2013 tacoma rockford fosgate setup
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drtacoma23, Feb 27, 2013.
  1. Feb 27, 2013 at 1:14 AM
    drtacoma23
    drtacoma23 [OP] Member
    michigan
    2013 DCSB Sport
    so i found this on ebay just searching around. I'm really tempted to pull the trigger, but i guess what's holding me back is whether or not it will fit a 2013. I called the store and they cannot confirm if it will fit or not. Unfortanetely they don't take returns.
    I'm mean i don't think that they changed the back pannels of the tacoma beyond 12 so i can't imagine why it would not fit. ..
    help would be much appreciated both on the product (if it's a good deal or not) and if this will fit my 2013 tacoma.
    http://www.ebay.com/itm/ROCKFORD-FO...oofers_Enclosures&hash=item35c447223e&vxp=mtr
  2. Feb 27, 2013 at 4:25 PM
    drtacoma23
    michigan
    2013 DCSB Sport
    bump for a little help please
    really itching to pull the trigger
  3. Feb 27, 2013 at 4:31 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
  4. Feb 27, 2013 at 4:40 PM
    RPD STARS
    RPD STARS Turn up the good, turn down the suck!
    BC
    2010 Raptor
    Go Faster Retrozzz... Drop in Dry Flow, Blowfaster Delta 50, 315/70/17 BFG Stock Action
  5. Feb 27, 2013 at 11:53 PM
    drtacoma23
    michigan
    2013 DCSB Sport
    thanks for the replies
    i'm really tempted to pull the trigger. I really like RF punch series- friend had them.
    kicker is my second choice. I'm going to call toyota and try to find out if the specs are the same.
  6. Feb 27, 2013 at 11:54 PM
    drtacoma23
    michigan
    2013 DCSB Sport
  7. Mar 11, 2013 at 11:15 PM
    NavyGuyAN
    NavyGuyAN Well-Known Member
    Virginia Beach, VA
    2010 Silver Taco 4x4
    Wet Okole Seat covers, Weathertech Floor mats, Blistein 5100's all-around, BFG KO2’s Fumoto Drain valve
    So like does the box go all the way across the back? was curious if you can still do the box and keep the shorter back seat storage area behind the seat open.
  8. Mar 11, 2013 at 11:21 PM
    eric3187
    eric3187 Well-Known Member
    pretty sure those boxes go all the way across.
  9. Mar 11, 2013 at 11:53 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Yeah! If you look at the link that was posted. There is an opened space at the back and it looks like it's for the cross beam that is behind the storage space. You are more than likely going to have to remove the storage space behind the seats.
  10. Mar 12, 2013 at 4:05 AM
    CINDOGS 21
    CINDOGS 21 Member
    Cincinnati
    09 4x4 dc short
    truxedo lo pro window vents avs bug shield II pop lock nerf bars
    Im also curious with ur results. hows it sound, bump, and fit. Did you run it off factory head unit and did you add any door speakers. Ive been reading and comparing while saving to buy a nice setup.
  11. Mar 12, 2013 at 1:11 PM
    RPD STARS
    BC
    2010 Raptor
    Im off tom so ill get some pics for you. Yes the box takes up the entire rear compartment and i mean everything. It fits just barely lol. It sounds great in my opinion and ive had quite a few diff setups...
  12. Mar 13, 2013 at 3:24 PM
    RPD STARS
    BC
    2010 Raptor
    As promised, I cant answer the stock head unit question because i Have a JVC screen...
