HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Mar 24, 2019 at 2:26 PM
    Hacktacular
    Hacktacular [OP] Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    So HP Tuners made this happen recently and is a fantastic option for the 05-15!
    This will allow you to tune your own vehicle if that is what you are after.
    TOYOTA
    YearModel TypeSingle Vehicle Universal CreditsUnlimited Year/Model Universal Credits
    05-15 Tacoma 4.0L V6 (1GR-FE) (Including transmission) (2) 4 N/A
    07-18 Land Cruiser 200 & 70 – 4.5L V8 D-4D (1VD-FTV) (Including transmission) (2) 4 N/A
    07-19 Land Cruiser 5.7L V8 (3UR-FE) (Including transmission) (2) 6 N/A
    07-18 Tundra 5.7L V8 (3UR-FE, 3UR-FBE) (Including transmission) (2) 6 N/A
    07-18 Sequoia 5.7L V8 (3UR-FE, 3UR-FBE) (Including transmission) (2) 6 N/A
    Kolter45, Slashaar, sanchez and 14 others like this.
  2. Mar 24, 2019 at 3:36 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  3. Mar 24, 2019 at 3:42 PM
    Halligan
    Halligan Old School
    Cam
    BC Canada
    2015 DCSB Gearjammer
    OME 887s, OME Dakar Heavys, 265/70/17's, Truetrac, 6sp manual
    Looking at your truck build you clearly know a thing or two about tuning these trucks! Will the HP software allow a user to eliminate the bloody rev hang that plagues the later (2013-15) 4.0L trucks? I loathe the rev hang with a manual, it makes me want to explode.
  4. Mar 24, 2019 at 4:01 PM
    Hacktacular
    Robert
    @Halligan, I assume it will but cannot confirm as I haven't done one myself. Hp Tuners has been adding more vehicles to their supported list and I was excited to see the 2nd Gen Tacoma added.
    For the record I run Haltech but this has peaked my curiosity for sure. I may just give this a try.
    NOTE: The one thing I do not like about the product is that it is email support only. There is no number to call to troubleshoot or get support. So if you run in to an issue it could take a while to get it resolved.
    This is where Haltech kills it. Their customer service is the best in the industry in my experience so far.
    TXpro4X4, Jcyr, scottalot and 6 others like this.
  5. Mar 24, 2019 at 5:05 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  6. Mar 24, 2019 at 5:55 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's on now. HP Tuners is the ultimate in tuning functionality and simplicity for all GM vehicles.
    Time to have some fun with Toyota at last!
    @Torspd is this available for purchase?
  7. Mar 24, 2019 at 6:01 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    No idea. Hacktacular showed it to me first. All it takes is contacting them to find out.
    Hacktacular[OP] and 12TRDTacoma like this.
  8. Mar 24, 2019 at 6:34 PM
    Hacktacular
    Robert
    It is available. It is still in BETA but available on the website.
  9. Mar 24, 2019 at 8:26 PM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    I emailed them to see if they have a sample tune file. I downloaded the beta VCM editor but it doesn't have one for a tacoma, I am really curious to see what it can do.
    Hacktacular[OP] and loginfailed like this.
  10. Mar 24, 2019 at 8:33 PM
    Gerard6778
    Gerard6778 Well-Known Member
    Gerard
    2015 TRD Sport
    Following
  11. Mar 24, 2019 at 9:01 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
  12. Mar 25, 2019 at 4:29 AM
    Hacktacular
    Robert
    If it's the same as it has been for GM all these years, it pretty versatile.
    Jcyr and 12TRDTacoma like this.
  13. Mar 25, 2019 at 6:12 PM
    Hacktacular
    Robert
    A little Q and A with HP Tuners today.
    1. Can I tune for the larger injectors? Yes you can compensate for larger injectors in the calibration.
    2. Can I use the GM flex fuel sensor and provide the input to the mpvi2? The factory system does not use a flex fuel sensor and the MPVI2 does not currently have a frequency input that would be able to log a GM flex fuel sensor.
    3. When using flex fuel can is there any room in the ECU for auto scaling for E85? If the vehicle has a flex fuel calibration there will be flex fuel parameters available for variation in ethanol content.
    4. What type of mapping is being done? Is it speed density/VE? The OEM fueling strategy is MAF based, you should not lose any functionality as our software only makes changes to the oem calibration.
    5. Do you lose any factory functionality such as VSC or have any issues with DTC's causing CEL's? You should not lose any functionality as our software only makes changes to the oem calibration.
    6. I would like to check out the software but it tell me there is no device connected when I try. Is there a way to see what is available for my vehicle in the software? If you do not have an MPVI2 you will not be able to open any files.
    TRDSport10, JFick, Biscuits and 3 others like this.
  14. Mar 25, 2019 at 6:18 PM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    The software comes with some samples you can open and check out, but not a Toyota one.
  15. Mar 25, 2019 at 6:22 PM
    Hacktacular
    Robert
    To their credit, they did provide me screenshots but I didn't want to share them without permission.
  16. Mar 25, 2019 at 6:31 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Did the contents of the screen shots provided indicate that the solution they offer is a worthy investment for tuning the 1GR?
  17. Mar 25, 2019 at 6:37 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Sub'd because it's HP Tuners
    Biscuits and Gingerbeard Man like this.
  18. Mar 25, 2019 at 6:38 PM
    Hacktacular
    Robert
    Yes, you can use larger injectors change timing and fueling parameters. The downside is no E85 solution.
  19. Mar 25, 2019 at 6:40 PM
    Hacktacular
    Robert
    Here are the screenshots....
  20. Mar 25, 2019 at 6:57 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Is no E85 support more of a limitation of the 1GR ECU than a missing software feature? No E85 is a shame, but for me isn't a dealbreaker.
    This means I could ditch the UCON, but still keep my 640cc injectors. Very tempting. They list transmission control as well. I wonder what sort of things can be done. I have the complete built transmission from IPT and it shifts great, but the logic in the ECU could use some work.
