2012 TPMS light Disabled
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vigo, Jul 1, 2013.
  1. Jul 1, 2013 at 7:39 PM
    Vigo
    Vigo [OP] WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    First off, I've spent hours searching and sifting through bs on this site and still couldn't find the answer as to if this could be done on a 2012 model. This is to give others a definite answer. So keep the bs out, start your own thread.
    No boobie pics , or just make a canister or use the spare tire, or buy aftermarket, etc...
    To get the light to turn off, you get to the TPMS plug behind the stereo. Cut the blue wire, attach the wire harness side in-line with the red wire with white stripe. I taped up the other end of the blue wire, reinstalled in the wire loom, secured it with tape, and plugged it back in. The system is still on, but the signal to illuminate the tpms is disabled.
    Attempt at your own risk.
    From the info I gathered, the blue wire gong into the wire harness is the signal to the ecu/gauge cluster. The red/white wire supplies a 5v dc + to turn the light off. So it doesn't matter what the tpms computer is reading, the light is disabled with the system still on. Its been over a week since I did this and no problems whatsoever. (edited 7/2/13)
    Stereo and surround removed for easier access.
    Behind where the climate controls were, you can see the blue TPMS box, which the plug has been already removed.
    The blue wire is cut, the harness side is connected in-line with the red/white wire. I later taped the other side of the blue wire coming from the plug. Reinstall plug into tpms box and reinstall everything.
    I've received so much help from this site, hopefully this helps out someone else! Good luck!
    MtnClimber, deeezy, Taco 422 and 19 others like this.
  2. Jul 1, 2013 at 8:44 PM
    Commanderwiggin
    Commanderwiggin Well-Known Member
    Calgary
    12 Tacoma D/C 4x4 TRD Sport 6MT Supercharged
    What's the point of this? I've never had an issue with my TPMS...
  3. Jul 2, 2013 at 2:42 AM
    Vigo
    Vigo [OP] WFO
    '12 4 door
    stuff...
    In my case, I gave my dad my one month old stock set, so he didn't have to buy new tires. I installed a set of wheels and tires without tpms sensors. So this is to get rid of the dummy light. I check tire pressure often to ensure the longevity of my MTZs anyway.
    Some people put the sensors in a pressurized pipe, or the spare, and I think its ridiculous. Also the battery life in the sensors are for 7-10 years so eventually everyone is going to run into problems with the system. I figured I'd just get rid of it now.
    stonybrook, Hayrider and techbill like this.
  4. Jul 2, 2013 at 3:45 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    TPMS is just another knee jerk reaction by our govt. that adds to the cost of our vehicles. I see idiots every day driving on low tires. System was required after all the Explorers flipped. I would disable on a heartbeat if it was easy to get to.
  5. Jul 2, 2013 at 5:34 AM
    2006KJ
    2006KJ Well-Known Member
    Front Royal VA
    Wish I saw this a month ago before I bought used sensors and made a PVC container to put them in. Granted that its working very well... This would've been a much cheaper and fool proof fix
  6. Jul 2, 2013 at 6:19 AM
    Raoul Duke
    Raoul Duke Well-Known Member
    CJ
    Vancouver, Canada
    TRD O/R Pyrite
    retrofit/bhlm, CB, System, color match grill, debadge, TRD wheels
    +1 OP! i'm getting sick of looking at this light on my 2013!!!
    do you know the function of those two wires?
    are you grounding the blue wire or giving it 12v?
  7. Jul 2, 2013 at 7:15 AM
    TR90125
    TR90125 Well-Known Member
    North Texas
    2013 DCSB TRD Sport
    Bone stock for now....
    Good thread. Even if I don't get a second set of wheels/tires I will probably do this mod. Hate all TPMS systems.
  8. Jul 2, 2013 at 12:33 PM
    Vigo
    Vigo [OP] WFO
    '12 4 door
    stuff...
    First post will be updated with this info.
