2012 rear locker question
Discussion in 'Technical Chat' started by r6hokie, Oct 30, 2011.
  1. Oct 30, 2011 at 8:23 PM
    r6hokie
    r6hokie [OP] Well-Known Member
    Virginia
    tint, fog light anytime mod, weathertech visors
    New 2012 potential owner
    I test drove the 2012 Tacoma today, double cab, off road package and have a question for those 2012 guys trying to lock the rear differential
    Ok getting into 4hi, green indicator comes on and does not blink
    Ok getting into 4lo, 4lo orange indicator comes on and does not blink
    When I am in 4lo and I try to push the rear differential button to lock the rear differential the red indicator comes on but it blinks
    Is the red rear differential locker indicator supposed to blink or stay solid for 2012?
    Help!
  2. Oct 31, 2011 at 4:15 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Pretty sure that means it hadn't engaged yet.
  3. Oct 31, 2011 at 4:15 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
  4. Oct 31, 2011 at 9:44 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Blinking means you pushed the button, but it is NOT yet engaged... driving a few feet, turning the tires a bit helps line the gears up so it will lock.
    However, you have A-TRAC and that engages instantly with zero difficulty. Use A-TRAC in low range, as it gives you traction nearly equal to lockers in the front and back.
    The Rear Locker is for emergency only (per Toyota), anyway... You may never need it off roading, but nice that it is there if you ever did.
  5. Oct 31, 2011 at 11:57 AM
    r6hokie
    Virginia
    I hear mixed things on the 2012's, it seems salesmen have no idea what they are talking about, I test drove two 2012 tacomas and in the parking lot in 4lo(while driving straight) I pushed the rear locker button and just could not get the red light to stay solid it kept blinking
    I am hoping to hear from a butt load of 2012 owners on here
    crazy
  6. Oct 31, 2011 at 3:36 PM
    David K
    It isn't just 2012, all three of my Tacomas ('01, '05, '10) take more than one attempt at engaging the rear diff. usually... It will go solid (the light) sooner or later... but, again I have to say not to worry... the A-TRAC is instantly active and it gives you front and rear traction. Don't worry about the rear locker... someday it may be gone once everyone understands A-TRAC, so until then it is a selling tool. When I got my third Tacoma, I didn't know about A-TRAC (other than seeing a test of it on a Lexus in the desert 10 years ago, but didn't know what it was)... and I buy the Off Road TRDs because they have the rear locker, always.
  7. Nov 28, 2011 at 1:40 PM
    TACOconvert2012
    TACOconvert2012 My truck hates you. My wallet hates you.
    Socal
    SC'd 2012 MGM TX/Pro 4x4
    never ending..
    i just bought a 2012 tx/pro and i cant seem to get the rear locker to engage either. it has worked twice for me just so icould check it out but it isnt consistent.. i need some help on the topic. i understand a-track but i want everything to work in this brand new truck...
  8. Nov 28, 2011 at 2:02 PM
    TACOconvert2012
    Socal
    never ending..
    lol ok i will try that and see what happens thanks man i know you posted to one of my other psots thanks for the info. ill check back in and let yall know waht happens.
  9. Nov 28, 2011 at 2:36 PM
    David K
    The A-TRAC turns on with NO EFFORT... and instead of just 'locking the back', it works on ALL FOUR wheels. Of course the rear locker should work as well... but if you are on the trail, and in low range... just always have the A-TRAC on... and it would be a rare condition when you would ever need to use the rear locker... if ever!
  10. Nov 28, 2011 at 3:09 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    ^X a billion
  11. Nov 28, 2011 at 3:41 PM
    TACOconvert2012
    Socal
    never ending..
    yea exactly i want to know about the locker lol i got that the A-trac to some is awesome but all aspects of a new truck should work so thats what im trying to solve. unfortunately im stuck at my desk at wrk and cant go play :/
  12. Nov 28, 2011 at 3:50 PM
    David K
    What are you all going to do when Toyota stops offering the locker? ? ?
    Yes, the locker should engage... mine does, sometimes at the first try sometimes it takes three tries. But, if we use it as it is designed to be used by Toyota, it is only to be used to get unstuck. (Yes, I know you can use it anytime).
    So, if you already have the A-TRAC... then getting stuck is pretty much a thing of the past! Seriously, if you are in a stuck that the rear locker can extract you from, then the A-TRAC (with double the traction of a rear locker) would get you out/ through.
  13. Nov 28, 2011 at 3:53 PM
    David K
    Yes it is, and IF IT DOESN'T WORK (as is the case here)... The OP and ANYONE ELSE should know that there is even MORE traction from their A-TRAC. The Rear Locker is only for emergency stucks (per Toyota) and the A-TRAC is for ALL the time you are in Low Range, if you want more than just open differentials.
  14. Nov 28, 2011 at 4:02 PM
    TACOconvert2012
    Socal
    never ending..
    lol i get that a-trac is cool(sounds awesome) but im just wondering why locker is so difficult to operate it kinda baffles me. figured it should be just as easy as a-trac to activate. IMO
  15. Nov 28, 2011 at 4:19 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I was wheeling once with Seth (PRS 2TiFJ) and he went down into some deep ruts. Once down there, he was in the classic "one wheel unloaded from each axle" articulation challenge and wouldn't you know - the locker wouldn't engage and he couldn't roll far enough one way or the other to get it to engage. He had to take a strap to get out.
    If you're going to roll over an articulation obstacle that's going to unload one wheel from each axle in that way - it pays to engage the locker when you're on relatively level ground beforehand.
  16. Nov 28, 2011 at 4:21 PM
    jandrews
    '09 FourDubDee TRD OR
    Motherfucking shithell.
    Ignore the A-TRAC retard. Let's talk about the locker. Here's some education for free folks:
    This is how an electronic locker works, in concept. This is GM's setup on Hummers, but the idea is the same. The carrier itself is essentially hard mounted to the spider gears in the differential, and the side gears are connected/disconnected to the spider gears by a locking collar that more or less makes one side gear one with the carrier when it's engaged. This has the effect of the side gear and both spider gears being locked to the carrier...which leaves the other side gear nowhere to turn, because the other three gears in the differential take it with them as they rotate. Hence the "lock". In place of GM's magnet/ball-bearing setup, Toyota uses an electronic motor with a splined gear to push the locking collar into place.
    http://www.youtube.com/watch?v=-VPPGsYq6TE
    See those little pins on the locking collar? See the holes they slot into? It works the same way in the Toyota Locker, only it's a splined collar rather than pegs. In any event, when you happen to press the locker button, the splines may not be lined up. You need to rotate the side gears at DIFFERENT RATES to turn the carrier so the splines in the locking collar line up with the splines on the carrier and the locker slots into place.
    The easiest way to rotate side gears at different rates is to turn your vehicle. This causes the wheel on the inside of the turn to rotate at a slower speed than the wheel on the outside of the turn, because it has less distance to travel. This rotates the side gears inside the diff and when the splines line up, voila - locked diff.
    SO, if your diff is cranky about locking, do this:
    Engage the locker, if the light is blinking, put the truck in reverse, cut the wheel to one side a turn or two, and idle backwards. I guarantee you won't have to idle more than a few feet and the locker will engage.
    Make sense now?
    This is correct. Engage your locker before entering hard obstacles, as long as you're not turning on a high traction surface. Even if other traction methods could get you through, why NOT have the control the locker offers?
    There is a difference between just getting your truck through the obstacle and getting your truck through the obstacle with a minimum of wear and tear and minimum risk of driveline breakage. Using it correctly is key to minimizing these risks and avoiding unnecessary trail repairs.
  17. Nov 28, 2011 at 4:52 PM
    Cr250jumper
    The moon
    50 shades of tan©
    VVVV - Now he can never say again that "I never said atrac is better than a locker." Double the traction? :rofl::rofl:
  18. Nov 28, 2011 at 5:47 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I didn't even read this statement the first time through. :eek: :rolleyes:
    David, seriously man. You're this weird Dr. Jeckle/Mr. Hyde mix of TW newbie helper guy/ATRAC-Locker BBS Troll. I don't know what to make of you; really I don't.
    I don't generally waste my breath telling folks what they should and shouldn't post on the interwebz - but man, you *do* throw out these inflammatory statements with regularity. I can only conclude that you *enjoy* the resulting imbroglio; otherwise you'd surely stop doing it. But if, perchance, some part of you is wondering why you're always in these enormous shit fights - well - it's time to look in the mirror, dude.
    Where's that cartoon? It goes something like:
    "...coming to bed dear?"
    "No, this can't wait. It's important. Someone is WRONG on the Internet!"
  19. Nov 28, 2011 at 5:52 PM
    jandrews
  20. Nov 28, 2011 at 6:04 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    So, if idling it into diff lock is ok(understood, gently and within reason), then if I was hung up with two opposing wheel spinning, and unable to get the locker to lock... can press the button, put her in gear and slowly move let a wheel move?
    Might save my own ass someday!
