2012 foglight anytime mod ?
Discussion in 'Lighting' started by Hydrolai, Nov 8, 2011.
  1. Aug 8, 2013 at 7:39 AM
    #101
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    Found these pics on a Tundra Forum. Looks like you also have to snip off a little from one of the three metal tabs to make the H9 bulb fit the H11 housing. Several guys did this to their Tundra fog lights with no ill effects. I’m going to try it this weekend if I can find the bulbs at a local parts store.
  2. Aug 9, 2013 at 5:09 AM
    #102
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Anyone know how to do this on a 2013 the spots are blank in the little side box and any open ones are the same in the main box. Thanks to anyone who has the information
  3. Aug 9, 2013 at 6:50 AM
    #103
    PaulK
    Paul
    Pittsburgh, PA
    I think this an issue of trim level and/or options. My 2013 Baja, non-towing package has the wiring in the sub panel. That said, I have seen threads elsewhere that recommend using an add-a-circuit in the tail light fuse slot. This provides ignition-only power when the tail lights are on. That would mean you could use your fog lights anytime you had the running lights on (just running lights, or headlights too). If you want them to work even without the running lights on, I suppose you could pick another fuse to tap. Just make sure to stay away from anything having to do with the emissions system or you might get the lights turning on by themselves when the truck is parked. Also, I’ve heard, but can’t confirm that using the fuel pump circuit is a bad idea.
    http://www.amazon.com/Bussmann-BP-H...TF8&colid=2F3Z1T5J4SZAQ&coliid=I1OZSOXELI734M
  4. Aug 9, 2013 at 7:04 AM
    #104
    Timbo's Customs
    Timothy
    Lakeland FL
    I have the tow backage and the relay for trailer control is dead but has a relay in it. No power when on or off. One says c/opn but found out it has to do with fuel so left that one alone. Ill grab a add a circuit at work already have a inline fuse holder.
  5. Aug 9, 2013 at 6:20 PM
    #105
    Timbo's Customs
    Timothy
    Lakeland FL
    Well the only fuses that uave no power when off are the headlight fuses, a/c and a sta. Fuse. Tried the a/c it works but only if I turn the ac on. Dont want to jump into a headlight circuit would defeat the purpose. Looks like I need to start finding a wire into the harness at the fuse box to tap into. Anyone done this to a 13 yet that has successfully done it??
  6. Aug 9, 2013 at 7:28 PM
    #106
    bueller
    bueller Well-Known Member
    AZ
    I tapped into the green wire as shown on the first page of this thread. Ran a jumper to the fog relay. I didn't have anything to tap into in the small box, so I had to run a wire between the two. The only downside is turning the lights off does not turn the fogs off. They're on when the key is on, so if I forget to turn them off, they will come on when I get in the truck next. I'd rather not be running them during the day. At least the key off turns them off and they don't come on by themselves like some of the other options.
  7. Aug 12, 2013 at 9:54 AM
    #107
    PaulK
    Paul
    Pittsburgh, PA
    I did the mod over the weekend, choosing to go with the simple green circle jumper method within the subpanel box. Works perfect.
    I also did the H11 to H9 conversion, which took about 20 minutes. I used standard Sylvania H9 bulbs, and my fogs are MUCH brighter now. They make a SilverStar version, which I guess would be even brighter, but the standard bulbs were cheap and available off-the-shelf at the local parts store.
  8. Nov 28, 2013 at 8:26 AM
    #108
    Bodacious
    Bodacious Well-Known Member
    Dave
    Northern Michigan
    TRD Sport 4x4
    my small box on the 2014 looks identical to this picture, except the two relays vac spots next or right of the existing blue relays have no wiring pins in the terminals ( no hot pins all unwired from the factory). Need a switched power spot to pick up from.
  9. Feb 21, 2014 at 4:49 PM
    #109
    GrumpyOldMan
    GrumpyOldMan Member
    Thomas
    Vancouver Island
    2006 Tacoma SR5 Off-Road
    6" Pro Comp Lift
    I didn't have power to the seat heaters... in other words no green wire to swap. I also didn't want to drill holes into the sub fuse box nor the main. And... I didn't want to bend (possibly break off) that relay connector.
    What I don't have a problem with is cutting wires. So... long story short, I cut the red/black wire, sealed the end going back into the harness, connected another wire to the one running up to the relay and ran it out the bottom of the sub fuse box, then up the wiring harness into the main. Once there, I found an open slot in the middle for the power. 15amp fuse was also wired in.
    Pros: No bending, drilling.
    Cons: Fog lights can be turned on with or without ignition power. So it's possible to accidently leave them on. (Fortunately... that will never happen in my world... OCD takes over)
    Bravisimo likes this.
  10. Jun 11, 2014 at 9:02 PM
    #110
    KnoxTac0713
    KnoxTac0713 Well-Known Member
    Justin
    Knoxville, TN
    13 DCSB SR5 4x4 Barcelona Red
    Bilstein 6112, rear 2.0 Icon VS shocks, TRD Black SEMA wheels, 255/80/17 Cooper ST Maxx, SOS Rear bumper, SOS bolt on sliders,TRD skid plate, derped badges, 15% tint, color matched oem grille, lamin-x amber fog covers, TRD cat-back exhaust, Tacoma bed mat, Tonno-pro trifold, Depo black tail lights, front tow hook w/ D shackle, Wheeler's Superbumps rear, Wheeler's 1 inch block rear, Custom Car Grills mesh grill insert, light bar in lower valence
  11. Jul 22, 2014 at 8:18 AM
    #111
    TacoTronics
    TacoTronics War Eagle!
