2012 Won't Accelerate
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zul, Sep 3, 2015.
  1. May 9, 2018 at 5:30 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yup, OP has a 2012, was gonna say the air injection system. pretty common with the 2012's unfortunatly due to lack of shutdown purge that the 2013+'s have.
  2. May 9, 2018 at 8:49 PM
    nd4spdbh
    SoCal
    shutdown purge.
    When you turn the truck off, the air injection system turns on, opens the valves and blows fresh air through the system to purge the valves of any moisture buildup that accumulated while the truck was running.
    TireFire likes this.
  3. May 10, 2018 at 12:34 AM
    PNW/TRD Steve
    PNW/TRD Steve Well-Known Member
    WA
    2012 DCSB TRD
    ImMrYo Rear view mirror lift bracket. Changed out mud flaps. Salex glove box organizer. OEM Ashtray (cup). AVS Step Shields. 16x8 SCS F5 Matte Jet Black. 265/75 16 Cooper St Maxx. OME Bp-51s. U.S. Offroad Winch Mount (in process) Smittybuilt x20 12k synthetic winch (in process) More....
    Maybe February? My valves had already been replaced under my extended warranty.
  4. May 10, 2018 at 12:35 AM
    PNW/TRD Steve
    WA
    2012 DCSB TRD
    There is a thread on here that talks about that and a kit that is available. Seems for some it works great and others had issues.
    Markschexnayder likes this.
  5. May 10, 2018 at 12:37 AM
    PNW/TRD Steve
    WA
    2012 DCSB TRD
    My understanding is there is a change in the valve system on the 2013 that made it more reliable than the 2012. I also understand that the replacement is the later valve system.
  6. May 10, 2018 at 5:04 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I would ask for my $50 bucks back OP. Its a known issue and other members haven't paid a dime to have it fixed.
    Hunter.415 likes this.
  7. May 10, 2018 at 7:35 AM
    nd4spdbh
    SoCal
    on the 2012 v6's there is no shutdown air purge, 2013 they added in the coding to do so on the v6's
    FYI 2012 was the first year the V6 got the air injection pump. i4's have had them since the beginning.
  8. May 10, 2018 at 3:51 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Different ECU?
  9. May 10, 2018 at 5:57 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The pcm software is written (coded) to simply turn the pump on for a second and clear out any moisture before shutoff. Mine does it every time i shut the truck down
  10. May 10, 2018 at 6:24 PM
    Hunter.415
    Hunter.415 Well-Known Member
    Pete
    Western mass
    2012 Tacoma short bed 4x4
    Cooper t/a 3
    2x , plus a loaner car which corporate covers as well. I had a loaner for 2 days
  11. May 10, 2018 at 6:24 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    In 2012 the pump was on there for the first time and they hadn't thought about the purge cycle during shutoff.. yet.. it took a few :rolleyes: failures to get them thinking about how to protect the pump.
    Nothing gets the phones ringing in the engineering department like a few thousand pump/valve failures! Lol! IIRC it was basically just the 2012s that fail. By the next model year they had figured it out
  12. May 10, 2018 at 11:42 PM
    TireFire
    Olympic Peninsula
    Pretty sure they would introduce the fix as soon as possible so if yours is a later model 2012 it might not be affected?
  13. May 11, 2018 at 6:37 AM
    nd4spdbh
    SoCal
    Different ECU coding, when you turn the truck off, it runs the pump for x amount.
    DoorDing likes this.
  14. May 11, 2018 at 1:09 PM
    nd4spdbh
    SoCal
    2012 trucks dont do the shutdown purge at all, the air pump only runs for the first 15 seconds or so right when the motor is started cold and ambient temps are above a certain temp (40*F i think).
    2013+ v6 trucks do the same plus a 5-10 second run of the pump right as you shut it down. I suppose you could make a switch to open the air injection valves and turn on the pump to simulate the shutdown purge on a 2012 truck.
  15. May 11, 2018 at 4:42 PM
    #35
    zul
    zul [OP] Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails, RokBlokz mud flaps WANT: Rear Plate Bumper, Steel bed cage
    Thanks but check the date of this post - this happened to me almost three years ago. Before it was a well known issue and covered by Toyota at 100%. My truck is an early 2012 (I drove it home in December 2011) so this problem happened to hit me earlier than most.
  16. May 11, 2018 at 9:14 PM
    #36
    nd4spdbh
    SoCal
    could of been a late mid year change.
  17. May 11, 2018 at 9:48 PM
    #37
    TireFire
    Olympic Peninsula
    Fixed
  18. May 24, 2018 at 11:22 AM
    #38
    Cbeck5000
    Cbeck5000 New Member
    Christian
    2012 Toyota Tacom
    Before my trac off light and my check engine light came on my air injection pump was making a loud noise only on a cold start for 30 seconds. I went to get the codes checked yesterday and they said it’s my air injection pump then today I go to merge on the interstate and my truck didn’t accelerate as fast as it should’ve. Just wondering if y’all think I need a new pump or what. PLEASE PLEASE PLEASE HELP!!!!!
  19. May 24, 2018 at 11:47 AM
    #39
    Hunter.415
    Pete
    Western mass
    Cooper t/a 3
    what codes? Both the valves and pump is covered by corporate if you have the codes needed. If lack of power your in limp mode now. My dealer replaced valves and pump, also given a loaner car for two day.
  20. May 24, 2018 at 11:54 AM
    #40
    Cbeck5000
    Christian
    2012 Toyota Tacom
    P2441 is the code. Secondary air injection system switching valve stuck closed bank 1 is what it says it is. I have 73k miles so I’m not sure if it’s under warranty
