2013 Tacoma Trac control, abs, brake lights on due to gas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thenerdal, Nov 1, 2024.
  1. Nov 1, 2024 at 6:53 AM
    Thenerdal
    Thenerdal [OP] Active Member
    Came on once while driving. Had a guy check with a smoke machine or whatever. It was bad gas cap.
    Ordered new gas cap, problem went away but it comes back sometimes only when gas is low.
    Probably not needed to do anything, just an annoyance but is there anything I can do to stop this?
  2. Nov 1, 2024 at 7:17 AM
    Clearwater Bill
    Billy
    Largo Florida
    Is the new gas cap from Toyota or a parts house?
    Scan tool show any codes when the light pops on?
  3. Nov 1, 2024 at 7:40 AM
    Thenerdal
    Idk about oem, I got this one
    Gas Cap, Fuel Tank Cap Assembly Replaces 77300-06040, 7730006040 Compatible with Toyota - 4Runner, Avalon, Camry, Corolla, Highlander, Matrix, RAV4, Tacoma, ES350, GS350, GS460 and More https://www.amazon.com/dp/B07QFMNBH3
    And idk about codes. The guy did say it was a gas related code. Unfortunately my connection doesn't get power to just go to autozone so I need to use a powered scanner. I should probably just buy one huh
  4. Nov 1, 2024 at 9:31 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That appears to be an aftermarket knock off.
    Get a genuine Toyota Gas Cap.
