2012 Toyota Tacoma 4x4 Off Road RR Differential will not engage
Discussion in 'Technical Chat' started by Rick2018, Feb 10, 2018.
  1. Feb 10, 2018 at 11:52 AM
    Rick2018
    Rick2018 [OP] New Member
    I am looking to buy a 2012 Toyota Tacoma 4WD Double Cab w/Off Road package.
    When I put the vehicle in 4L, the icon flashes and then remains on as it should. When I engage the rear differential lock the icon will flash, but never remains on. The vehicle is running and in neutral. The RR lock has probably not been engaged in a while, if ever. The seller doesn't know. Personally, after looking the vehicle over, I don't think the truck has ever been off road. I know, like old locks, if not operated over a long period, it will not function. Anyone have any other suggestions. Beautiful truck, 63k miles.
  2. Feb 10, 2018 at 12:03 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Did you try to make sharp turns ( on dirt)? Sometimes moving and turning helps it engage.
  3. Feb 10, 2018 at 12:07 PM
    Rick2018
    Haven't tried that. Waiting for rain to stop.
  4. Feb 10, 2018 at 12:11 PM
    koditten
    Kirk
    Central Michigan
    You do know you don't want to engage the four wheel drive or axle lock while on pavement? It's not good for the drive train.
  5. Feb 10, 2018 at 12:13 PM
    Rick2018
    Hey that worked. Thanks koditten.
  6. Feb 10, 2018 at 12:15 PM
    koditten
    Kirk
    Central Michigan
  7. Feb 10, 2018 at 2:59 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    You can engage locker on pavement to test. Just don’t turn but a little bit to get the locker to chooch. Then go straight only and disengage soon.
