2013 reverse camera to non-jbl dash display
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jaymay82, Dec 31, 2012.
  1. Jan 5, 2013 at 11:53 AM
    jaymay82
    jaymay82 [OP] Well-Known Member
    '13 MGM TRD Sport DCSB
    Isn't your thread about the 2012 unit? I'm looking for the video feed harness for the 2013 unit.
  2. Jan 5, 2013 at 1:13 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Ya originally, not anymore...in one of the last 2-3 PGs is the parts number for the plug needed
  3. Jan 9, 2013 at 2:40 AM
    illmatyk
    illmatyk Well-Known Member
    Yigo,Guam
    2013 DCSB
    Any update on this?
  4. Jan 9, 2013 at 3:33 AM
    JRFugitt
    JRFugitt Well-Known Member
    Justin
    Texas
    '13 PreRunner V6
    Glad I found this post, we started discusing this in another thread but it never went anywere!
  5. Jan 9, 2013 at 5:06 AM
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
  6. Jan 13, 2013 at 3:34 PM
    DinaxMaxxum
    DinaxMaxxum Active Member
    TRD Sport
  7. Jan 13, 2013 at 3:44 PM
    MIAtaco
    MIAtaco Well-Known Member
    Brian
    Miami FL
    2010 tacoma base lifted
    2.75" front lift 2.5" rear, pro comp es3000 rear shocks w/ orange shock boots, custom exhaust, k&n cold air intake, 20" led light bar behind grill, aftermarket grill, T-rex3 eyelids, pioneer HD radio
    Anybody notice ithe video the guy calls it a tundra not a tacoma ?
  8. Jan 13, 2013 at 7:42 PM
    DinaxMaxxum
    TRD Sport
    Yes Is a Camry radio. but I said more of 3 times Camry and Tacoma 2012 up using the same Panasonic radio...only change the trim
    Raul
  9. Jan 13, 2013 at 8:11 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    ^^^i know...there's another thread where that is posted and has been stated...I'm still trying to work the kinks for the back up cam and /a/v
  10. Jan 13, 2013 at 8:16 PM
    Domreis
    Domreis Well-Known Member
    Pullman
    On another note, does anyone know how to bypass the moving lockout? I've looked before, but couldn't find anything.
    Thanks
  11. Jan 13, 2013 at 8:16 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
  12. Jan 21, 2013 at 7:57 PM
    DinaxMaxxum
    TRD Sport
    http://s1299.beta.photobucket.com/u...ibrary/?&_suid=135882528568600372138564448366
    Bonjour
    Here you will find some pics from this project..I have already the information
    needed to conect the back up camera to the NON JBL HU radio..(Camry, Tacoma 2012 up)
    Mine is a Tacoma 2013..well you need to buy a conector housing (toyota part #90980-12553) and 5 pins (toyota part # 82998-12870)
    if you camera need 12 volts to work you will need a 5 - 6 volts reed relay
    (before start with the relay, try connecting your camera to the radio)
    pin 7 is 6 volts positive voltage output to feed the camera
    pin 15 is negative output to feed the camera
    pin 8 is positive video siganal input
    pin 16 is negative video siganal input
    pin 2 in the large connector is 12 volts reverse signal input..this voltage came from the reverse light wire.
    when you start the vehicle, radio send voltage to the camera and check if they are video signal..this set up the radio as a monitor when the reverse voltage will arrive to the pin # 2 in the large connector..
    Good luck
    Raul
    justchil likes this.
  13. Jan 21, 2013 at 10:25 PM
    jaymay82
    Looking good
  14. Jan 22, 2013 at 1:44 AM
    illmatyk
    Yigo,Guam
    2013 DCSB
    My truck didn't come with a reverse camera, can I Just buy the camera and plug/pins and do this mod for it to work?
  15. Jan 22, 2013 at 2:07 AM
    #35
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Almost positive you can
  16. Jan 22, 2013 at 2:55 AM
    #36
    illmatyk
    Yigo,Guam
    2013 DCSB
    Thanks! Also, saw your thread with the work you do and thats some awesome work!
  17. Jan 22, 2013 at 7:15 AM
    #37
    DinaxMaxxum
    TRD Sport
    Hello
    The answer is yes...
    Try with a Toyota or Lexus ( mine is a Lexus)
    OEM camera
  18. Jan 22, 2013 at 11:13 AM
    #38
    Agro
    Agro Well-Known Member
    San Diego
    2015 Ford F-150 XLT 3.5L Ecoboost!
    I have a 2013 with the non Entune head-unit but has the rear-view camera in the mirror. I would love to make this mod work!
    Anyone out there willing to give this a try and give a detailed how-to?
  19. Jan 22, 2013 at 12:32 PM
    #39
    ProForce
    Anthony
    Alaska
    Thanks!
  20. Jan 22, 2013 at 3:34 PM
    #40
    DinaxMaxxum
    TRD Sport
    Hello Agro
    I need to do the same. After I order the right
    Connector I will tell you what to do..
    Raul
