2013 MT shifting problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ddavis8, Oct 7, 2019.
  1. Oct 21, 2019 at 9:42 AM
    #41
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    What are you at right now? I was planning on going 400k!
  2. Oct 21, 2019 at 9:45 AM
    #42
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod
    128,000. I would buy the new Tacoma first, and swap all the compatible parts from my old one on to the new one before selling it. Then drive the 2015 to whatever mileage, then hopefully by then Ill have a decent job and upgrade to a supercharged 4runner and have a fun little project car to keep my manual driving habits in check, maybe a st185 or st205 celica gt4
  3. Oct 21, 2019 at 10:00 AM
    #43
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    I agree with the folks here mentioning that an ECU tune to reduce rev hang and deleting the clutch accumulator/shuttle valve improve the shifting of the 6-speed.
    In addition, I noticed when I switched to a one piece drive shaft and a heavier leaf pack in the rear that shifting also felt better.
    With all the above my 2011 with 80k on it finally feels like it shifts better than my 2003 4-cyl did, which is ridiculous that it took that much modification - but it is a blast to drive now. My only real beef with it at this point is the absurdly short 6th gear - drives me nuts to suck so much extra gas at freeway speeds.
    In general I don't think these transmissions suffer from widespread synchro issues, so if you're going to keep it and put in a new trans maybe look into getting an FJ Cruiser 6-speed - I am not sure if the output shaft has the same # of splines as the Taco tranny, but if it does it would get you slightly better gear ratios.
    I think a low mile trans off of Car-part.com would be where I would look if I were in your shoes.
    ddavis8[OP] and JustDSM like this.
  4. Oct 21, 2019 at 2:53 PM
    #44
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Highway mileage is about 3 mpg less and you can tow a camper at highway speeds in 6th but not with the automatic with out it constantly shifting. I have done nothing to mine but drive it no delete this or that or a reflash. Yes the release bearing makes a little noise in neutral idling and it has since new but only when cold and frankly I don't have a tendency to flip out over some thing will be replaced when I do the clutch at maybe 200+K
  5. Oct 22, 2019 at 7:44 PM
    #45
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    it was 21 bucks at the dealer, cheaper than Amazon but not rock auto.
  6. Oct 23, 2019 at 10:53 AM
    #46
    ddavis8
    ddavis8 [OP] Member
    Dan
    2013 Dubcab MT 4x4
    Bumper, steps, lights
    What's involved with the tuning stuff? Foreign language you are speaking lol. Big money at a shop?
  7. Oct 23, 2019 at 11:56 AM
    #47
    smelly621
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    The best option for the 4.0 is through HPTuners equipment and software package - which is actually great because they are one of the bigger players in the US.
    You don't have to be a tech wizard to pull it off - but it can be a lot of info to digest at the beginning. I would read up in this thread:
    https://www.tacomaworld.com/threads/hp-tuners-for-2005-2015.600793/
    The thread is long, but the summary is:
    -If you have a buddy or can find a speed shop with the HPTuners cable that will help you out you'll need to "buy" 4 "universal credits" from HPTuners to allow you to tune your vin-specific ECU for $200.
    -If you have to or want to buy the cable for yourself that's another $300
    -At this point, you are able to start making changes to a number of parameters of the engine and transmission control system (including getting rid of the rev hang!)
    -Easy thing to do is send your stock file to @JustDSM, he will make changes based on your set-up, and send you back a tuned file to flash to the truck (for a very nominal fee in my opinion).
    -You can take some logs using the HPTuners software and a laptop to see how things look and he can make further adjustments if needed.
