2012+ Tacoma V6 Block Heater Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rockhopjohn, Sep 3, 2013.
  1. Sep 8, 2014 at 6:32 PM
    Gerrrr
    Gerrrr Well-Known Member
    Jeremy
    Ottawa, Canada
    2017 Blazing Blue Metallic (Limited 2013 Silver Streak DC Auto - Retired)
    Starting over.......
    I will check out the price at local dealer for you in the AM
  2. Sep 8, 2014 at 8:04 PM
    TRDWEST
    TRDWEST Well-Known Member
    Tucson, AZ Area
    2012 DC TRD OFFROAD 4x4
    CVT RTT, VooDoo 10 inch bed rack
    Awesome thanks a lot! This will really help me out for the upcoming winter in nebraska
  3. Sep 8, 2014 at 8:06 PM
    TRDWEST
    Tucson, AZ Area
    Just to be sure too please double check it is not a freeze plug heater and also let the dealer know the block heater is for a 2014 tacoma 4.0 because the part number is different than all the other years
  4. Sep 9, 2014 at 10:40 AM
    Gerrrr
    Jeremy
    Ottawa, Canada
    Here's the scoop
    According to the local dealer, both the 13 and 14 use the same part. I had him verify that the numbers were the same. It is the kit with the socket that is installed by the fog light etc.
    P/N PU140-00911
    $160 CAD for the part
    $340 CAD for install
    From what I can see, there are 50 different part numbers and configurations for the block heater, crazy.
    Edit:
    I also got a price of $316 for part and install at Kingston Toyota, they claim 1 1/2 hour of labour.
  5. Sep 9, 2014 at 2:43 PM
    TRDWEST
    Tucson, AZ Area
    Hey gerrrr I really appreciate the help, are you willing to make a transaction and also shipping to the states?
  6. Feb 7, 2015 at 10:22 PM
    danthemgman
    danthemgman New Member
  7. Dec 7, 2015 at 4:48 AM
    aktaco14
    aktaco14 New Member
    2014 Tacoma Sport 4x4
    Rigid Industries 20" E2 Light Bar Tekonsha Trailer Brake Controller Block/Battery Heater
    Huge shout out to Thumper. I was at my wits end trying to get that stupid bolt undone. I tried from underneath, I tried from on top...I tried staring at it, hoping my Jedi powers would loosen it...I was ready to toss in the towel and take it to the stealership. Taking off the tire worked great though and made the job much easier. I didn't have a 4-wheeler winch so I set up my socket with the handle pointing downward and used a bar and rubber mallet to shwack it couple times. After the bolt broke loose, it was smooth sailing. The heater install took more time than was expected (about 2 hours with included lunch break), but was super easy after taking off the wheel. Now to figure out what my next mod will be...
  8. Mar 7, 2020 at 12:12 AM
    Skawdee
    Skawdee SKOL Vikings!
    Star Valley, Wyoming
    2009 Tacoma TRD-Offroad, 6-spd Man.
    Old Man Emu 2.5” Full Suspension Lift w/ Wheeler's Off-Road Progressive Leaf Pack JBA Upper Control Arms Moog Lower Control Arms Victory4x4 Strike Front Bumper w/ Grill Tubing Morimoto XB Headlights Baja Designs Squadron Sport Amber Fog LED’s Baja Designs 20” White LED Light Bar Over-sized BFG All-Terrain Tires K&N Stock Replacement Air Filter Pioneer AVIC-W8400 Head Unit Apple TV Wireless Phone Charging Pad Bed rail mounting with ax, shovel, MaxTrax Bed Extender
    Hey guys. Sorry for bringing this thread back, but thought I'd just add to it with my experience:
    I bought my 2009 TRD OR brand new in 2008 and had the dealer put the heater in.
    (RANT ALERT!!: I still have the paperwork for that and they actually charged me a couple hours labor AND coolant! You don't need to drain the coolant because this cartridge simply slides into the hole on the left-rear part of the block that is designed for it!)
    Anyway, I tested the cord that came with it and it isn't registering any resistance so I believe the cord is bad, or maybe both the cord and element. I ordered a new one ( https://www.amazon.com/dp/B004IHLY3I?psc=1&ref=ppx_pop_dt_b_product_details), but even though Amazon and KAT'S state the 11813 part # is correct, it is NOT the correct item after attempting to install it just about an hour ago. That part is for the 3rd Gen's. The difference between the two is that the KAT'S KH11813 is a complete cylinder while the OEM part has a flat edge cut into the length of the cylinder.
    For my 2009 TRD OR 4.0L, made in Canada and bought in UT, the correct part # is: C0140-00889
    Toyota Canada part number: PU140-00902
    Toyota U.S.A. part number: 00113-00213-00902
    (previous part #:00213-00889 or 00213-00885 or 00213-00900)
    So what this boils down to for me, now, is I have to return my Amazon order of the 11813 and then go into town tomorrow to see if Napa carries a replacement for my OEM heater. They DO have the cord, which I may try and see if that lights up my old element plug. We shall see...
  9. Mar 7, 2020 at 2:37 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Why would you expect the cord to have resistance? That makes no sense to me. It’s a conductor.
  10. Mar 7, 2020 at 9:11 AM
    Skawdee
    Because if you do a resistance test (Ohms setting at 200, which is also testing continuity on some multimeters) through the entire copper line from end-to-end of the wire loom, you should get some kind of resistance and a low-value reading, which I do get on the new wiring. But if you don't get any reading at all, then that means you have a disconnect somewhere along that line because the red and black probes can't communicate and the multimeter will simply do nothing.
    tacoman45 and 4xdog[QUOTED] like this.
  11. Mar 7, 2020 at 9:24 AM
    4xdog
    Santa Fe, NM
    OK -- so you're saying you don't have continuity in your supply line? Why not say it that way! Many multimeters have a audible tone setting for that -- usually no need for checking for *very* tiny resistances.
