2013 Fog Light anytime w/ fuse...step by step
Discussion in '2nd Gen. Tacomas (2005-2015)' started by V5ioV, May 26, 2013.
  1. Jan 11, 2014 at 7:13 PM
    #61
    V5ioV
    V5ioV [OP] My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    :thumbsup:
  2. Jan 17, 2014 at 8:48 PM
    #62
    Nicko
    Nicko beach bum
    Nicolas
    South Florida
    Not sure if i missed it but,
    What size fuse are you guys using
    For the jumper??
  3. Jan 17, 2014 at 10:46 PM
    #63
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    There is no need for a fuse what so ever.... See the fog light mod in my sig
  4. Jan 17, 2014 at 11:24 PM
    #64
    Nicko
    Nicko beach bum
    Nicolas
    South Florida
    Well thats good, thanks
  5. Jan 18, 2014 at 4:23 AM
    #65
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    your are right there isnt a need, but it DOES NOT cause any harn… and this method is also reversible...
  6. Jan 18, 2014 at 7:17 AM
    #66
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
  7. Jan 18, 2014 at 8:07 AM
    #67
    nd4spdbh
    SoCal
    Bend that relay leg back to put it back in your stock location and its going to break.
    Yes there is no harm in the fuse but its also a waste of resources.
    I will say this mod was one I took inspiration from for my fog light mod so thanks op !! :)
  8. Jan 18, 2014 at 8:53 AM
    #68
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    That's cool.... I still just don't see the need to be bending it on and on....
  9. Jan 18, 2014 at 9:22 AM
    #69
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    I tried this mod while I retrofitted my headlights and my relay began to make a loud buzzing noise so I bent the relay blade back and its fine, didn't brake just have to be easy with it
  10. Jan 18, 2014 at 6:11 PM
    #70
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    Gents, In the OP's thread he demonstrates grinding the male clip end sides with a dremmel to get it to fit the female end in the fuze box slot. That's not a requirement. You can get the male connector clips at Radio Shack that are already narrow in width and pop right in.:cool:
  11. Jan 18, 2014 at 6:20 PM
    #71
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Pic for ya!:) Shrink tubing is already provided as well...
  12. Jan 18, 2014 at 6:54 PM
    #72
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Yes.... If you get smaller ones that fit you right, it's not required to grind it... The smaller ones that I found that day not only were more norrow which would have been great but they were also shorter and I wanted a little more contact. .. Therefore u used wider and longer ones and trimmed them to fit
  13. Jan 18, 2014 at 7:50 PM
    #73
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    Aloha V5! You are correct in that statement:) I didn't have a dremmel tool, so I took the pre-fab'd route on a wing and a prayer...haha It all came out good though and I appreciate your post and time in putting it together! I initially installed the in-line fuse wire as depicted and when I turned on the Taco to check the lights...nadda.. I pulled a Homer Simpson and didn't realize that there wasn't a fuze in the holder that I had purchased...lmao! Wondered why it didn't work at first.:) Anyways, another quick trip to the "Shack" fixed that. Works like a charm! Thanks Bro!:cool:
  14. Jan 18, 2014 at 7:54 PM
    #74
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    That awesome... glad it worked out for you....
  15. Jan 18, 2014 at 8:29 PM
    #75
    timmytoast
    timmytoast Card-Carrying Illuminati Member
    Prison City, CA
    2013 SR5 4x4
    Black Plastiderp Front Emblem and Grille Surround, Relocated Horns, Bed Mat w/ bolt mod, Precision Fit seat covers, Anytime Fog Light Mod, Console and Glove Box Organizers, DIY Washable Cabin Air Filter, Pop N Lock Tailgate Latch, K B Voodoo Bed Brackets
    You can also take diagonal cutters/side cutters/dikes and trim the male connectors to fit.
  16. Jan 21, 2014 at 4:35 AM
    #76
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    :thumbsup:
  17. Jan 28, 2014 at 10:48 AM
    #77
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Very nice write up. I will be doing this in the near future. The pics and detailed instructions will come in handy.....I don't like messing with electrical! But this definitely gives me the confidence to go ahead and do it. Thanks bro, I'll let you know how it turns out.
  18. Jan 28, 2014 at 10:51 AM
    #78
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    It's very easy.... good luck :thumbsup:
  19. Feb 13, 2014 at 10:01 AM
    #79
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Well as I stated a couple posts above.....I finally got the opportunity to finally get this done.....worked like a charm. It's awesome, great write up bro. I only have 1 question, through all the threads and different posts on this mod I remember reading somewhere that at some point your lights may come on for 90 seconds.....is that for older models...all models who do this mod???
    I have a 13.
    Thanks man,
    Juan
  20. Feb 13, 2014 at 10:41 AM
    #80
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    I'm glad it worked out for you. As far as the lights coming on like the way you describe it. I've never had that problem
