2013 Bluetooth touchscreen install in my 06
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ajw1986, Jan 26, 2014.
  1. Jul 6, 2014 at 2:42 PM
    #61
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Ok, so that's pretty much the same thing as the toyota plug, just much cheaper since it doesn't plug in without a little cutting?
    #61
  2. Jul 6, 2014 at 9:43 PM
    #62
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    The plug that goes to the back of the radio plugs right in. The other side has a male USB so you can run whatever you want to the dash. On the dash side I picked up the Toyota OEM USB/AUX port and didn't need to hack into the back side at all.
  3. Jul 6, 2014 at 9:47 PM
    #63
    SpeedoJosh
    Florida
    Sounds good. Thanks for the help.
  4. Aug 20, 2014 at 7:57 PM
    #64
    TRDh4vok
    TRDh4vok Well-Known Member
    Gil
    Palm Beach County
    '09 TRD PreRunner Sport
    -4" MaxTrac Spindle lift -5100 RCD Bilstein's -1/2" Strut Spacer driver's side (Taco Lean fix) -1/4" Strut Spacer passenger side (Taco Lean fix) -4" Tapered Blocks -Extended length U bolts -Front Skid Plate -Exhaust Tip -Tube Steps - Silver -Bed Extender -LEER Tonneau Cover -Rampage Roof Cab Lights -Rampage Tailgate Light Bar Six Function SUPERBRITE with Reverse Lights, Running Lights, Brake lights, Emergency Hazard and L & R turn signals -exLED Toyota Tacoma Custom interior LED Light Kit -PIAA Xtreme White Plus head lights and fog lights -NITTO Terra Grapplers 285-70-17 -30" Avec CR-Series Led Light Bar in bumper grill -Two 6.5" Led light bar's attached to the A pillars -Hood hinge bracket mounts from Famous Fabrications -Exhaust muffler Aero Turbine AT2525XL -OEM Roof Racks -OTTRAW Rocker switch -Stant locking gas cap -Large T emblem and mid mount bracket from Diaz Fabrications
  5. Sep 13, 2014 at 8:18 AM
    #65
    T09COMA
    T09COMA Member
    justin
    nc
    09 Trd Sport SR5
    what did everyone do about the clock, i have a 09 did anyone use the factory one in the truck the gray one or did anyone use the newer clocks that was for the radio and will the newer black clocks for touch screen plug right up to my factory harness
  6. Sep 13, 2014 at 3:39 PM
    #66
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    I got a 2012 black clock for cheap from a junk yard. Same size as the older gray ones and same plug in back.
  7. Sep 14, 2014 at 12:14 PM
    #67
    T09COMA
    T09COMA Member
    justin
    nc
    09 Trd Sport SR5
    oh ok thank you but i was going to go ahead and put the radio in till i can find a black one, will the old one fit in the touch screen just till i find a black one?
  8. Sep 14, 2014 at 12:28 PM
    #68
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    yes the whole case is the same only difference is internally some
  9. Jan 17, 2015 at 8:20 AM
    #69
    mtcarrio
    mtcarrio Active Member
    New Orleans
    2007 TRD Sport
    Skid plate, debadged
    Has anyone heard of problems installing a 2015 HU into a 2007 Tacoma?
  10. May 11, 2015 at 1:15 PM
    #70
    depechek
    depechek Well-Known Member
    Houston, TX
    07 Prerunner SR5 DC
    Just completed my 2015 Entune Plus swap in my 2007 SR5 non-JBL. Thanks
    ajw1986 for all the good info! Now to just get my aftermarket backup camera to work with the Entune HU.
  11. May 11, 2015 at 1:20 PM
    #71
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    subd. Gosh i want bluetooth. About how much did you spend on this mod?
  12. May 11, 2015 at 1:24 PM
    #72
    depechek
    Houston, TX
    07 Prerunner SR5 DC
    200 for the HU here on TW and 85bucks on the wires and bluetooth mic (Camel Toyota online). So about 285. Totally worth the upgrade especially if you want to keep it stock.
  13. May 11, 2015 at 1:27 PM
    #73
    Taco Dan
    Dan
    Tuscaloosa, AL
    Thanks! yes i like to stay semi-stock on the interior.
  14. May 11, 2015 at 1:32 PM
    #74
    depechek
    Houston, TX
    07 Prerunner SR5 DC
    except for the gray Hazard button, IMO it looks better than 2007 stock dash trim. May sure to get at least the Entune Plus HU so you can get HD weather, traffic, and radio. Feel free to PM or post here if you have any questions.
  15. May 19, 2015 at 8:25 AM
    #75
    Taco Dan
    Dan
    Tuscaloosa, AL
    anyone know if this basic 2012+ radio has bluetooth? i like the price
    http://www.ebay.com/itm/12-Toyota-T...lay-OEM-LKQ-/361291934247?hash=item541ead6a27
    or is it just the touchscreen models?
    nevermind i found this one that should work.
    http://www.ebay.com/itm/TOYOTA-TACO...OEM-/221774681096?hash=item33a2cd1408&vxp=mtr
    from this one^, here is the pic of the back. Im not interested in steering wheel controls, only interested in adding bluetooth and back up camera. will this do?(besides the harnesses/mic mentioned earlier in the thread i need to get?)[​IMG]
    #75
  16. May 19, 2015 at 10:28 AM
    #76
    depechek
    Houston, TX
    07 Prerunner SR5 DC
    Dan, first ebay listing won't work since it doesn't have bluetooth nor can it support a backup camera. The second ebay listing says it does have bluetooth. It is a base Entune HU- so no HD radio, HD weather, HD traffic, or Gracenotes. I believe you will still need all the harnesses and wiring the OP has listed in this thread to get the radio to work.
    I am still trying to figure out the back up camera part, I have an aftermarket camera.
    #76
  17. May 19, 2015 at 11:55 AM
    #77
    Taco Dan
    Dan
    Tuscaloosa, AL
    Thanks Man!
    #77
  18. May 25, 2015 at 8:39 AM
    #78
    markiemark9
    markiemark9 Member
    Omaha
    2008 Access Cab 4WD
    Can you please share the links to the parts needed to install?
  19. May 25, 2015 at 12:24 PM
    #79
    depechek
    Houston, TX
    07 Prerunner SR5 DC
    #79
    twitch813 likes this.
  20. May 25, 2015 at 12:46 PM
    #80
    depechek
    Houston, TX
    07 Prerunner SR5 DC
    I saw a 2013 Hu with Bluetooth n touchscreen just posted in the for sale forums for 175
