2013 Tacoma 2.7L Help
Discussion in 'Performance and Tuning' started by Taco9595, Jun 1, 2015.
  1. Jul 18, 2015 at 11:35 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Wat?
  2. Jul 18, 2015 at 11:57 AM
    eivad1
    eivad1 Active Member
    dave
    canyon lake ca
    2007 toyota tacoma 2wd
    stock
    well yrs ago we could get into the computer but all of a sudden in the trucks we cant decode them
  3. Jul 18, 2015 at 12:27 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    It wasn't all of a sudden. Toyota simply stopped supplying the code, which would allow companies to overwrite Toyota's programming, to avoid warranty issues. Several other manufacturers have done this as well.
    As engines gain more sensors and more complex programming the amount of risk increases with tuning. Notice how in the 2000's several manufacturers openly supplied 3rd party companies with support for tuning their Diesels? That disappeared after trucks started blowing motors left and right.
    BTW there are ways around it. UCON from URD is a piggyback ECU that can work with the stock ECU to allow for tuning. Unichip is available as well.
  4. Aug 31, 2015 at 9:01 PM
    pasotaco
    pasotaco Well-Known Member
    Central Coast, CA
    2013 4x4 Access Cab
    LCE headers, King 2.5 Coilovers w/ res, TC UCA's, King resi's in rear, Geared to 4.88, rear locker, Timbren Bump stops, All Pro Leafs, Carrier bearing drop kit, ARB onboard air,
    Do you know anybody that has swapped out motors? 2.7 for the 4.0 or are you referring to swapping out the entire truck?
  5. Mar 17, 2016 at 5:58 PM
    mahaloTaco
    mahaloTaco TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
