2012 seat belt chime disable
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jesse.jamz, Nov 6, 2011.
  1. Jun 28, 2014 at 11:06 AM
    #81
    ancient11
    ancient11 Well-Known Member
    robert
    tallahassee
    2019 4 cyl srsx ac
    url=http://www.tacomaworld.com/gallery/showphoto.php/photo/412941/cat/500][​IMG][/url]
    Installed the seatbelt extension and problem solved.....no chime when I want it gone. Btw, never roll on asphalt w/o being buckled up.
  2. Jun 28, 2014 at 11:12 AM
    #82
    1stacoma
    1stacoma Well-Known Member
    Austin
    2012 MGM SR5 DCSB 4.0
    5100's front and rear, front 2.5" rear 2" AAL, 18% tint front and rear, color matched grill. SCS wheels 275/70/17 BFG AT KO's. DTRL toggle switch.
    I have a 2012 took it to the dealer asked them to turn it off. No questions asked they turned it off.
  3. Jun 28, 2014 at 9:20 PM
    #83
    gotpit
    gotpit New Member
    Dennis
    Alaska
    Tacoma TRD
    I went with the spring removal today after seeing this post. A small flat tip and a pair of needle nose pliers to snake out the spring and all done. No warning lights, no beeps. Probably only took two minutes to pull the sensor out and have the spring removed. Real trick is getting the sensor housing to snap back into place. You just have to be patient and wiggle wiggle wiggle wiggle until you get there.
  4. Dec 14, 2014 at 5:45 AM
    #84
    drscott11
    drscott11 Well-Known Member
    Going to the dealer is not a great idea as disconnecting the battery resets the controller to factory settings; meaning you have to go back to the dealer after every battery disconnect.
    Install an amp or stereo... back to the dealer. Change battery...back to the dealer. You get the idea.
    A more permanent solution is to locate the wires going into the seat belt then tie them together. This will trick the controller into thinking the belt is plugged in. I did this on my 4Runner and am about to do the same to my 2012 Taco as the buzzer is annoying as hell.
  5. Dec 14, 2014 at 7:13 AM
    #85
    JerryTaco
    JerryTaco Well-Known Member
    Not true. I've changed the battery twice on my 2012 and the seat belt chime has never come back.
  6. Dec 14, 2014 at 10:41 AM
    #86
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    seat belt chime is very inconvenient for people on ranches who have to get in and out of vehicle a lot. Dealer would not disable mine even though it says it is a custom feature in the owners manual.
  7. Mar 10, 2015 at 8:08 AM
    #87
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    Does this work for the 2014??
  8. Mar 10, 2015 at 8:19 AM
    #88
    EODwick
    EODwick Fire In The Hole!
    Ed
    Box Elder, SD
    2013 TRD Sport
    Stuff I Think Makes it Better
    I got my turned off at the dealership, just told em I ride with my dogs a whole bunch and they said no problem. Easiest way to do it is to get a tuner and turn it off
  9. Mar 10, 2015 at 8:33 AM
    #89
    aubi1414
    Justin
    Pensacola, FL
    Yeah I knew the dealership could but is there any other way too? My 2010 you had to follow a step by step process that worked well
  10. Mar 10, 2015 at 12:26 PM
    #90
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Had the dealer turn mine off as condition of sale. Have disconnected the battery twice since and warning chime is still off - 2015 Sport
  11. May 28, 2016 at 2:32 PM
    #91
    Pixelpaul
    Pixelpaul Member
    I'm not near a dealer, so I went with the spring removal route, as described on page 3 of this post. It was easy, quick to do, and it works! For my Taco 2012
  12. May 28, 2016 at 2:44 PM
    #92
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Turned mine off (and programmed a new Immobilizer Key) myself with this.
    #92
  13. May 31, 2016 at 6:07 AM
    #93
    Pixelpaul
    Pixelpaul Member
    With the spring removal technique, be aware that if you do remove the spring on the passenger side, it disables the airbag for the passenger. The 'airbag off' indicator light stays on. I did not find a workaround for that, so I just put the spring back on the passenger side. It was a lot harder putting it back compared to taking it out!
  14. May 31, 2016 at 9:43 AM
    #94
    JadedTaco
    JadedTaco Well-Known Member
    IA
    15 OR SSM (MT)
    Lift, tires, mats, blah, blah, blah...
