. I wonder if they're going to be turning on and off every few minutes. I guess I'm going to have to wire it to the trailer relay.
  13. Apr 1, 2012 at 5:33 AM
    cintocrunch
    cintocrunch Special Substitute Guest Member
    MD
    2012 DCSB TRD Sport MGM 6MT
    Anytime fogs, Leer Tonneau
    If you are talking about my picture (the one with the red wire) it doesn't get much simpler. Bend up the bottom left tab on the relay, add female connector to bent tab, add wire, add an inline fuse (I did 1 amp), add male connector, insert in seat heater relay location as shown. It took longer to explain to my father why this wouldn't damage the truck down than to do it (I tried to make it a father/son activity, bad choice).
    Check your fog light fuse. For some reason when I first pulled the relay and put it back it popped the fog light fuse. When I pulled the relay to do the mod I had no issues...
  14. Apr 2, 2012 at 6:47 AM
    Rossi396
    Rossi396 Rossi396
    Tony
    Pittsburgh, PA
    Yeah...Got it. Thanks. I couldn't tell from the pic if the red wire went somewhere other than the seat heater relay. Which, by the way, I don't have...So this won't work for me anyway..! I'm just using the diagram with the two green circles and trying to remember to shut my fogs off.
  15. Apr 2, 2012 at 10:05 AM
    #35
    TACOconvert2012
    TACOconvert2012 My truck hates you. My wallet hates you.
    Socal
    SC'd 2012 MGM TX/Pro 4x4
    never ending..
    ok so i used the slot with the green circle closest to the top of the pic... works perfect except that fog lights only com on with key turned all the way to ON position. it does not allow them to be used in the with the key on Acc like the other lights.. but hey still supper clean to keep in in one box no drilling and when the truck is off they stay off too.
  16. Apr 2, 2012 at 12:42 PM
    #36
    KrispyTaco
    KrispyTaco Member
    Indio, CA.
    The other method can be done cleanly as well. These pics are from Johnny E and will give you the options you want:
    • Notice where the wire is coming in with the other harness at the top.
    • You can see the wire coming from the fog relay & going into the hole in the center of the box. Then it runs out with the other harness to the right. I removed the wire loom & ran the wire through the loom and re-taped it. It looks clean and no drilling required. ;)
  17. Apr 4, 2012 at 10:13 PM
    #37
    TACOconvert2012
    Socal
    never ending..
    how do you pop that sub fuse box up?? i couldnt figure it out and dont want to break it..
  18. Apr 4, 2012 at 10:14 PM
    #38
    TACOconvert2012
    Socal
    never ending..
    you dont run a inline fuse??
  19. Apr 5, 2012 at 12:01 PM
    #39
    KrispyTaco
    KrispyTaco Member
    Indio, CA.
    I did just to be safe.;) I also wire tied the green wire and the one coming from the fog relay. Don't want that sucker popping out.
  20. Apr 24, 2012 at 4:27 PM
    #40
    jdelbono
    jdelbono Member
    Jack
    Massachusetts
    12 Tacoma - TRD Sport Upgarde
    Flowmaster American Thunder Dual Outlet exhaust
    Johnnie,
    Just to confirm - bottom right power source will not cause any issues w/fog lights coming on after vehicle is off? I am trying to be able to leave fog light switch in on position at all times and want fogs to come on w/parking lights and headlights. Sorry to bug you but I have been reading so many options - but this one looks the best. 1 amp fused power source also recommended?
    Thanks in advance.
    Jack
