2013 Fog Light anytime w/ fuse...step by step
Discussion in '2nd Gen. Tacomas (2005-2015)' started by V5ioV, May 26, 2013.
  1. Jan 17, 2015 at 7:53 PM
    #121
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    I have a 2012 this may be the same on your truck. The empty fuse location on the top row has power on it only when the parking lights or headlights are on.
  2. Jan 17, 2015 at 11:41 PM
    #122
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    just pull from the HEAD relay,
    see link in my sig for fog light mod, im pretty sure i explained which one on the headlight relay you could use for this application.
  3. Jan 18, 2015 at 4:36 AM
    #123
    V5ioV
    V5ioV [OP] My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    Go ahead and drop the link... it won't be the 1st time you dropped the link here!
  4. Jan 18, 2015 at 4:53 AM
    #124
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
  5. Jan 18, 2015 at 4:58 AM
    #125
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    I'll check what could be done on the fuse panel that's under the hood closer to the fogs relay
  6. Jan 22, 2015 at 7:42 AM
    #126
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    So any clue if this version works on a 2015
  7. Jan 22, 2015 at 8:43 AM
    #127
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Can you post a pic of your fuse panel?
  8. Jan 22, 2015 at 8:49 AM
    #128
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Sure the big or small one in the engine compartment?
  9. Jan 22, 2015 at 9:39 AM
    #129
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    The small one in the engine bay.... if it's the same, you would most likely be good to go.
  10. Jan 22, 2015 at 9:51 AM
    #130
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Here you go
  11. Jan 22, 2015 at 10:40 AM
    #131
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Yep... seems to be the same as my '13
    Check the OP
  12. Jan 29, 2015 at 4:55 AM
    #132
    goodend
    goodend Well-Known Member
    dave
    sw missouri
    2013dbl cab
    what brand foglites u buy how much and what size wire?
  13. Jan 29, 2015 at 7:36 AM
    #133
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    I didn't buy any other than some HIDs.
    Bulb H11
  14. Nov 10, 2015 at 3:41 PM
    #134
    luchin
    luchin living the Canadian dream
    Vancouver Island
    15 6MT DCSB SR5
    OME 885 coils, Dakar leaf pack, Bilstein 5100 struts, SCS Matte Jet Black SR8 wheels, 265/75/16 Toyo Open Country AT II, Arrow cap, Truxedo Truxsport Tonneau cover, TRD Exhaust, colour matched grill.
    I don't have the relay for the dc-ac converter because I have an SR5. Can I still feed the male connector into that power source without the relay being there? I'm assuming I can.
  15. Dec 29, 2015 at 4:54 PM
    #135
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    Thanks V5ioV for this write up. It was easy to follow and works as described
    V5ioV[OP] likes this.
  16. Jan 26, 2016 at 8:14 AM
    #136
    Alfred
    Alfred Well-Known Member
    Alfred
    California
    14 TRD Sport 4X4 DCSB
    I need to do this
  17. Jan 26, 2016 at 8:46 AM
    #137
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    It's an awesome cheap/free mod
  18. Jan 26, 2016 at 8:49 AM
    #138
    Alfred
    Alfred
    California
    I'm off tonight so I might do it this evening or tomorrow morning. I have my bumper led lights wired to my factory fog light switch and circuit so it sucks I can't turn them on whenever I want.
  19. Jan 26, 2016 at 8:50 AM
    #139
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Oh yeah.. you got to set them free...
    I should rename this threat to #SetYourFogsFree
  20. Jan 26, 2016 at 10:38 AM
    #140
    Alfred
    Alfred
    California
    Haha that's a good title :thumbsup:
