2012 Tacoma HU removal
Discussion in 'Audio & Video' started by Hawaiianguy, May 28, 2012.
  1. May 28, 2012 at 5:58 PM
    Hawaiianguy
    Hawaiianguy [OP] Member
    Can't get the Hazard Switch and Passenger Restraint Indication Unit out of the factory housing. I can remove the outer screws holding the unit but I cannot get to the screw in the middle. Looks like I have to take the stock receiver out from the housing to get to the screw. Any help would be appreciated.
    Aloha
  2. May 28, 2012 at 7:49 PM
    Big Dustin
    Big Dustin Well-Known Member
    Dustin
    Denver, Colorado
    '17 Tacoma DCSB SR 4x4
    5100's all around, OME 887 with 1/4" spacer, icon 3 leaf aal. 255/75/17 BFG KM's on 4runner pro's. Rigid led pods. Debadged and tinted.
    You dont need to take the screws out. If you look between the box that holds the clock and hazard switch, and the thin piece of plastic that screw down, you can see little clips that hold it in.
    You just need to pry it out gently. It is a pain in the @ss to do, but can be done. I fought mine for quite a while before it came out. It also might help if you do take out a couple screws, so you can flex that thin plastic to undo the clips.
    Hope this helps.
  3. May 29, 2012 at 12:37 AM
    Hawaiianguy
    Thanks for the reply. I was trying to take out the sleeve around the unit. I finally figured it out and all is well. Mahalo
  4. Jun 1, 2012 at 12:47 PM
    Ciacci24
    Ciacci24 Member
    Honolulu, hawaii
    '12 Dcab 4x4 TRD Sport 6MT
    how did you get it out. Did you remove the stock radio first or just slip it out by removing the screws?
  5. Jun 1, 2012 at 3:44 PM
    Commanderwiggin
    Commanderwiggin Well-Known Member
    Calgary
    12 Tacoma D/C 4x4 TRD Sport 6MT Supercharged
    Have fun...I still don't really know how the heck I got mine apart...I know it was an extreme PITA! At the end of it I had like 6 kitchen knifes stuffed in places...
  6. Dec 13, 2012 at 5:49 AM
    Voodoochild 2k9
    Voodoochild 2k9 Well-Known Member
    Randy
    Florida
    TBD
    Undercover SE; DD Pioneer Radio
    Thanks for the tips. Finally got mine out. Now that I figured it out (with y'all's help) I think I could do it again no prob. I was also trying to take out the sleeve it was in. Realizing which piece to remove and where the tabs were was the key.
  7. Dec 14, 2012 at 2:41 AM
    tractng
    tractng Well-Known Member
    Just last month, I had the same issue. Almost crack my unit. I was about to pull the receiver out.:D
