2013 Home made Raptor (sort of) Grill
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SeattleTac, Nov 4, 2012.
  1. Nov 4, 2012 at 4:39 PM
    SeattleTac
    SeattleTac [OP] Member
    Seattle
    2013 2.7 4x4
    I thought I would share some pics of a grill that I made up for my 2013 Tacoma and the steps taken - it took about a day, I am not patient, and dont have too many tools so this has to be a fast job otherwise I would get bored.
    1. Buy a 2013 Tacoma
    2. Buy a piece of aluminium perforated sotted sheet
    3. Buy some rubber trim, some LEDs, and zip ties.
    4. Take off the grill and chop out the middle with a saw, leaving some of the plastic attachments in place as those are going to be anchors for zip ties once they have been drilled with a hole in them, these will hold the new grill
    5. Use a piece of card to create a template before cutting the aluminum to fit
    6. With the card template lay it over the metal and cut it to size, then mess around with it trimming etc so it fits as well as possible, make sure the bend is clean using a straight edge.
    7. Cut holes in the metal for the LEDs
    8. Put the grill surround back on the truck and then cable tie the new trimmed and painted grill to it.
    9. Include a pic of my seat covers that are really nice :)
    This was a quick and effective job. Its on there temporary as I want to paint the chrome piece in body color and make the lower grill in the same way, just didnt have body color paint yet. I also need to wire the LED's to the DRL light position but did not get to it (or know how yet) as I ran out of time.
  2. Nov 4, 2012 at 5:34 PM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    interesting
  3. Nov 4, 2012 at 5:41 PM
    Fightman80
    Fightman80 Well-Known Member
    Capreol Ontario Canada
    05 TRD DCLB Speedway Blue
    Tinted Tail lights, Nerb Bars, Tonneau Cover, Vent Visors, Hood Deflector, Foglight/highbeam mod, Custom homemade grill, Carbon Fibre Interior.
    NICE! Sub'd for updates on paint and such... :)
  4. Nov 10, 2012 at 5:05 PM
    SeattleTac
    Seattle
    2013 2.7 4x4
    Quick update - wired up the LEDs and installed some Halo Projector fogs, still gotta make my lower grill and maybe get creative with a light strip in it or maybe not as it might get a bit too christmas tree like.
  5. Nov 10, 2012 at 5:09 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Very nice. Well done!
  6. Nov 10, 2012 at 5:12 PM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '12 DCSB 4x4 SR5
    So you didn't even cut it out perfectly or used bondo...hmmm :)
  7. Nov 10, 2012 at 5:13 PM
    JRFugitt
    JRFugitt Well-Known Member
    Justin
    Texas
    '13 PreRunner V6
    Where can you buy different types of mesh? I've been wanting to do this to my '13.
  8. Nov 10, 2012 at 5:13 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar/Ontario, CA
    08 TRD 2wd converted to 4wd
    Estock
    nice :thumbsup: thats exactly how i wired up RADs grill lights...look almost identical
  9. Nov 10, 2012 at 5:15 PM
    ravenmad
    ravenmad Member
    Florida
    2015 DC 4x4 Taco
    5100's Soon... Pockets full of cobwebs atm.
    Kewl! I would also like to know where you got the grill inserts.
  10. Nov 10, 2012 at 5:52 PM
    SeattleTac
    Seattle
    2013 2.7 4x4
    Thanks for the comments
    So the cutting out of the plastic middle grill was very easy and I just used a hand saw. A key thing was to use a piece of masking tape to use as a straight line up the plastic, and leave pieces of plastic from the original center piece at the edges rather than cutting it out completely - the reason being that it then covers up parts of the lights that you would otherwise see through the grill. I never even split out teh chrome surround - that will get body colored when I get some paint.
    No bondo or glue or anything - that would be beyond my skill and patience level and I wanted it to sit flush anyway without being recessed in any way.
    A key thing was the rubber trim - you need that too get the right finish.
    I bought the Aluminium perforated from a sheet metals supplier - $50 for a piece of 4x2. Dont get it too thin or it will buckle and dont get carbon steel or it will rust. The formal name for this stuff is slotted perforated aluminum sheet.
    I cut mine with a hand saw - its a pain with basic tools.
    Halo projectors are a Camry fit - $60.00 ebay. Not the best but good enough and different - takes a bit of modding to get them to fit, but they work nicely.
  11. Nov 21, 2012 at 9:55 PM
    Natediggity33
    Natediggity33 New Member
    Nathan
    Oregon/Washington
    How did u attach it??
  12. Feb 17, 2013 at 5:30 PM
    mfdchief
    mfdchief Well-Known Member
    Louis
    Rhode Island
    Where did you get the LEDs?
  13. Feb 18, 2013 at 7:19 AM
    SeattleTac
    Seattle
    2013 2.7 4x4
    So the LED's came from ebay - they are holding up fine and the truck is used everyday with them switched on. They are called Maxima's - they are 3/4 size, white glass and glow amber. They came from an ebayer called randcarriages and I think that ebayer is still there selling them.
    I fixed everything on using zip ties which you cannot see as they are black.
  14. Feb 18, 2013 at 8:49 AM
    Swordknives
    Swordknives mmm Tacos
    South OC CA
    2013 Dbl cab LB v6 SR5
    What kind of rubber trim did you use?
  15. Feb 20, 2013 at 5:34 PM
    SeattleTac
    Seattle
    2013 2.7 4x4
    it came from customecargrills.com they do stuff which is just right for the job
  16. Feb 20, 2013 at 5:35 PM
    SeattleTac
    Seattle
    2013 2.7 4x4
    sorry, drop the "e", it is customcargrills.com
  17. Aug 22, 2013 at 7:50 AM
    tacotoy2013
    tacotoy2013 Member
    TacoToy
    Seattle
    SilverStreak TacoToy
    3" Suspension, New wheels/Tires, Bull Bar & Running Boards, Window Tint, Fog Lamps...
    Looks great! How much to make one for me? I have an '13 as well. Hate the factory grill. Great job, keep it up!
  18. Aug 22, 2013 at 9:29 PM
    xxxotiknightz
    xxxotiknightz taco newb
    Titus
    NORCAL
    2013 SR5 DCLB
    looks nice. I may have to knock these off
  19. Aug 22, 2013 at 10:50 PM
    BXTACOMA
    BXTACOMA Well-Known Member
    Joe
    Virginia Beach
    05 Tacoma PreRunner SR5
    K&N Cold Air Intake, Borla CatBack Exhaust, JBA Ceramic Silver Coated Long Tube Headers. Pioneer Avic Z1 In dash Navigation HDD Radio, Boston Acoustic Speakers+Subs and Amp.
    looks great
