2013 Access Cab- Need Ideas On Audio Upgrade
Discussion in 'Audio & Video' started by grubburg, Apr 20, 2014.
  1. Apr 20, 2014 at 10:04 PM
    grubburg
    grubburg [OP] Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    Love the taco, hate the sound system. With teh windows down on my freeway, i can hardly hear my beats!
    It has to appear stock in every way. I don't want a break-in.
    I'd rather keep the stock head unit.
    can i just buy an amp and replace the front speakers? I don't want to spend a whole lot.
    Any ideas are appreciated.
  2. Apr 20, 2014 at 10:29 PM
    grubburg
    2019 TRD OR MT
  3. Apr 21, 2014 at 7:46 AM
    grubburg
    2019 TRD OR MT
    if i want to get new front speakers, do i need an amp or can i run them off that powered sub/amp combo?
  4. Apr 28, 2014 at 6:51 PM
    919motoring
    919motoring Active Member
    Shaun
    Raleigh, NC
    13 DC Mag Gray TRD sport 4x4
    Those little flat amped enclosures are junk save your money. Use a audiocontrol lc2i to grab signal from your radio, 4 channel amp that can be bridged. Run the amp in 3 ch mode.
    A common setup I do when clients are on a budget is alpine MRV-f300, Rtype 6.5" components and a Rtype 8" sub. In the access cab you could do a little armrest type enclosure in the back. Add the volume knob to the lc2i to have sub level control
  5. May 1, 2014 at 9:03 AM
    Papa K
    Papa K Well-Known Member
    Aurora, CO
    2013 Access Cab 4x4 4 cyl
    You are at the same stage I am at. I went out and purchased upgraded 6x9 speakers and purchased the speaker adapter through Mr. Marv. Haven't installed yet though - want to do it right and put Rammat in the doors first, then install the speakers.
  6. May 8, 2014 at 10:14 PM
    BBQ
    BBQ Active Member
    I am searching all over the forums. All I want to do is upgrade the 2 door speakers..will i want one of those inline amps that fit in the dash work? do i need an amp? what size are the speakers? what is a good high quality mainstream speaker?
  7. May 8, 2014 at 10:40 PM
    camptaco01
    camptaco01 Well-Known Member
    Eric
    Tempe,AZ
    2004 TRD Double Cab 4x4
  8. May 11, 2014 at 8:38 PM
    LittleLady808
    LittleLady808 Well-Known Member
    Kauai,Hawaii
    2013 Prerunner SR5 2.7l
    I have that Sound Ordinance sub/amp installed in my double cab Tacoma. I too wanted to keep the stock HU and did just that. I have no regrets with the SO sub, it does it's job and adds that little extra thump I was looking for. I did change my door speakers to Kicker 6 3/4" front speakers and 5 1/4 " rear speakers adding an amp to only the fronts. Sounds a lot better now without spending a ton of money on a custom built sub box and all that other good stuff. Everyone has different opinions and it's all a matter of what you want/need and how much of a BOOM BOOM you're looking for and also how deep you want to dig into your pocket. :)
  9. Aug 13, 2018 at 3:47 PM
    Bluebird.
    Bluebird. Member
    Joe
    2017 TRDpro AC
    OEM audio plus, dual amp
    Id reccomend finding the Focal 6x9 components (they dont have to be the toyo specific line as Crutchfeild includes the speaker adaptors for your door) from Crutchfeild. I paid 240ish for these in my 16 4Runner and they are a very nice upgrade for the money. They are very effient (90 plus db) and sound fine with the factory head unit. Speakers must be very effient to work well, and all speakers in the rruck need to be replaced. I dont reccomend amps on a small budget, it will likley muck up one part of the sound spectrum.
    You should be happy just replacing the speakers. Crutchfeild makes it very easy and is worth the $.
    Good luck
