2012 Whistling sound indentified
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Appljaxx, Nov 23, 2011.
  1. Apr 3, 2013 at 7:14 AM
    #141
    DTater
    DTater New Member
    David
    Jacksonville, FL
    13 Tacoma Quad TRD OR
    nada
    What does the new grill installed under the TSB change?
  2. Apr 3, 2013 at 9:30 PM
    #142
    firefly335i
    firefly335i Member
    ScruffyGolem6
    Austin, TX
    2013 Tacoma Sport
    Icon Stage 1 kit w/Add a Leafs, TRD Catback Exaust
    Applejax you are the man!! I totally followed your 1/4" tubing trick and it worked like a champ! Now my truck doesn't whistle like a tea kettle ;)
  3. Apr 4, 2013 at 2:26 AM
    #143
    dexzel
    dexzel TRDex
    Dexter
    Las Vegas
    2013 Dbl Cab TRD OffRoad
    Awesome Appljaxx! This worked like a charm! :yay:
  4. Apr 5, 2013 at 7:50 AM
    #144
    ja63197
    ja63197 Active Member
    12 4x4 Sport
    I fixed my whistle
    carneasada likes this.
  5. Apr 5, 2013 at 11:17 AM
    #145
    Gonzo714
    Gonzo714 Member
    Jeff
    SANTA ANA
    2017 TRD
    MESOS, KIING SHOCKS SET UP ALL AROUND, NUMEROUS DIY MODS
    I have a 2005 Tacoma which I love but ever since my truck got delivered brand new off the lot it has made this annoying noise/whistle! I can't wait to get home and try the tubing trick. Hope it works!
    Thanks
  6. Apr 15, 2013 at 4:06 PM
    #146
    zengineer
    zengineer Member
    Jerott
    Utah
    13 Doublecab 4X4 Limited
    Just bought my 13' Limited last week...100 miles on it. Whistling (sounds like it coming from behind rear view mirror) is driving me nuts!! Starts whining at about 55-60mph..Returned to dealer today, and they drove it, then taped the windshield, drove again. Then they were scratching their heads, and want it for two days. I said "gimme the keys, I'm going home". I am not leaving them my brand new truck to tear apart.
    Came home and came right here to TW. Absolutely love this thread. I'm gonna head down to the hardware store right now, and get some tubing.
    Praying to God this works! You guys Rule!
  7. Apr 16, 2013 at 5:30 AM
    #147
    ja63197
    12 4x4 Sport
    Here is how I finally fixed my whistle, I did not pay 31000 for a truck that whistled. I also did not pay for toyota, both dealer (who put a whopping 500 miles on my new truck) and there "customer service" to claim that this is not an issue. Loving the new truck though. No whistles, 26 gallon fuel tank, and 9600lb conventional towing capacity. Also, give that drip line a few months and a couple of temperature fluctuations, because the whistle will return, very slowly. Plus, who in there right mind sits back and lets this happen. Thank goodness my truck was paid off, and I only had to give 3500 cash for the sierra. Oh by the way, did I mention I have power seats, and leather? We do love our lexus RX 350, but they don't like nothing is going on when we did have one single issue.
  8. Apr 16, 2013 at 9:24 AM
    #148
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    Just use an aluminum dowel (not the tubes) in 1/4" from a Hardware store (ACE, etc) Put some Teflon lube or whatever lube you want to use on the dowel. Slightly shape it to the long curve, insert and be done. You can even round off the ends if you like. Aluminum is soft enough to make that easy and is strong, and non corrosive. As well, you can easily remove the Aluminum dowel. Tap from the other end and pull.
  9. Apr 16, 2013 at 9:36 AM
    #149
    kmk2012
    kmk2012 Member
    NorCal
    Tacoma dbl cab 4wd
    stock
    It sounds to like the windshield seal is bad in your case. Easy test, take up to whistle speed and push out around the review mirror. If the sound changes then it is the window seal. If it doesn't change it's not and tubing is the way to go. This happened on my 2012 Tacoma. Yes, they want it for a day, something to do with curing of the new seal.
    It is amazing Toyota has not acted on this longstanding and very annoying problem.
  10. Apr 17, 2013 at 10:50 AM
    #150
    zengineer
    zengineer Member
    Jerott
    Utah
    I placed a strip of blue painters tape across the front of both headlights, and the grill. Essentially covering the rubber seal under these spots. Then hit the highway. SILENT! I took the tape off at Home Depot, went in and bought 25' of 1/4" tubing for $3.00 and returned home. Installed into the weatherstripping on both headlights, and the grill. Sprayed a touch of wd40 into the weatherstrippping, which easily allowed the tubing to glide thru. Total time to do was 3-4 minutes. Cant even tell its there.
    Will try out the aluminum idea when/if the tubing fails.
