2013 Tacoma, Best Option For 3" lift ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VdubVr6, Feb 28, 2013.
  1. Mar 15, 2013 at 12:02 AM
    VdubVr6
    VdubVr6 [OP] Well-Known Member
  2. Mar 15, 2013 at 7:47 PM
    VdubVr6
    anyone ??
  3. Mar 15, 2013 at 7:50 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    X2! For your price range.
    Brett
  4. Mar 15, 2013 at 8:10 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    4 leafs is the TSB it doesn't come stock.. if you have 4 leafs you don't need the AAL if you have 3 you do
  5. Mar 15, 2013 at 8:13 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    My 2013 has 4 leafs
  6. Mar 15, 2013 at 9:54 PM
    Frissen
    Frissen Well-Known Member
    i think i have 4 leaf in my 13 dbl cab trd sport ...
  7. Mar 16, 2013 at 6:51 AM
    VdubVr6
    ok pretty sure the rear is 4 leafs. so all I need to do is purchase 5100's and set to 1.75 and i'm good to go. sounds to easy!
  8. Mar 16, 2013 at 8:29 AM
    DirtEater
    DirtEater Well-Known Member
    Surprise, AZ
    Good to go if you like the East L.A. look where the front rides a little higher than the rear. This is what I've gathered from others comments. With 5100's set at 1.75, you need a 1" block or add a leafs in the rear.
  9. Mar 16, 2013 at 10:01 AM
    RoosterCogburn
    RoosterCogburn I have ten reputation points
    Vick Vinegar
    Ass Kick USA
    2013 DCSB 4x4
    I've got a 13 base 4x4 with three leafs :(
  10. Mar 16, 2013 at 11:04 PM
    VdubVr6
    so even with 4 leafs... need to add another leaf ??
  11. Mar 17, 2013 at 12:40 AM
    I5runner
    I5runner Well-Known Member
    Ratha
    Belle Chasse
    13 DCLB
    See build page
    [QUOTEa=PRIMETIME;6514887]Im at 2.5 with no uca's guess i got lucky[/QUOTE]
    Same here! I got an alignment after I did the lift and it came out good. Maybe it's a hit or miss?
