2012 Tacoma headliner removal....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by helvis, Apr 9, 2012.
  1. Apr 9, 2012 at 3:19 PM
    helvis
    helvis [OP] Member
    oceanside ca
    00 prerunner
    stock
    I have a new 2012 Tacoma SR5 Access Cab. I need to remove the headliner so I can install an antenna mount on the roof (I am a HAM radio geek). My model Tacoma has four airbag curtains at the bottom edge of the headliner. I don't want to screw those up. Does any have any advise and or experience for removing a 2012 access cab headliner? Thank You..
  2. Apr 10, 2012 at 10:29 AM
    currierstaco
    currierstaco Active Member
    Little Rock AFB
    05 sport pkg 3in lift on 20s and terra grappl
    spyder headlights, hids all around, painted bug deflector and window gaurds, 20s and terra grapplers, ready lift kit front, add a leaf rear, led tails and third, billet grille top and bottom, 2 polk audio mm1240dvc subs behind rear seat, hifonics 1000.1 amp, jvc deck, power acoustics 5 farad capacitor.
    All u need to do is disconnect the battery before u do absolutely anything. and besides popping the covers on the headliner and undoing the screws, and the dome light, pop off the trim and take off the o-sh*! handles and ure good. definitely recommend have a hand or two help just with the awkwardness of it. hope this helps
  3. Apr 11, 2012 at 9:44 PM
    helvis
    helvis [OP] Member
    oceanside ca
    00 prerunner
    stock
    Thanks for the advise. Im ready to tackle the task. Im fired up.
  4. Nov 25, 2012 at 5:39 PM
    2009tacomav6
    2009tacomav6 Well-Known Member
    phx AZ
    2012 4x4
    TRD SC TRD Cat Back KMC 17x9 Addicts
    How did it go? Any pics or tips?
  5. Feb 11, 2013 at 2:38 PM
    DaveEli
    DaveEli Well- Known Member
    David
    Virginia Beach
    2011 Tacoma Sport 4X4
    Icon Extended Travel Coilovers, King 700lb springs, All-Pro Expo leaf springs, All-pro U-Bolt flip kit, Icon 2.0 Series custom length rear shocks, Wheelers Superbump Bumpstops, All-Pro extended rear brake lines, Warn 86255 VR10000 10,000 lb winch, Warn 90287 wireless remote, Redline Hood Struts, AVS Bugflector II, Pelfreybilt front bumper with Rigid 92031 SR- Series White 20" Spot/Flood lightbar, Brute Force rear bumper with short swingarm, Famous Fabrication Rock Sliders, Pelfreybilt Skid Plates, Rigid 50231 D2 Driving Lights, Rigid 20221 Dually Spotlights, Rigid 98000 SR-M backup lights, ARB CKMTA12 "12V"on-board twin high performance air compressor, Dick Cepek DC-2 17x9" wheels, 285/70R17 Goodyear MTRs with Kevlar tires, Wet Okole seat covers,Airflow snorkle, ARE CX HD cap, Front Runner Slimline II cap rack, TRD cat back exhaust, AVS in channel window vents, Toyota door sill protectors, Pop & Lock tailgate lock, Husky Rear floorliners, WeatherTech Front Floorliners, DeeZee bed mat, Window tint, TRD drop in air filter, Plasmaglow led bed lights, Hi-Lift jack mounted on bed rail, IMMRYO Rear View Mirror Relocate, ARB 63 Quart fridge freezer, Arb ARB209 Snatch Block, ARB ARB730US 3" x 10' Tree saver, ARB ARB705US 2-3/8" x 30' recovery strap, Bubba Rope 7/8" x 30' original rope 28600 lbs, Bubba Rope Gator Jaw soft shackle 7/16.
    Do you do anything to the little plastic covers that say SRS Curtain Airbags?
  6. Feb 11, 2013 at 3:39 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
  7. Nov 2, 2013 at 8:14 AM
    wyotracker
    wyotracker Active Member
    will
    torrington wyoming
    11 taco off road
