2013 Chrome exhaust tip?
Discussion in '4 Cylinder' started by LittleLady808, Oct 26, 2013.
  1. Oct 26, 2013 at 9:59 PM
    LittleLady808
    LittleLady808 [OP] Well-Known Member
    Kauai,Hawaii
    2013 Prerunner SR5 2.7l
    Hi guys! Any ideas? I wanted to look into getting a chrome exhaust tip to dress her up a little bit but for some reason can't find the right one. I'd like a regular one not one of the resonator tips cause i don't need the rugged noise. Lol :)
  2. Oct 26, 2013 at 10:10 PM
    LittleLady808
    Kauai,Hawaii
    Sorry for the double post I was trying to edit it and some how it posted twice. Please, can someone delete one of these? Thank you.
  3. Oct 26, 2013 at 10:55 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I cut my exhaust pipe just after the rear axle and put a simple straight chrome tip on it. So everything is all tucked up underneath and out of the way. :)
    I'm running the stock muffler and there's absolutely no difference in the sound with the cut pipe. The exhaust is also directed down and away from the spare tire so there are no heat issues.
    I have the 2.7, and the stock exhaust tubing is this weird 2 3/8 inch outside diameter. So I had to find a fitting that specifically stated that it would slip fit over 2 3/8 inch pipe. So carefully measure your pipe first before you buy any tip. :thumbsup:
    Greg
  4. Mar 4, 2015 at 8:23 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Yucky
  5. Mar 24, 2015 at 2:04 PM
    mistermanny
    mistermanny Well-Known Member
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    Nothing wrong with a nice exhaust tip :)
  6. Mar 24, 2015 at 4:40 PM
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    i'de hunt eBay for a TRD looking tip.
    Have it welded on, don't settle for a set screw that will come off on the roadway and your tip fall off and put a hole in someones tire.
  7. Mar 24, 2015 at 4:50 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I found one at Ollies Discount Store loose in an aisle. I took it up to the cashier and said I wanted the toothbrush holder but it was missing the bottom. They looked at it and said I could have it for $1.99. It's fully polished stainless steel. Score. :)
