2013 Tacoma AC not strong enough
Discussion in 'Technical Chat' started by tacomanewhampshire, Aug 26, 2016.
  1. Aug 26, 2016 at 7:11 AM
    tacomanewhampshire
    tacomanewhampshire [OP] New Member
    Ever since I've had my 2013 Tacoma double cab, I can never seem to get it cool enough on days above 80ish, which this year has been even more than ever. My AC does blow cool air on all fan levels so I know it's not an issue with the fan speed switch. It is more an issue with the AC or fan not being strong enough to cool the entire cabin and keep it cool. The only time it is somewhat okay is if the fan is constantly on high. But as soon as I turn it down to the next fan speed, it gets too warm again. Anybody else have this issue and what can be done about it. My guess is that either the AC, fan or #vents is undersized for the full double cab and they just put the same equipment in all size cabs. The car only has 30,000 miles on it so it should not be an issue of the AC needing re-charging, especially since this is an issue I've noticed ever since I owned it. Thanks.
  2. Aug 26, 2016 at 7:17 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Do you notice this all the time, or just when stopped in traffic? The radiator fan is known to be marginal (doesn't move enough air) with the engine at idle.
  3. Aug 26, 2016 at 7:29 AM
    tacomanewhampshire
    KenLyns,
    I notice it driving also. Nice tailgate.
  4. Aug 26, 2016 at 7:33 AM
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    I've got a 2013 with about 65k and I haven't noticed anything wrong with mine. I usually have to turn the cool towards heat a little because of getting cold. I have tinted windows as well so that helps living in south Georgia.
  5. Aug 26, 2016 at 7:37 AM
    The109
    The109 Well-Known Member
    Fort Collins
    2013 TRD OR Access Cab
    I have the same problem at idle or low RPMs. If I crank up the RPMs it gets colder. '13 as well. I only notice if it's above 90 and humid.
  6. Aug 26, 2016 at 7:37 AM
    motorsport36
    motorsport36 Black Lights Matter
    Furnace, AZ
    98 SR5 AC 4x4
    I had a 2013 that I just sold and it was very cold(Arizona ain't no joke)
  7. Aug 27, 2016 at 7:44 AM
    KenLyns
    Belly of the Beast
    ^Arizona does have the "benefit" of dry heat.
    Get a vent thermometer like this one: http://www.harborfreight.com/1-inch-pocket-thermometer-46586.html
    Do a performance test like it's shown in this video. If performance is not up to par, suggest you take it to a good shop for diagnosis. Note: he's showing a 4Runner with automatic climate control. In the Taco, turn the temp knob to the coldest setting, which automatically enables recirc, so you will have to manually deselect recirc.
    https://www.youtube.com/watch?v=XU_A4wNuHXI
