2012 TPMS light Disabled
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vigo, Jul 1, 2013.
  1. Sep 12, 2013 at 6:44 PM
    #41
    SamSin
    SamSin I can resist everything except temptation
    Jersey Sam
    NJ
    Longbed 4x4 SR5
    Oil Free AFE Pro Dry S Air Filter, Nitrogen filled tires, Tonno Pro Tri-Fold Hard Tonneau Cover BLU Logic Handsfree
    I'm not sure why :(
    After the light flashes 3x did you switch the ignition off and restart the vehicle?:confused:
  2. Sep 12, 2013 at 6:52 PM
    #42
    SamSin
    Jersey Sam
    NJ
    Longbed 4x4 SR5
    TREAD Act of 2000
    The TREAD Act was passed in the fall of 2000 following the Ford/Firestone crisis. Congress wanted to make tires safer for the motoring public. The TREAD Act has nine components that affect the tire industry.
    Ø Tire testing standards
    Ø Tire labeling requirements
    Ø Tire Pressure Monitoring Systems
    Ø Early warning reporting system
    Ø Safety recalls in Foreign countries
    Ø Sale or lease of recalled ties
    Ø Reimbursement prior to recall
    Ø Acceleration of recall
    Ø Disposal of recalled tires.
    Tire Pressure Monitoring Systems (TPMS)
    The TREAD act requires the installation of tire pressure monitoring systems that warn the driver when a tire is significantly under-inflated. It includes all passenger vehicles with a gross vehicle weight of 10,000lbs or less. That includes almost all Passenger and Light Truck vehicles with the exception of vehicles with dual rear wheels. The TREAD Act is very specific in that a TPMS system need only warn the driver in the event that a tire is determined to be significantly under-inflated. According to the specifications of the Act, this could mean a tire would need to be under-inflated by as much as 25% before the TPMS telltale would alert the driver. The current TPMS mandate applies only to passenger cars, SUV's, vans and Light trucks below 10,000 lbs GVW. However a ?phase II? ruling covering vehicles heavier than 10,000 lbs is already in the works. Although the current mandate began with 2004 model year vehicles, TPMS systems were first seen in the US on some 1997 vehicles. Regardless, by September 1st 2007, all vehicles sold in the US must have tire pressure monitoring systems.
    See the final legislation here:
    http://www.nhtsa.gov/cars/rules/rulings/TPMSnprmPost2Cir/TPMSnprmPost2Cir.html
    http://summittire.com/?PageData=59921
  3. Sep 15, 2013 at 7:03 PM
    #43
    Greenpants
    Greenpants Well-Known Member
    Massachusetts
    2009 4x4 Tacoma 4 banger
    The tailgate mod
  4. Sep 15, 2013 at 7:10 PM
    #44
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^FYI Toyota stopped putting TPMS sensors in spare tires from 2008 onwards.
  5. Sep 17, 2013 at 9:55 AM
    #45
    SamSin
    Jersey Sam
    NJ
    Longbed 4x4 SR5
    Greenpants, just by an off chance did you buy your truck new? If not, is it possible if the rims were changed there are no tire sensors which is why the dash light will not rest?
  6. Sep 17, 2013 at 12:34 PM
    #46
    Greenpants
    Massachusetts
    The tailgate mod
    Yes , I did buy it new. I will try again though. It is starting to make me crazy. Thanks for the encouragement.
    greenpants....mike
  7. Sep 17, 2013 at 1:58 PM
    #47
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    How long do the batteries last,
    I wonder if the folks at a Discount Tire would be nice enough to "scan" or "listen" to your valve stems for the TPMS sending it's data to the receiver. With the handheld unit they have to identify them,
    You have been through the loop with this bro, :(
    My money is on a sensor is dead,
  8. Sep 17, 2013 at 2:23 PM
    #48
    Greenpants
    Massachusetts
    The tailgate mod
    I do not have sensors in my wheels .I thought there was on in my spare tire. Guess the 09s don't. So I do not have a way to turn off the dash light . I just put some black tape over the TPMS light. I am done with it !thanks to all you guys for the help.
    greenpants....mike
  9. Sep 17, 2013 at 3:24 PM
    #49
    Greenbean
    Zack
    Western NC
  10. Sep 17, 2013 at 6:52 PM
    #50
    SamSin
    Jersey Sam
    NJ
    Longbed 4x4 SR5
    Over & Out Greenpants, sorry it didn't work for you.
