2012 front brake pad rattle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tpr676, Aug 20, 2012.
  1. Aug 20, 2012 at 5:30 PM
    tpr676
    tpr676 [OP] Well-Known Member
    I just wanted to throw this out there it has been driving me nuckin futs, at first I thought it was a loose heat shield or possibly the 18" chrome clad wheel. My truck has 4800 miles on the clock I did pull the the front wheels checking for the source, anyway Toyota only puts 1 spring on the bottom caliber pin leaving the top of the pads to rattle. I install 2 springs one each side, yes I know it's under warranty problem solved. I am taking it in for the vibration @ 20 mph I did rotate my tires it seem to improve there is a lot of weights on the inside of these wheels maybe it's out of balance or it's the driveline. The weird thing is my peeps at the dealership says no one has complained so if Toyota only installs 1 spring per side and my pads were rattling has anybody else had a issue.
    RCKT82 likes this.
  2. Aug 20, 2012 at 5:39 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Mine only shift when going from reverse to drive. They don't rattle.
  3. Sep 27, 2012 at 10:59 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I have the rattle problem, thanks for the info.
  4. Sep 27, 2012 at 5:12 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    I have also been hating this for so long, would you be so kind as to post pics of how you set up the springs. Are the springs avail at the dealer?
  5. Sep 28, 2012 at 3:42 AM
    tpr676
    Yes they are I think it's $3 and change for 2 in a pack, I also believe they are a bit beefier than what's on there. Part # 04947-0c010 fitting kit, disc brake front. I will post pic for you later today.
  6. Sep 28, 2012 at 4:11 AM
    MATOAKA
    MATOAKA Well-Known Member
    Takomus
    Norfolk, VA
    09 PreRunner
    trd cold air intake, trd cat back exhaust, austin tube running board, truxedo tonneau cover, toyota xm radio, vip security system, weather tech floor mats, weather tech side window deflectors, e-z down tailgate strut, redline tuning hood strut, shortie antenna, billies 5100s, u-haul tow receiver, patial debadge, sockmonkey VA trd sport bed sticker,
    I have a Silver 2009 DCLB TRD Sport 25k+ I am also hearing rattle when I brake. Only on slow speed. I can't tell if it's coming from the front or back. My dealer says its coming from the front brake pads. They adjusted it but the rattle returns after a week.
  7. Sep 28, 2012 at 4:21 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    When does it rattle?
    Mine - as the brakes got older - used to 'clunk' when first moving forward or reverse but I just changed my pads and no more clunks. I had 51,000 miles on the first set of pads.
  8. Sep 28, 2012 at 9:34 AM
    Asgard
    ^^Mine doesn't rattle with new pads, only when the pads are worn down about halfway or more.
  9. Sep 28, 2012 at 2:13 PM
    Good351
    Good351 Well-Known Member
    Ames, IA
    03 4Runner V8
    Mine rattles like crazy..over every bump it will rattle. Reverse to forward it clunks too..
    Pics please :)
  10. Sep 28, 2012 at 3:25 PM
    Janster
    Jandy
    Lancaster, PA
    If you search google, it appears ALL toyota vehicles have the same thing.
    It almost sounds like the pistons aren't adjusting as the pads wear....
    OP - did you try a different dealership?? Did you request they inspect the pads/pistons? Or request they take them off, lube the pins, put them back together, bla bla bla?? Try putting your foot on the brakes (truck OFF) several times to the floor and again several times (truck running)....
    Sounds like they aren't adjusting properly..??? Just a guess...
  11. Oct 1, 2012 at 7:17 AM
    whargreaves97
    whargreaves97 New Member
    Will
    Southern Maryland
    '11 TRD Sport
    I just got out of the shop (two trips) for the same prob. "clunk" over bumps was the symptom but it did it going from fwd to reverse and sometimes when braking... turns out the pin that the pads ride on fits through a hole that either elongated or was machined poorly. The oval (vice circle!) hole allowed the pads to shift either going over bumps or when changing direction of rotation. no probs for a few days. Will let you know if problem returns. My service manager said they had never seen before and showed me the pads... made sense and prob solved. I also noted the single spring and figure that a second spring would probably resolve the problem.
  12. Oct 15, 2015 at 9:12 AM
    RCKT82
    RCKT82 Well-Known Member
    Mid-West U.S.
    2013 PreRunner AC SR5 V6
    This definitely annoys the hell out of me. I only get it at slow speeds when I apply the brakes or hit a hard bump. It's probably doing the same at higher speeds but the road and wind noise drown it out.