    Thanks guys, this forum is invaluable!
  11. Apr 17, 2013 at 11:10 AM
    #151
    KingKoda
    Palmetto
    '12 TRD.S DCSB 4x4
    Yeah I taped off my grill with blue painters tape in spots and located my 40-50 mph noise to the grill weather stripping. I had tried the tubing but could not get it in. Just so happened I was in a hardware store a few days later and ran across the aluminum dowel. Rounded the ends and installed - it has been over 6 months now and I have all forgotten about it except for this thread popping up.
  12. Apr 26, 2013 at 4:46 AM
    #152
    pamtnman
    pamtnman Active Member
    PA...where else
    2013 Tacoma etc.
    The brand shiny new 2013 Tacoma 4x4 SR5 I drove off the lot last week made me so happy. Until I drive around over 42 mph. Then a whistle started up. It's loud enough to interfere with phone conversations and thoughts, and even my wife was complaining about it. Adjusting the mirrors did nothing. A quick Internet search turned up a number of hits, including here at Tacoma World. I told the dealership about it and they asked me to come in. It's shameful that the Toyota Tacoma of all vehicles has this persistent problem. My '02 TRD never had any issues, still runs great. What happened?
  13. Apr 26, 2013 at 4:51 AM
    #153
    NiceTaco
    NiceTaco Canadian Redneck
    Ontario, Canada
    2012 TRD Sport
    Aero Turbine 2525, Front bilstein 5100's @1.75, rear 5100's, 1" Toytec rear block, Devil Horns, BGF AT's, 18" Moto Metal 962's
    Toyota's quality is nonexistent... They are f$&ked... It's crazy to think truck coming off the line still have this issue... I hate Toyota...
  14. Apr 26, 2013 at 5:05 AM
    #154
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Sorry you had issues. :wave: Bye.
  15. Apr 26, 2013 at 6:00 AM
    #155
    pamtnman
    PA...where else
    2013 Tacoma etc.
    Hey Nice, it's the stupid little things that can undermine an otherwise perfect creation. Tacomas are renowned for their ruggedness, high performance, durability, etc. If I were using mine at only low speeds on timber, mining, land deal backwoods jobs, then all I'd know is that my new truck is awesome. It's that highway thing that brought this small but significant issue to my attention. What's surprising is that this issue has been established for several years. One year, OK, a design flaw, and they fix it. Two years, looks sloppy. Three years? OK. There's some Toyota engineer responsible for the front end who is falling down on the job, because this persistent problem shouldn't be an issue.
    Otherwise an awesome vehicle. I've already hauled several tons of dirt, cut stone, been offroading on a timber sale, etc and the truck otherwise functions as advertised and anticipated. My 2002 TRD SR5 is an incredible little truck. Goes on ATV trails no problem, never had an issue.
  16. Apr 26, 2013 at 6:35 AM
    #156
    NiceTaco
    Ontario, Canada
    2012 TRD Sport
    I dont hate my my truck but I do hate Toyota for putting shit out with the same problems... Would I buy another one? I'm thinking not...
  17. Apr 26, 2013 at 7:40 AM
    #157
    pamtnman
    PA...where else
    2013 Tacoma etc.
    On Monday I'll see what the dealership does to solve this. The salesman and I spoke this morning, and I told him about the results of my Internet search on this problem. I told him that it's not isolated, not unique to my truck, widely reported. And I suggested that the dealership prepare to address it Monday morning with the 1/4" tubing-in-the-seal solution described here on this site.
    The thing is, it's not a huge material defect. It's a tiny, stupid problem that a) shouldn't happen, and b) should be easily fixed long before a vehicle enters the marketplace. And that does speak to Toyota's culture.
    Is Toyota riding on their laurels, now producing defective trucks and pretending they're as good as or better than prior trucks?
  18. Apr 26, 2013 at 11:35 AM
    #158
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    I installed the tubing on my truck this morning. Mine is still whistling. I swear mine is coming from the satellite antenna, it sounds like it is coming from behind me somewhere.
  19. Apr 28, 2013 at 7:14 PM
    #159
    pamtnman
    PA...where else
    2013 Tacoma etc.
    Today I moved tape around to locate the source of the whistle.
    Not good. It's both sides of the windshield. Probably not the windshield itself, but the big gap between the windshield and the pillar. That's a design flaw. Tomorrow at the dealer is going to be unpleasant, unless they can find a fix that doesn't involve permanent tape over the side gaps. How sad. I was so excited to get my new Tacoma. This is a big disappointment.
  20. Apr 28, 2013 at 11:51 PM
    #160
    Commanderwiggin
    Commanderwiggin Well-Known Member
    Calgary
    12 Tacoma D/C 4x4 TRD Sport 6MT Supercharged
    New windshield fixed all my whistling...going on nearly 7 months of no whistle :D
