2012 Tocoma AC only run on high
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tocoma561, Jun 27, 2022.
  1. Jun 27, 2022 at 12:32 AM
    Tocoma561
    Tocoma561 [OP] New Member
    2012 Tocoma
    Mag Wheels
    So my AC only runs on high, I'm thinking it's a relay. Anyone has had any issues with AC running on high only?
  2. Jun 27, 2022 at 12:58 AM
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    If it's AC that only runs on high, relay. If your blower motor fan only runs on high, resistor is to blame - commonly on the firewall. Check fuses of course, but it's unlikely.
  3. Jun 27, 2022 at 1:04 AM
    2017_TACOMA_LIMITED
    2017_TACOMA_LIMITED Well-Known Member
    2019 Pro/2017 Limited/2014 Limited
    I had the same issue a few years back with my wife’s 2014. I researched it on here and found that I needed to check a wiring harness under the glove box. I checked, and found a black arc spot after unplugging it. I believe the new harness was around $30 at the time. Toyota wanted to charge 2 hours labor to replace. I was able to do it in 40 minutes.
  4. Jun 27, 2022 at 1:55 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Here is the service bulletin with instructions and part numbers you will need:
    Jimmyh likes this.
  5. Jun 27, 2022 at 6:38 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    You can usually just clean those dirty contacts. They look burned but probably really aren't and the resistor is also probably fine. Scrape 'em out with a small screwdriver and you'll be back in operation in no time. If that doesn't work, or if the wires are really burned, then replace the resistor and connector with the upgrade parts. I have those in my parts bin if and when I need them. But the cleaning was all mine needed, at least for now.
  6. Jun 27, 2022 at 8:22 AM
    taco912
    taco912 Well-Known Member
    North of the Bridge
    2006 AC 4.0 AT 4x4 SR5 TRD OR
  7. Jun 27, 2022 at 8:27 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Literally did this yesterday, noticed my blower started only working on high, pulled the resistor, definitely got hot on one pin (slight discoloration on the plug and wire), pulled the pin out and bent the tab that contacts the resistor so it pushes on it harder to make better contact. Not sure how long it will last, but those tiny pins cant handle the extra heat + current. Ill do the upgrade to the square style plug resistor when I get the chance when if fails again.
