2013 4x4 SR5 Build
Discussion in '2nd Gen. Builds (2005-2015)' started by fuscotj, Jul 30, 2014.
  1. Oct 23, 2014 at 7:48 PM
    fuscotj
    fuscotj [OP] Well-Known Member
    Travis
    Atlanta Area, GA
    SR5 4X4
    X Metal grill, LED DRL's, LED Light bars
  2. Dec 18, 2014 at 12:27 PM
    fuscotj
    Travis
    Atlanta Area, GA
    SR5 4X4
    Installed the rear differential breather mod. Bought the union and breather from the Toyota dealer. Went with 6 feet of fuel hose purchased at Pep Boys, but probably used around 4 and a half. I used one of the original drain holes in the bottom of the bed storage compartment and just drilled it larger rather than drilling a new hole.
    [/IMG]
  3. Dec 18, 2014 at 1:31 PM
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    09 dcsb Super white 4x4 sr5.
    Bilstein 5100 at 2.5 inch OME dakars with the big overload removed 265/75/16 on stock wheels 290,000 miles and counting
    Take the diff drop off. I'm not running one and no vibes. It doesn't do much anyway. The rear block is going to eat your springs to death in short time. Mine were toast in only a month or so. Get a set of OME dakars for2.5-3 inch lift in rear. They ride awesome for me. Get the constant load ONLY if you have a tool box or carry a couple hundred pounds all the time. Bout $500.
  4. Dec 18, 2014 at 2:49 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Your diff breather using the original valve is 100% pointless. The reason why you get the other breather is so that the diff can breathe in and out.
  5. Dec 18, 2014 at 3:57 PM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    All you have to do to turn the factory rear breather into a real breather is pop the top off of it and toss the rubber diaphragm out. It takes all of 30 seconds.
  6. Dec 18, 2014 at 7:08 PM
    fuscotj
    Travis
    Atlanta Area, GA
    SR5 4X4
    Good info. Guess you have to learn along the way... Thanks, going to change it out with the new one.
  7. Dec 18, 2014 at 7:35 PM
    C4 Fabrication
    C4 Fabrication Well-Known Member Vendor
    Caleb
    South Dakota
    07 DCLB Sport
    2" lift, 285/70/17 BFG TA KO2's, baja bumper, bedrack with swing out, CVT RTT, Leather interior, heated seats, JBL, remote start, K&N intake, Hood Scoop LED lightbar mod.
    truck looks great, lift and wheels/tires really make it. If you havnt already, I would suggest moving the lightbars off the grille, but that's just my personal opinion! They look out of place up there on the outside of the grille.
  8. Dec 18, 2014 at 8:37 PM
    fuscotj
    Travis
    Atlanta Area, GA
    SR5 4X4
    Yeah, I removed them a while ago. Definitely cleans up the look. I was just eager to do some mods to the ol' girl.
  9. Dec 19, 2014 at 6:24 AM
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    I think wheelers has them. I got them from my local offroad shop. That's cheaper so you don't have to pay shipping.
  10. Dec 19, 2014 at 6:36 AM
    cgs2k2
    cgs2k2 old man
    truck looks great. don't listen to some of the snobs around here wanting to tell you how to spend your money. nothing wrong with 1" blocks at all. 4" blocks and you may have problems with axle wrap.
  11. Dec 19, 2014 at 7:02 AM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    +1.
    Also, if you've already installed the diff drop, no point spending the effort to remove it. The only reason why people say not to install them is because ONE guy had a very bad experience a long time ago and told everyone that diff drops are the devil. Everyone seemed to jump on the band wagon and group think prevailed...
    Group think is very much alive and well on TW and as soon as you go outside the box, be prepared to hear about it.
    A flame suit is recommended! hahah
  12. Dec 19, 2014 at 10:55 AM
    fuscotj
    Travis
    Atlanta Area, GA
    SR5 4X4
    Definitely not going to remove the diff drop. I am thinking of getting the OME leafs though. The 4wheelParts here has them for the same price as online at Wheelers and without the shipping. I replaced the breather with the new one today.
  13. Dec 19, 2014 at 12:18 PM
    jaymac10
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    The way you had it with the original breather wasn't 100% pointless as someone else said. While it may not have been as optimal as a two-way breather, re-locating it away from water is the most important part.
  14. Dec 19, 2014 at 6:58 PM
    fuscotj
    Travis
    Atlanta Area, GA
    SR5 4X4
    Did a little fender and mud flap trimming today. I was still getting a bit of rub when the suspension compresses and the wheel is turned. Hope this does the trick.
  15. Dec 19, 2014 at 8:22 PM
    #35
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    I promise you will not regret the OME leaves.
  16. Dec 20, 2014 at 10:29 AM
    #36
    fuscotj
    Travis
    Atlanta Area, GA
    SR5 4X4
    That's what I hear. Hopefully pick up a set this week.
  17. Dec 23, 2014 at 9:15 AM
    #37
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    I remember seeing this truck at TRS's open house. Looks good!
  18. Dec 23, 2014 at 10:11 AM
    #38
    nd4spdbh
    SoCal
    FYI dakars are pretty damn stiff.... unless they changed, my buddy ran his even with one overload out he hated them.... went with the all pro standard pack and is much happier now.
  19. Jan 4, 2015 at 10:46 AM
    #39
    fuscotj
    Travis
    Atlanta Area, GA
    SR5 4X4
    Here's a how-to video I made on installing the Old Man EMU CS047R leaf packs on my 2013 DCSB. Finished it yesterday. Probably could have shaved a lot of time off of the install if I wasn't making a video.
    https://www.youtube.com/watch?v=31ORzqSCKHQ&list=UUS2yw_6NDSVz7V9KQf4e6XA
    Some good links I used as a guide:
    Torques: http://www.tacomaworld.com/forum/2nd-gen-tacomas/318116-torque-spec-guide.html
    Install instructions: http://www.sleeoffroad.com/installation/tacoma_05_ome_suspension_instructions_newlogo.pdf
  20. Apr 3, 2015 at 9:25 PM
    #40
    fuscotj
    Travis
    Atlanta Area, GA
    SR5 4X4
