2012 foglight anytime mod ?
Discussion in 'Lighting' started by Hydrolai, Nov 8, 2011.
  1. Nov 25, 2012 at 11:45 AM
    #81
    Palmetto Pete
    Palmetto Pete Well-Known Member
    Pete
    In the Mountains
    2012 SSM TRD Sport DCSB 4x4
    3M Paint Pro Film, OEM Bed Mat, Antenna X, WeatherTech Floor Mats, Foglight Anytime Mod, 8000k HIDs, BFG AT/KOs (265/70/17), Debadged, Ultra-Gauge, Leer 100XR
    In-line 10 amp fuse
  2. Nov 25, 2012 at 11:49 AM
    #82
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    Oh really?
    you're not supplying power to the fog light from this jumper. a one amp fuse to protect the relay circuit would be sufficient.
  3. Nov 25, 2012 at 12:02 PM
    #83
    Palmetto Pete
    Pete
    In the Mountains
    10 amp is the smallest I had in the garage at the time.
  4. Nov 25, 2012 at 6:26 PM
    #84
    Datsik
    Datsik Well-Known Member
    Anthony
    San Diego
    1999 Tacoma 4x4
    Not much.
    Did it. Super easy.
  5. Nov 25, 2012 at 6:27 PM
    #85
    Datsik
    Anthony
    San Diego
    1999 Tacoma 4x4
    Not much.
    Thank you sir. I used a 5. Smallest I could find
  6. Nov 25, 2012 at 10:08 PM
    #86
    Palmetto Pete
    Pete
    In the Mountains
    No problem! Glad I could help!
  7. Dec 2, 2012 at 10:18 AM
    #87
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    This seems to be the safest way! Has anyone found any weird side effects yet?
  8. Dec 2, 2012 at 12:42 PM
    #88
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    I dont have that relay in the air pump spot. Will my lights still come on by themselves if I use that spot?
  9. Dec 14, 2012 at 4:02 PM
    #89
    bmiranda
    bmiranda Member
    I have a 2013 TRD Sport, and I have no power to any of the empty terminals in the sub panel..there are no female blade connectors in any of the empty slots like shown in the above pictures...any ideas?
  10. Jan 19, 2013 at 2:10 PM
    #90
    tintedtaco
    tintedtaco New Member
    Iowa
    12 Tacoma SR5
    5% window tint, 265/70/17 Mickey Thompson Baja ATZ tires, 17x9 helo rims
    i have a 2012 tacoma and i recently put hid's on it and im lookin to do this foglight mod but i dont have the female terminals down inside of my box with the foglight relay, what are my other options?
  11. Feb 24, 2013 at 11:56 AM
    #91
    SpruceJPG
    SpruceJPG Raging Dunkay
    .JPG
    Maryland
    2013 Spruce Mica DCLB SR5
    WeatherTech Floor Mats and some window tint
    I feel your pain TintedTaco. Went to do the mod today, and I also have the same problem... 2 relays in that box, and no wiring to the other the other open spots. Mine is a 2013 DCLB SR5. Tested a few connections over in the main fuse box which I could get to work, but im trying not to run a cable from the smaller box over to the larger. Unfortunately at this point, I think it may be our only option.
  12. Apr 7, 2013 at 8:38 PM
    #92
    OmegaQuest
    OmegaQuest Well-Known Member
    Maryland
    2013 Tacoma Limited Double Cab 4X4
    Oil Catch Can, Motorcycle Chock, WeatherTech Window Deflectors, Bilstein 5100, OEM 4 Leaf, Chrome Satoshi Grille, FX-R Stage III Retrofit, Color Match Head Light Mod, Front Hella 500 HID, Behind Grill Light Bar, Rear LED Bed Lights, Pop and Lock Tailgate, Chrome License Plate Covers, AFE Air Filter, Removed Secondary Air Filter, Paint engine cover (Red), ImMrYo Rear-View Mirror Lift Bracket, Center Console Organizer, ScanGauge 2, Firestone W217602407 Ride-Rite Kit, Firestone WR17602178 Air-Rite Dual Electric Air Command
    sub for later. I'm going to hook up my halo lights to the fog lights and then do this mod so they are always on when I press the Fog Light button on in the cab no matter if the high beams or what ever is on.
    Thanks
    Stryker420 likes this.
  13. Apr 11, 2013 at 9:10 PM
    #93
    SR5808
    SR5808 Well-Known Member
    J10
    Honolulu,Hi
    Black Prerunner SR5
    Tint/ weathertech visors/ truxedo tonneau cover/ color matched front emblem and door emblems/ Clazzio Leather seat covers/debaged tail gate/depo black tail lights/color matched front grill/led headlights/ Pioneer Avh-5800/ Alpine Type R Front and Rear speakers/ Alpine Pdr-v75/ JL audio 10tw3/ Mr. Marv Custom sub box/amp rack/ Stealth Custom Series Stealth 6 17x8.5/ 265/70/17 Nitto terra grapplers...
