2012 Tacoma won't disengage from 4w drive
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bugaboocaillier, Feb 28, 2013.
  1. Feb 28, 2013 at 9:14 PM
    bugaboocaillier
    bugaboocaillier [OP] Member
    J
    Tacoma
    We have had the truck for 6 months and use the 4w drive function often. As we get snow from October on- It get used quite often.
    We ahd a snow storm today of 30cm + anyways we cannot get it out of 4W low back to 4h or 2 W. We have tried everything in the manual, including trying to reverse) Help? We will ahve to bring it in to the dealer in the morning as driving under 30km/hr isn not an option. Is there any ideas as to what would cause this? Or any extra tips that can be applied
  2. Feb 28, 2013 at 9:52 PM
    sde780
    sde780 Well-Known Member
    Put in neutral, stop truck, push and turn to 2wd doesn't work?
  3. Feb 28, 2013 at 9:54 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    It's gotta go back into 4H before 2H.
    OP have you tried turning slightly one way or the other while driving forward or backwards?
  4. Feb 28, 2013 at 10:11 PM
    sde780
    My mistake :)
  5. Feb 28, 2013 at 10:21 PM
    JT Class
    JT Class Can't spell class without...
    JT
    Sept-Iles, Canada
    09 DC TRD Sport
    Aries bull bar, Tonneau pro box cover, TrailFX hood deflector, Sleeper lids, US Speedo speedometer gauge (white), more to come...(3incher bilsteins 5100+f/coils+aal w/285 or 265?)
    I believe your tires need to have decend traction to switch back, try looking for a dry spot of road, stop but in reverse then fwd then try switching. Happened to me earlier this year during a snow storm. I got angry reved in neutral a bit (not too much) then put her in reverse. Instantly heard it un-lock. Of course i wouldnt recommened doing this 50 times, but gets ya out of a sticky situation or less of.
  6. Mar 1, 2013 at 5:44 AM
    bugaboocaillier
    J
    Tacoma
    Thanks for the input. We tried switching from 4W low back to 4 W high as suggested in neutral, Considering we have had the snow..the roads are still not very clear, to try and shift on dry spot on the road.We even tried the reversing, it is still stuck. We orginally had it in 4W high but when it woudlnt disengage back to 2w after reversing and all the tricks in the manual, we thought to try engaging in 4 low which it shifted, no problem but now thats why its now stuck in 4w low. It has been towed to the dealer. I just hope its covered under the warranty, as the toyato assistance mechanic tried and it still wont disengage
  7. Mar 1, 2013 at 5:52 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Mine did that 2 or 3 times when it was new the only way I was able to get it to work was to remove the battery cable then replace it dealer played with could not find any thing. It would not come out of 4X4 no matter what I tried and it has never done it since got about 30K on it now.
  8. Mar 1, 2013 at 5:55 AM
    bugaboocaillier
    J
    Tacoma
    Good to know, but I still have at least 20K to go before I hit 30 . LOL
  9. Mar 1, 2013 at 6:12 AM
    bluedust
    bluedust Well-Known Member
    Patrick
    Pittsburgh
    '12, Access, TRD, Off Road, ,
    Wet Okole Seat Covers, Charcoal & Black "TRD" stiching Stuby Ant., Husky Mud Guards WeatherTech Floor liners
    So, my 4x4 low red light comes on last night, without me engaging the system.
    It's still flashing this morning, tried to switch to 4x4 high and low but no good still flashing.
    Called Dealer and they can't see it till Monday.
    Any issues with me continuing to drive it, and is there anything I can do till then?
    Just thought I'd put the question out there,,,
    Would of, Could of, Should of, because if your Aunt had balls she'd be your Uncle
  10. Mar 1, 2013 at 6:40 AM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    ^^^ If it is not in 4wd, you should be fine to drive it.
  11. Mar 1, 2013 at 7:23 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Red 4x4 light ? I am guessing you pressed locker button by accident.
  12. Mar 1, 2013 at 7:46 AM
    bluedust
    Patrick
    Pittsburgh
    Hmm?, not like I 've never done that before.
    Should have a cover on the switch, like you would see covering a rocket launcher or something.
    But that's never done anything before, service guy said something about the system just locking everything out,?
    I will double check that, just in case.
  13. Mar 1, 2013 at 10:03 AM
    Brandon9402
    Brandon9402 uncoordinated dirtbox
    Brandon
    Mississippi
    02 prerunner sr5
    Kenwood headunit, 4 kicker 5x7 coaxials,2 memphis 1.5" tweeters, 2 12" memphis subwoofers, memphis 500w amp, chrome grille guard, kc fog lamps, chrome side steps, chrome tool box, and window visors
    I don't see a problem with it being stuck in 4wd. thats your truck telling you it wants to get down and dirty!
  14. Mar 1, 2013 at 12:23 PM
    bluedust
    Patrick
    Pittsburgh
    Huh, so when I drive around with the locker button engaged the 4x4 red light blinks.
    Because that's what happened, none of those buttons light up when they are pushed in.
    Must have turned the fogs on didn't realize I pushed the locker switch, and the truck was trying to tell me something was wrong.
    Maybe there is a mod out there, where a hand comes out of the dash slaps me up side the head, and gets my attention!
  15. Mar 1, 2013 at 12:38 PM
    bugaboocaillier
    J
    Tacoma
    So apparently the switch is fubbarbed, and a new one is being put in as we speak.
  16. Mar 5, 2013 at 6:44 AM
    bugaboocaillier
    J
    Tacoma
    The actuator switch was faulty/ broken. They literaly had to use a hammer underneath the truck to manipulate it out oof 4W drive
  17. Mar 5, 2013 at 7:40 AM
    majorhavok
    majorhavok Rabid Conservative
    Mike in Cali..
    Peoples Republic of Caulifournia
    '13 TRD Sport DoubleCab 4x4
    Ultragauge, ImMrYo mirror, Tailgate lock, Snugtop Rebel Shell.
    Mechanics applying a hammer to truck? :eek:
  18. Mar 5, 2013 at 3:05 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Does seem a wee bit suspicious hammer blows were needed to disengage what electrical current should. If it was truly just the switch, then simply replacing the switch and USING it should have disengaged the 4WD.
    I'm wondering where the hammer blows were directed and what type of hammer.
  19. Mar 6, 2013 at 5:35 AM
    bugaboocaillier
    J
    Tacoma
    While im not a mechanic, I know it wasn't a regular hammer. Unfortunetaly they did not have the switch in stock to replace it right away. We are still waiting for the part and hence have a loaner . We were told something about the "solenoid" is being replaced as well.....Again its all covered under the warranty. Thank god.
    BTW, we live in the north, so winter is not over for at least another month, and since my hubby is in the trades field - we do use the 2w- 4w quite often.
  20. Mar 6, 2013 at 5:38 AM
    bugaboocaillier
    J
    Tacoma
    The transfer case is fine, and they were able to tell the "shifting" for 4w is broken in nicely...LOL ( Considering since we have had the truck) 75% of the time its in 4w Drive. ( let me tell you it loves the gas in 4W)
