2012 Upgrading speakers
Discussion in 'Audio & Video' started by fadippides, Jan 2, 2012.
  1. Jan 2, 2012 at 4:02 PM
    fadippides
    fadippides [OP] Well-Known Member
    NEPA
    12 TRD Off Road
    Does anyone know what power the 2012 non jbl head unit puts out? I would like to upgrade the sound by changing the speakers and keeping the factory look/BT/XM.
    I am looking to get speakers with a range of 2-30 [ or 50] RMS and hoping I can get by without an amp (or the stereo cutting the bass). There are some excellent threads showing how to install the speakers on here and I follow that as the steps shouldn't have changed too much for the 2012's.
  2. Jan 2, 2012 at 4:43 PM
    lbridges
    lbridges Well-Known Member
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    Every relatively recent (last decade) factory unit (without an external amp) I've ever seen tested produced between 13 & 17 Watts per channel. While I've not seen a 2012, the 2011 non-JBL was in this ball park.
  3. Jan 2, 2012 at 4:53 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    For what it worth, I've replaced both, head and factory speakers, but not at the same time. I think the biggest difference was the head unit, not speakers. Now don't get me wrong, the speaker swap made a huge difference. The factory speakers made me laugh when I saw how flipping cheap they were.
  4. Jan 2, 2012 at 5:05 PM
    fadippides
    NEPA
    12 TRD Off Road
    Did you have any problems with getting the factory bluetooth to work? Thats my main reason for sticking with factory
  5. Jan 2, 2012 at 5:11 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    If you want to stick with factory head unit a 50 rms speaker will be fine but if you want it to be louder look for something with a high sensitivity say ~100 Db and I'd suggest that you add something like a JL Audio CleanSweep aka a line out converter because even if you don't add a amp your after market speakers should still be able to handle most of the bass in a song decently.
  6. Jan 2, 2012 at 6:53 PM
    t4daddy
    North Alabama
    I'm a total dumb ass, the Pioneer AHV 3200BT (blue tooth model) was $50.00 dollars more than than the 3200DVD, and I didnt opt for it. Regreted it ever since.
  7. Jan 2, 2012 at 6:55 PM
    t4daddy
    North Alabama
    I thought a low sensitivity speaker was more efficient, needed less power to perform.
  8. Jan 2, 2012 at 6:59 PM
    Warhorseforever
    Will
    Sand Lapper
    Nope higher the sensitivity the louder it will get with any given amount of power.
    Crutchfield is the place to go for audio information.
    :thumbsup:
  9. Jan 2, 2012 at 7:00 PM
    XJBaylor
    XJBaylor Well-Known Member
    Keith
    Plano, TX
    06 DCLB TRD Sport 4x4
    King coilovers with remote reservoirs, Deaver 12 leaf pack with 5100's, TRD exhaust, Kenwood 6160, Anthracite Sport Wheels
    It is the opposite. A high sensitivity speaker is more sensitive to power, and will provide more db per watt of power applied.
  10. Jan 2, 2012 at 7:05 PM
    t4daddy
    North Alabama
    Not sure WTF I'm thinking. I had it in my head the other way for some reason.
  11. Jan 2, 2012 at 7:14 PM
    Warhorseforever
    Will
    Sand Lapper
    Ha happens to me all the time don't worry about it.
  12. Jan 2, 2012 at 8:19 PM
    t4daddy
    North Alabama
    Worry about what??
  13. Jan 3, 2012 at 5:36 AM
    XJBaylor
    Keith
    Plano, TX
    I'm quite certain he was referring to this...
  14. Jan 3, 2012 at 11:01 AM
    Warhorseforever
    Will
    Sand Lapper
    About getting things mixed up it happens.
  15. Jan 9, 2012 at 7:03 PM
    Wizzard005
    Wizzard005 Well-Known Member
    Greg
    Sacramento, CA
    Stock
    FYI Front Doors are X-OVered , not sure where it is, but there is one, going to make it a bitch to upgrade your front speakers.
    I learned the hard way with my Entune system..