    I know its been answered. But what kinda wires and connectors would I need to do this mod on my 2013? Still a noob at this. Lmk. Thanks guys.
  14. May 2, 2013 at 10:59 AM
    #94
    DannyD
    DannyD Well-Known Member
    Dan
    BC Canada
    2012 Tacoma TRD off road
    I seem to have a different sub panel then you guys. Same year, this is an access cab TRD off road. I'm missing the green and Grey? In the bottom right corner. Looking from above that space is empty aswell
  15. May 6, 2013 at 5:42 PM
    #95
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    I just did this mod, instead of un clipping, I stripped the green wire out, hooked a female connector to it, and connected that to an in line fuse (3amp) from the relay, I was able to feed the relay end through the hole on the bottom and tuck away the in line fuse on the bottom of the box, makes it super convenient to disconnect in case of dick head inspections.
  16. Jun 13, 2013 at 6:27 PM
    #96
    scorpio382
    scorpio382 Active Member
    D-Man
    Maui Hawaii
    2012 TRD off road
    6" BDS Fox lift, Total Caos UCA, Magna Flow exhaust,Westin chrome running boards, E-3 spark plugs,euro rubber antenna,tint,SS Brakes lines, Akebono Brake Pads, Centric Rotors, AFE stage 2 pro dry intake system,JBA Titanium ceramic shorty headers,rain guards,redline EZ down hood & tail gate, Toyota full synthetic oil, any time fog light & rear camera mods, full time 400 watt mod.
    Just did the fog light any time mod on my 2012. Just like above but I added a 10 amp inline fuse. Works perfect.. Fast and easy mod
  17. Aug 3, 2013 at 4:33 PM
    #97
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    apparently, my truck is a "special edition" (sarcasm). none of the connections worked for me. my headlights would come on and stay on, even in the off position, using the terminals suggested. any other ideas?
  18. Aug 7, 2013 at 2:26 PM
    #98
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Dublin, OH (but still a Pittsburgh guy)
    2013 Black Baja Access Cab
    I plan to do the Johnny E Ultra Stealth Mod – swapping the red/black with the pale green wire in the sub panel – on my 2013 Baja, but I have a question. This would result in the exact same circuit as adding a jumper from the lower-right green circle (the pale green wire) and connecting it to the bent relay connector. I assume that the pale green wire is also a fused circuit from the factory (heated seats?), so why is a fuse needed if you do the jumper method but not the Johnny E Ultra Stealth Mod? Wouldn’t adding a fuse to the jumper be redundant? Am I correct in assuming that the Johnny E Ultra Stealth Mod does not require a fuse?
  19. Aug 7, 2013 at 5:23 PM
    #99
    J Gibson
    J Gibson Well-Known Member
    J
    Knoxville, TN
    '12 DCSB,4wd,TRD Sport, tow pkg, MGM
    katzkin leather, toyota step bars, pro grill, advent overhead DVD player, cargo extender, bed mat, husky liners, impulse digital brake controller, avs bugflector, tinted windows, Firestone ride-rite air bags, ARE camper top with tool doors, ScangaugeII, ProEFX tow mirrors, ImMrYo rearview mirror lift bracket, Salex glove box and console organizers, 2020 Tacoma Pro styled wheels, 265/70 r17 Michelin MS2 tires, LED map lights, drivers seat extended and raised, ram ball tech deck installed, blacked out badges, tinted taillights, upgraded climate control knobs, ultimate headlight upgrade with Osram superbrights and wiring harness along wit OEM pro headlight housings.
    What is the add a circuit? Will the fogs always be on?
  20. Aug 8, 2013 at 5:33 AM
    #100
    PaulK
    Paul
    While figuring out how to best do the fog lights anytime mod, I also looked into getting some brighter bulbs. There are lots of vendors who offer “high performance” H11 bulbs – Sylvania, PIAA, lots of other vendors on Summit Racing’s website – but are these bulbs really worth it?
    Also, while looking I found a thread on an Acura TSX forum that showed how to modify H9 bulbs to replace H11 bulbs. Apparently the light output when switching from standard H11 to H9 bulbs goes from 1350 lumens to 2100 lumens, while the wattage goes from 55w to 65w. The only physical difference between the bulbs is an additional small plastic tab in the socket area that can be easily cut away with a utility knife.
    http://www.tsxclub.com/forums/1st-gen-electronics/15061-fog-light-h11-h9-bulb-conversion.html
    Has anyone tried this? Is it safe to up the wattage?