  9. Jul 2, 2013 at 4:19 PM
    Raoul Duke
    CJ
    Vancouver, Canada
    TRD O/R Pyrite
    Just did this mod, worked great, thanks so much OP!! This should be in the cheap free mod section for sure!!!
    007fodo likes this.
  10. Jul 3, 2013 at 1:42 AM
    Vigo
    Vigo [OP] WFO
    '12 4 door
    stuff...
    Glad I could help someone else out!
  11. Jul 3, 2013 at 4:52 AM
    2006KJ
    Front Royal VA
    Should at least be a sticky In the tire/wheel section. Or added to the TPMS sticky already there
  12. Jul 3, 2013 at 6:05 AM
    Raoul Duke
    CJ
    Vancouver, Canada
    TRD O/R Pyrite
    :facepalm:
  13. Jul 3, 2013 at 6:22 AM
    Raoul Duke
    CJ
    Vancouver, Canada
    TRD O/R Pyrite
    this has been done to death on other threads.
    the type of people who drive with low air pressure in their tires areprobably not the people who are reading forums about how to disable a TPMSlight. this safety feature serves a purpose for people who use their vehicle solelyas a means of transportation and have no intention of doing any of their own maintenance.
    a TPMS serves no purpose to anyone who seriously offroads, constantlychanges tire pressures for different scenario, or has multiple wheel sets
    there is no need for a switch, however it would be a good idea to reattatch the wire as it was if you were to sell you truck. just my opinion
  14. Jul 3, 2013 at 6:48 AM
    Raoul Duke
    CJ
    Vancouver, Canada
    TRD O/R Pyrite
    touche :duel:
    I change my tire pressure enought that I have no use for it but you make a valid point.
  15. Jul 3, 2013 at 8:18 AM
    Raoul Duke
    CJ
    Vancouver, Canada
    TRD O/R Pyrite
    i wish there wer more spots for all the switches needed in these trucks
    1 for 2lo mod
    1 for ABS kill
    1 for locker anytime
    1 for rear view any time
    1 for OEM heated mirror
    1 for TPMS now
    AHHH
    Greenbean likes this.
  16. Jul 3, 2013 at 8:57 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    Good info. Just make sure to re-enable before selling as disabling light is not permissible.
    My reason for using the canister is that once I sell my truck I will have to make my system work again. I either pay for alloy sensors now or when I swap tires years from now when I sell it. Everyone will have their reasons. I will do this if my batteries die before I sell. Thanks!
    Rambo54 likes this.
  17. Aug 8, 2013 at 12:49 PM
    Haws
    Haws Well-Known Member
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    I did this today in my 2010 and it works great! Now I can run lower pressure in my tires without that dang light on all the time. Just make sure your wires make contact in the splicer or it wont work......
  18. Aug 8, 2013 at 4:12 PM
    tfeltz73
    tfeltz73 That's greasy Ricky
    central Wisconsin
    2013 supercharged long travel thing
    I might try this because my new rims and tires have the tpms but I can't get the light to stay off no matter what pressure I put in them
  19. Aug 18, 2013 at 12:10 PM
    SamSin
    SamSin I can resist everything except temptation
    Jersey Sam
    NJ
    Longbed 4x4 SR5
    Oil Free AFE Pro Dry S Air Filter, Nitrogen filled tires, Tonno Pro Tri-Fold Hard Tonneau Cover BLU Logic Handsfree
    My TPMS would not go out no matter what I did, as for the same reason tfelz73 described and I was ready to cut the wire as VIGO described. I figured I would give it one more try as a last resort. It might be worth a try before taking the dash apart.
    1. Turn the ignition on, push the TPMS switch until the light goes out.
    2. Turn the ignition off
    3. Turn the ignition back on and hold the TPMS switch until the Tire Pressure light flashes 3 times and shut the ignition off again.
    My TPMS light would come on exactly at 2 miles every time I reset the switch for over a year. I drove for 10 miles after doing the above and it did not come back on since the reset. :kona:
  20. Aug 18, 2013 at 12:49 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    This I shall try!!!