  11. Sep 20, 2013 at 2:40 PM
    #51
    Flynbyu2
    Flynbyu2 Start every day with a smile and get it over with
    Ron
    Folsom, CA
    '10 Tacoma Sport
    The TPMS light on my 2010 DCSB has been on for the last month.
    Finally, I took it to Les Schwab to get the bad sensor(s) replaced.
    The tech came in after about 30 minutes and said he was able to reset them with his computer and the light was now off.
    This next part is what shocked me the most; the tech then stated.
    "By the way, there's no charge today, just think of Les Schwab next time you need tires."
    You know I will!
  12. Oct 6, 2013 at 6:05 AM
    #52
    902taco
    902taco Active Member
    JG
    Dartmouth, NS
    07 4x4 AC SR5 6-speed
    K&N CAI, Bilstein 5100s, PIAA 540 driving lights, American Eagle 146 16x8x5.50 wheels, ECGS front diff bushing
    Thank you VIGO for the write up on how to disable the TPMS light. My winter wheels don't have the sensors in them and the TPMS light stays on which is a nuisance. I think I'll try this and install a switch.
  13. Mar 4, 2014 at 1:30 PM
    #53
    dakidz
    dakidz New Member
    Just want to say "Mahalo" for the info on how to disable the TPMS light for my son's 2014 Tacoma!
  14. Mar 4, 2014 at 1:54 PM
    #54
    crazy joker
    crazy joker Well-Known Member
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    Real men just call it camping
    Sub'd in case the system ever has a problem on my truck. I like the system just fine, I guess, but not enough to pay anything to fix it. Thanks for the write up.
  15. Jun 17, 2014 at 3:37 PM
    #55
    wobble
    wobble Well-Known Member
    Ridgefield, WA
    2014 TRD OR
    Modified RCD Lift, 315/70R17 STT Pros
    Thank you for this. Super easy 20 minute mod and no more light. I was going to do the pipe mod, but this is so much quicker.
  16. Jul 26, 2014 at 12:29 PM
    #56
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Just did this on my 09 seems like it works, no light.....what a pain in the dick to get that thing plugged back in tho
  17. Aug 19, 2014 at 2:13 PM
    #57
    remery829
    remery829 Well-Known Member
    Eastern NC
    '14 DCSB TRD Offroad
    Some stupid expensive stuff
    Sub'd cuz I'm not putting sensors in my sr8s
  18. Aug 19, 2014 at 2:21 PM
    #58
    Aw9d
    Aw9d That one guy
    I'd personally just take out the gauge cluster, then remove the LED for TPMS. Problem solved. Would take about 30 minutes to do.
  19. Oct 30, 2014 at 4:50 PM
    #59
    loco
    loco Who wants to ride my Brack Burrito???
    Phil
    Virginia Beach, VA
    1996 Diesel Land Cruiser AKA Brack Burrito
    Well its a land Cruiser with a diesel so I've got that going for me.
    Did this today. Works like a champ! Great Job OP!
  20. Oct 31, 2014 at 12:03 PM
    #60
    SR5808
    SR5808 Well-Known Member
    J10
    Honolulu,Hi
    Black Prerunner SR5
    Tint/ weathertech visors/ truxedo tonneau cover/ color matched front emblem and door emblems/ Clazzio Leather seat covers/debaged tail gate/depo black tail lights/color matched front grill/led headlights/ Pioneer Avh-5800/ Alpine Type R Front and Rear speakers/ Alpine Pdr-v75/ JL audio 10tw3/ Mr. Marv Custom sub box/amp rack/ Stealth Custom Series Stealth 6 17x8.5/ 265/70/17 Nitto terra grapplers...
    Does this method work on a 2013?
