2012 Weathertec Digital Fit Matts Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaIan, Dec 25, 2012.
  1. Dec 25, 2012 at 6:33 PM
    TacomaIan
    TacomaIan [OP] Well-Known Member
    Ian
    Alberta Canada
    2016 Canadian Limted
    I got a set of Black weathertec Digital Fit matts for my 2012 Tacoma today and they have spots for the little studs in the floor that lock on the OEM matts. Has anyone else found the holes in the Weathertec do not match the floor? There moulded to fit the vehicle but the studs do not match up with the holes in the matts?
    Anyone else have a set for their 2012?
  2. Dec 25, 2012 at 6:38 PM
    Badgtho
    Badgtho Well-Known Member
    Ben
    CT
    '13 TRD sport 6spd
    TRD exhaust, TRD beadlock wheels, moto xtender
    I have a set in my 13. My brother has them I his 12.
    No such issue for us.
    Do you have an 05-11 set?
  3. Dec 25, 2012 at 6:58 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater,FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x9 Fuel Krank wheels, 35x12.50 Cooper Discoverer STT, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    I got a set today too for my '12, front & rear & had no problems. Like badgtho said did you get a set for 05-11?
  4. Dec 25, 2012 at 7:01 PM
    joeyha
    joeyha Well-Known Member
    Joey
    Canmore
    12 DCLB TRD
    No problems with my 2012 "Canadian" DCLB TRD either...
    Where in Alberta are you?
  5. Dec 25, 2012 at 9:24 PM
    TacomaIan
    Ian
    Alberta Canada
    Edmonton
  6. Dec 25, 2012 at 10:42 PM
    dragnet
    dragnet Member
    Tim
    '11 Prerunner Sport Barcelona Red
    I would guess it's either the wrong model year mat, wrong cab style, or you might have the clips flipped the wrong way?
  7. Dec 26, 2012 at 4:15 AM
    Badgtho
    Ben
    CT
    '13 TRD sport 6spd
    Can't be the wrong cab style - all cab styles use the same front mats.
    In terms of flipping the clips I found it literally impossible to install floor mats improperly.
    They're the wrong mats.
    OP: what part number is on your front mats?
  8. Dec 26, 2012 at 12:25 PM
    krob32
    krob32 Well-Known Member
    Kelly
    Ft. Knox, KY / Asheville, NC
    2012 MGM TRD Sport DCLB
    WeatherTec Digi Liners, AVS Bugflector II, TRD FJ SE Anthracite Rims, Goodyear DuraTrac 265/75/16, AVS In-Channel Wind Deflectors, Extang Solid Fold, Pop & Lock, Color Match Grill Emblem (Anthracite), Plasti Dip Emblems, Tacoma Bed Mat, Tacoma Door Sill Protectors, ToyTec Ultimate Lift Kit, ICON UCAs, Wet Okoles, Sockmonkey 3rd Brake Light Cover, LED Hood/Bed Lighting w/ OTRATTW Switches, Famous Fabrication Sliders, Sockmonkey TRD Bed Decal, Proven Design 4x4 Mudflaps, BenWA's Rear Power Sliding Window, Jasper Off Road 6" Reverse LED Pod, ImMrYo Rear View Mirror Bracket, GrillCraft w/ Black Mesh and color matched Land Cruiser Emblem, LED Tail Lights, Badge Removal and Vinyl TRD/Tacoma Stickers, Bullaculla Trailer Harness Relocation.
    First and most functional mod. Fit like a glove. Contact where you purchased from and explain issue. I'm confident they will assist you. Sounds like wrong model year as stated above.
  9. Dec 26, 2012 at 12:33 PM
    MUDFISH
    MUDFISH Well-Known Member
    Syracuse
    12 Double Cab SR5
    I used to have an '09, sold it, and now I have a '12...
    I kept the same digital fit mats, and I can tell you that the mats are contoured to fit exactly the same, but the clips are in different places. It sounds to me like you have a set built for the 05-11's...
  10. Dec 26, 2012 at 1:50 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I had no probs.
    What is the measurement difference of the studs and WT mat holes??
  11. Dec 26, 2012 at 4:42 PM
    surfinbum88
    surfinbum88 Member
    Randall
    Norman Oklahoma
    12 Tacoma 4x2 TSS edition
    I had problem with passenger side 2012 double cab set. See attached pics. Returned for refund. Several phones calls to weathertech but they could not figure it out.
  12. Dec 26, 2012 at 4:58 PM
    TwzteD
    TwzteD Well-Known Member
    Kyle
    St Lucie Fl
    2013 4x4 reg cab Auto
    2013 4x4 reg cab, 2011 4runner sr5 rims, 265 general grabber at2's, 5100's All 4 corners with fronts at .85, De badged, Egr Rainguards, Led tail lights, Int wipers, fog lights, Trailer Hitch, POwer locks+ keyless entry, Extang Solidfold Bed Cover, WeatherTech Mats, Stubbie Antenna, Trd Skid Plate, Tint, Scanguage, Cargo net in bed, Sound Ordnance B-8PT, FULID FILM Under Coat.
    That's incorrect the reg cab and access cabs have same front mats doubblecab is differnt, the reg and access share same part number 444521 dbl cabs have a diff part number
  13. Dec 26, 2012 at 5:06 PM
    Larry
    Larry CARL
    CARL
    this could probably been fixed with a small carpet adjustment.
    the 2012/2013 hold downs are fixed to the carpet with no side to side movement like the clips on the earlier models.
  14. Dec 26, 2012 at 7:09 PM
    surfinbum88
    surfinbum88 Member
    Randall
    Norman Oklahoma
    Edit to my previous. Looked at my receipt and the part number they shipped me is 444531 for a double cab. Made mistake saying I had 05-11 model.
  15. Dec 29, 2012 at 8:56 PM
    TacomaIan
    Ian
    Alberta Canada
    Got the right ones now but yeah the passenger side is like this, only one lock works.
  16. Dec 30, 2012 at 7:02 AM
    Badgtho
    Ben
    CT
    '13 TRD sport 6spd
    Did the OEM mats fit in your truck?
  17. Dec 30, 2012 at 9:03 AM
    surfinbum88
    surfinbum88 Member
    Randall
    Norman Oklahoma
    The OEM mats fit like a glove. I have weathertech liners in my other 2 cars and they fit perfect. Not sure why these did not fit?
  18. Jan 7, 2013 at 8:22 PM
    Checkvalve
    Checkvalve Member
    Seattle Wa
    08TRD Off Road
    Question when you order weathertechs do you get both fronts or is the price per mat? I know stupid question but I have to ask.
  19. Jan 7, 2013 at 9:13 PM
    Catman
    Catman Member
    British Columbia
    2012 MGM DCLB TRD Sport
    You order both front mats.
    I had problems with the passenger side fitment also, if clipped in, the back (towards the seat) was too far out towards the door, the mat sat crooked. Also the rears would get caught on the front seat rails when you put the seat all the way back. There are others that have had the same problem. 1 member problem solved and relocated the clips so the mat lined up properly.
    Nice mats, just didn't fit for me.....the sock mats I have (both carpet/rubber) fit perfect.
