2013 tacoma v6 manual transmission gear oil.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aflores2726, Apr 27, 2021.
  1. Apr 27, 2021 at 6:52 PM
    aflores2726
    aflores2726 [OP] Well-Known Member
    Quick questions guys are there 2 types of gear oil for the manual transmission? If so what is it I see there is synthetic is that it only synthetic reason is I'm trying to change my transmission oil ?
  2. Apr 27, 2021 at 7:00 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Any GLIV (GL4) 75w-90 gear oil is acceptable synthetic or not.
    I (and many others) personally prefer Redline MT90.
    Note:
    The vast majority of 75w-90 gear oils are for differentials and are GLV (GL5) the difference is GL5 has higher sulfur content that is destructive to the yellow metals (brass synchros) in the transmission that differentials do not have.
    The transfer case can use GL5.
    Marc70, Dm93 and TnShooter like this.
  3. Apr 27, 2021 at 8:09 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I put Redline synthetic gear oils in all my driveline and MT90 in my transmission when my truck had 15k on it, I'm at 67k now. Transmission seemed to shift better after especially when cold.
  4. Apr 28, 2021 at 1:34 PM
    Markcal
    Markcal Well-Known Member
    My owner's manual states GL4/GL5 should be used in the transfer case, I was considering using Redline MT90 instead of the GL5 I have used in the previous two gear oil changes. Do you think using Redline MT90 is worth the extra cost over the GL5 gear oil I have been using for the last 14 years?
  5. Apr 28, 2021 at 5:05 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I've had good luck with Lucas and Royal Purple. Make sure you use GL4.
    Marc70 and Key-Rei like this.
  6. Apr 29, 2021 at 1:06 AM
    Key-Rei
    Key
    Florida
    In the transfer case? Nah. Unnecessary. I would use normal GL5 in the transfer case as MT90 is some pretty specialized and expensive stuff ment specifically for manual transmissions. (Hence "MT" and 90 is the weight) The transfer case doesn't need super special lube like that and if anything the added pressure protection of the sulfur additives in GL5 will benefit the transfercase's planetary gear sets.
    I have put MT-90 in my transfer case before out of fear of cross contamination but after learning a little more about how they're independently sealed I'm no longer worried about it and think GL5 offers better gear protection.
    MT-90 isn't going to hurt though if you want to use it, plus the capacity is only like 1.2 quarts or something so not overtly expensive either.
    Markcal[QUOTED] and Marc70 like this.
  7. Apr 29, 2021 at 12:38 PM
    Markcal
    Hey, thanks Key, how do you know so much about the mechanical workings of our Tacoma and automotive vehicles in general?
  8. Apr 29, 2021 at 8:57 PM
    Key-Rei
    Key
    Florida
    I work for my companies engineering department, though I do not currently hold a BSE degree.
    I used to work for Toyota in their parts department so I have a little inside knowledge.
    My Uncle was a Toyota Master Tech for 30 something years and taught me a lot of what I know.
    Toyota's are just kind of my special interest and I have a bit of down time at work so I just research and absorb infor from TW because I'm always interested in making my truck better.
    I'm not always right but I try to give the best info I can to help others at all times.
    :thumbsup:
    Marc70, bagleboy and Markcal[QUOTED] like this.
  9. Apr 29, 2021 at 10:41 PM
    blur
    blur Well-Known Member
    I use the GL4 Redline MT90 in both my transmission and transfer case. I’ve since learned the transfer case can take a GL5 oil but the GL4 in both won’t hurt. The important thing is that you DONT use a GL5 oil in the manual trans.
    Markcal[QUOTED], Marc70 and Key-Rei like this.
