2013 tacoma ac resistor issue
Discussion in 'Technical Chat' started by betboy25, Jul 19, 2019.
  1. Jul 19, 2019 at 5:15 AM
    betboy25
    betboy25 [OP] Member
    Lee
    2013 Tacoma TRD
    Added train horn
    Hello group,
    About 2-3 weeks ago my AC unit in my 2013 Tacoma stopped working except in the HIGH position. I did some research and found that I should replace the resistor and that should take care of the problem. I did that and it fixed it. Yesterday, the same problem occurred again. The AC stopped working except on HIGH speed. Anyone have some ideas about why this is happening? Thanks for any help
    Lee
  2. Jul 19, 2019 at 5:22 AM
    Clearwater Bill
    Clearwater Bill Sometimes when I close my eyes, I can't see.
    Billy
    Largo Florida
    '13 5 lug base AC w/convenience package
    @Jimmyh will have some suggestions for you.
    I have tagged him with this post.
  3. Jul 19, 2019 at 5:25 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Probably the connector itself is either not making a good connection, or is overheated/burnt.
  4. Jul 19, 2019 at 5:30 AM
    betboy25
    Lee
    2013 Tacoma TRD
    Added train horn
    Thanks for the reply. I am a green horn at this. Can I replace the connector myself or is that something a mechanic needs to do? I was able to change out the resistor myself(as much cussing trying to get at it in the small space on the dash board area).
  5. Jul 19, 2019 at 5:46 AM
    betboy25
    Lee
    2013 Tacoma TRD
    Added train horn
    Thank you.
  6. Jul 19, 2019 at 7:59 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You can change the connector with a stripper and a crimper.
    The terminals on the motor and resistor bridge fit loose and are prone to burning.
    Resistor and connector needed for the fan speed.
    Look at both connectors on the motor. I'd be willing to bet one or both of them are burned.
    If they have burn marks you need to replace the connector plugs.
    Part number 90980-10916 Connector
    Part Number 82998-12380 Wire and terminal
    Not sold as a kit, sold as each. So you will need one of the plugs and two of the terminal and wires.
    Connector:
    Terminals:
  7. Jul 19, 2019 at 8:40 PM
    betboy25
    Lee
    2013 Tacoma TRD
    Added train horn
    Thank you very much for the help. I will check it out tomorrow and let ya know what I find.
    Cheers!
    Clearwater Bill likes this.
  8. Jul 19, 2019 at 8:42 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  9. Jul 23, 2019 at 5:54 AM
    betboy25
    Lee
    2013 Tacoma TRD
    Added train horn
    That was the problem! I replaced the wiring and it works now. Thanks for your advice!
  10. Jul 23, 2019 at 6:54 AM
    Blue Truck
    Blue Truck Well-Known Member
    I just bent the pin a little in mine so it would make better contact still working after 2 weeks
  11. Jul 23, 2019 at 2:37 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    :thumbsup:
