2013 Fog Light anytime w/ fuse...step by step
Discussion in '2nd Gen. Tacomas (2005-2015)' started by V5ioV, May 26, 2013.
  1. Aug 3, 2013 at 4:14 PM
    SpruceJPG
    SpruceJPG Raging Dunkay
    .JPG
    Maryland
    2013 Spruce Mica DCLB SR5
    WeatherTech Floor Mats and some window tint
    Very nice write up! I have tried doing this on my 2013 SR5, but the open spots in the fuse box are not hot/wired. Just empty... like the feeling in my heart when I realized I still cant turn on just my fog lights.
  2. Aug 3, 2013 at 4:36 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    imagine what I felt when I just did the wiring and all that happened was my headlights would go on, even in the off position. fml.
  3. Aug 3, 2013 at 5:11 PM
    Tommiet
    Tommiet Well-Known Member
    Tom
    Charlotte Area
    PreRunner
    I like this mod, but wondering if the plastic housing will hold up to long term use. I did this to my Miata's fog lights and the plastic bulb holder melted after less than a year's use on both sides. Yes they were factory bulbs.
  4. Aug 3, 2013 at 6:59 PM
    V5ioV
    V5ioV [OP] My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    thanks,
    find a hot source… preferably one thats only hot when car is on! and follow the same concept!
    I dont know for sure! but I've had mine "on" for hours, *no issues yet!
  5. Aug 3, 2013 at 10:58 PM
    4508js
    4508js Well-Known Member
    Tennessee
    '13 TRD OR 4x4 DCSB, 4.0L V-6
    3" Rancho Suspension lift, Wet Okole seat covers, FJ TRD beadlock wheels
    If you use the fog light button to turn the lights off will they turn off ? Just curious, I want to do this mod myself. Thanks for the write up
  6. Aug 3, 2013 at 11:20 PM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
  7. Aug 12, 2013 at 4:49 PM
    4508js
    Tennessee
    Very nice write up with detailed pics, I just went out and did it to my '13 TRDOR and it was very easy. I really like the extra light when my high beams are on, thanks
  8. Aug 12, 2013 at 8:20 PM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Glad it help!
  9. Aug 14, 2013 at 11:48 AM
    Naholo808
    Naholo808 Well-Known Member
    Jordan
    9th Island (Las Vegas)
    2020 4Runner Off-Road
    2020 Toyota 4Runner Off-Road 3inch lift 33s Ko2s Matte black SCS SR8 2013 Tacoma TRD Sport 2wd - Traded In.
    Does this mod make your fogs go on in the middle of the night or just go on random times? I've been reading some posts saying that sometimes those things happen.
  10. Aug 14, 2013 at 2:41 PM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    nope! only when you manually turn them on…. but w this mod you can turn them on at any time…regardless of which light mode you got on or even while all your other lights are off…. also they will always come off when you shut the ignition!
  11. Aug 14, 2013 at 3:11 PM
    Naholo808
    Jordan
    Awesome.. I'll try it out soon! ;)
  12. Sep 27, 2013 at 5:04 PM
    LoneCynic
    LoneCynic Well-Known Member
    Ohio, USA
    NBM Tacoma 4x4 TRD Off Road & Towing
    SmittyBuilt Side Steps, DeeZee Bed Mat, TRD Shift Knob, Pop & Lock Tailgate lock, Stantz Locking Gas Cap, Marshall Instruments Oil Pressure & Oil Temperature Gauges
    Thanks for the write up, I will do this in the near future when time allows. Should be very helpful!
  13. Sep 27, 2013 at 8:24 PM
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Thanks for checking the write-up out! good luck!
  14. Oct 7, 2013 at 9:51 AM
    zk6760
    zk6760 Well-Known Member
    SLC, UT
    2010 Off Road
    Just got it!
    Question - is there any sort of 'switch' I can add to the wiring to shut the mod off?
    It wont pass inspection where I live and it would be nice to just "flip the mod off" without DC'ing anything to quickly get inspected and then turn it back on. Thoughts?
  15. Oct 7, 2013 at 12:57 PM
    #35
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Take out the blue relay circled in red, bend the tab on the top right (as if it were facing down like it is installed in the truck, just like in your picture) using an add a circuit, crimp a blade connector on to the end of the wire, slide it on the tab you bent from the relay. Remove the 10 amp fuse circled in red, place the add a circuit in its place, replacing the 10 amp fuse into the empty slot in the add a circuit, add a 5 amp fuse to the second slot to fuse your fog lights to avoid blowing your 10 amp ignition fuse if something goes wrong down the road.
    Here is a link to a mini add a circuit, you should be able to pick one up at your local auto parts store for a few bucks, make sure you get the mini blade fuse so it will fit in the ignition fuse's place. PM me if you have any more questions about how to do it.
    http://www.superbrightleds.com/more...gleBaseChild&gclid=CNLZ2L3BhboCFSVgMgod9m0ASg
    It should look like this when you're done.
    Also, just FYI, using this method, if you leave the switch in the cab turned on, approximately 4-5 hours after you turn the truck off, the fogs will come on for about 90 seconds, the ignition system powers up briefly to run some emission control systems in the truck. So don't panic if your fogs come on...it is normal and won't hurt anything.
  16. Oct 7, 2013 at 1:14 PM
    #36
    08TRDOFFROAD
    Dan
    I have had zero issues with the safety inspections on my truck with this mod for the past six years.
  17. Oct 7, 2013 at 3:24 PM
    #37
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Never knew there were places that check the fogs at the time of inspection!!!
  18. Oct 8, 2013 at 6:17 AM
    #38
    zk6760
    SLC, UT
    2010 Off Road
    Just got it!
    I've had them checked on a prior vehicle - just depends how thorough the inspection is.
  19. Oct 20, 2013 at 12:45 AM
    #39
    romiogt
    romiogt Member
    Canada
    2013 TRD Offroad
    TRD Cat-Back Exhaust, Bilstien 5100's @ 1.75, Weathertech Floormats Larsen NMO 2/70B
    Thanks for azchris for the orginal post, and Naholo808 for the write up, followed these instructions w/o issue and I am very happy with the result.
    Materials
    1x mini auto inline fuse holder 16ga - $1.50
    1x 15a mini auto fuse - $0.60
    1x male quick disconnects - $0.10
    1x female quick disconnect - $0.10
    Photos
    [​IMG][​IMG]
    On a 2013 there are no female connectors going to the empty SEAT HTR relay in the fuse box, so I spliced the male connector in with the male connector of the AC SKT (gray) relay as described; required just a little filing down to fit. Works exactly as per normal but I can turn on my fogs with my high-beams now!
  20. Oct 20, 2013 at 2:58 PM
    #40
    Naholo808
    Jordan
    Nice!!! Dont credit me. Credit 2006KJ!!
