2013 LED DRL and turn signal light question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by geodude91788, Jun 15, 2020.
  1. Jun 15, 2020 at 11:56 PM
    geodude91788
    geodude91788 [OP] New Member
    George
    Edmonton, Alberta, Canada
    2013 Tacoma SR5 V6
    Hey guys have a quick question here. So i bought a SYLVANNIA 3157/4157 amber LED to replace my halogen ones. So of course at first it hyperflashed, then I learned about the resistor, after installing resistors it worked fine now. BUT i do realize one thing, after changing to LED, my DRL now turns off when my headlight is on (not like with halogen, that DRL only dims when headlight is on). Is there like a way that my LED DRL would stay on with the headlights on?
    Thank you in advance!
  2. Jun 16, 2020 at 2:19 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Did get 3157 SRCK bulbs?
  3. Jun 16, 2020 at 2:30 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
  4. Jun 16, 2020 at 9:12 AM
    geodude91788
    George
    2013 Tacoma SR5 V6
    i will look into this! thanks a lot!
  5. Jun 16, 2020 at 9:13 AM
    geodude91788
    George
    2013 Tacoma SR5 V6
    Sterling_vH111 likes this.
  6. Jun 16, 2020 at 9:19 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Same with my 2012