    Frankie
    Auburn, AL
    2014 V6 DCSB TRD Sport
    G4 Elite tonneau cover. Fuel Vapor 17s. Bilstein 5100s. Wheelers 1.5" Progressive AAL. AVID Sliders Line-X, Nokya Hyper Yellow Fogs, Fog Mod. Debadged, Ghost bedside decals, Line-X AVID Light Bar, ImMrYo mirror lift, Mattgecko LED bed lighting with remote, CSJumper2003's DTRL LED switchback mod, reversing, and parking. Nat's Rear Molle Panel for storage, HomerTaco grill.
  12. Jul 22, 2014 at 8:24 AM
    #112
    TacoTronics
    Frankie
    Auburn, AL
    What made you choose 15 amps? Are you running stock bulbs?
  13. Dec 14, 2014 at 2:05 PM
    #113
    drscott11
    drscott11 Well-Known Member
    Super-easy mod, especially on a 2012. Thanks!
  14. Dec 15, 2014 at 9:23 AM
    #114
    GrumpyOldMan
    GrumpyOldMan Member
    Thomas
    Vancouver Island
    6" Pro Comp Lift
    Hey TacoTronics... I didn't see your question until today. Two reasons for the 15amp fuse. 1) Yes... stock bulbs, 2) That was all I had in my tool box at the time. :)
  15. Jun 6, 2015 at 2:23 PM
    #115
    MattB77
    MattB77 Well-Known Member
    OR
    2013 AC TRD Sport
    Here is a pic of mine itsit's a '13 i wanted to run it all the same small box but the 2 spots that was previously posted circled in green I don't know if that will work. The lower right spot there's nothing there and the top spot I have another relay. Anyone know what the top blue relay is?
  16. Aug 17, 2015 at 10:56 AM
    #116
    tommyhd03
    tommyhd03 Well-Known Member
    tommy
    spartanburg
    Sport Tacoma double cab long bed
    885 coils, blistein 5100 front and rear, 1 1/2 AAL. SCSI sr8 wheels, 285/70/17 cooper discover at3 tires.
    So I did it this way. and now my instrument panels wont work along with my tailights. What did I do wrong
  17. Feb 27, 2016 at 11:47 PM
    #117
    MCM78LC
    MCM78LC Well-Known Member
    Saint Paul, MN
    2021 Toyota Land Cruiser
  18. Dec 30, 2016 at 1:37 PM
    #118
    Dhannah
    Dhannah 2017 Tacoma OR DCSB
    Daniel
    North Carolina
    '17 DCSB OR TRD 4x4
    Under Construction
    subd
  19. Jan 22, 2017 at 11:50 PM
    #119
    DJSPEC
    DJSPEC @GuardianAdventures
    Sean G
    Kaimuki,Hawaii
    2011 TRD Sport DCSB 4x4 & 2014 TRD SPORT DCSB & 2016 TRD-OR AC 4x4
    Viper Alarm NorthStar 31 Battery Pelfreybilt Battery Cage OEM roof racks, step sides 35W 6000k HID Fog Lights 35% tint Front windows 5% tint rear windows 2 Sets of Rigid Industries D2 above the valance Duallys on Famous Fabrication's Hood Hinge Brackets Rigid Industries SR2 10" in HoodScoop with C4 Fabrications Hood Scoop Bracket Flowmasters Super 44 series 9942446) Firestone Destination MT/2 295/70R17 Method 702 17” 0 offset Wet Okole Seat Covers OEM Tow Hitch Plastidip Front Valance FoglightMod(Fuel Pump Relay Version) Matt Gecko Truck Bed LED Kit and Sliding Window Security Bar Snugtop Rebel King 2.5 adjustable front and rear Dakar HD Leaf Springs Icon tubular UCA Dirt Kings LCA
    I did it this way on my wife's 2014 TRD sport, I used a small eye glass screw driver and pushed the inside metal of the female connectors outwards giving the plastic tab holding it in place more room to release the female connectors.
    Bending the plastic tab out of the way was close to impossible for me.
    The plastic tab hooks/catches on to the flares of the female connectors so if when I pushed them away from the middle, they slid right out for me.
  20. Feb 21, 2017 at 2:50 PM
    #120
    Bravisimo
    Bravisimo So many mods, very little money.
    Joe
    Santa Clarita, CA
    2014 Tacoma PreRunner SR5 DCLB
    Tint, headlights wrapped & rear lights smoked, power outlet mod., grill & rear bumper wrapped, Falken A/T 3W,
    Im about to do the same mod on my 2014. I got the in fuse wire from radio shack. $5. Bit I don't know which fuse to get cuz there are several when I was looking through radio shack parts. I also don't know what type of wire connectors to use. Can anyone suggest?
