2013 Toyota Tacoma non-JBL to JBL radio replacement
Discussion in 'Audio & Video' started by Randrew1a, Sep 29, 2020.
  1. Sep 29, 2020 at 3:52 PM
    Randrew1a
    Randrew1a [OP] New Member
    Richard
    2013 Toyota Tacoma Access Cab
    Custom Rims and tires, upgraded radio system.
    Hello All,
    I purchased a 2013 Tacoma for my son. I bought it with an aftermarket stereo and sub woofer in it. I would like to replace the aftermarket radio with a factory radio and regain the steering wheel controls (better for a new driver). I suspect the original radio was a non-jbl radio based on the factory plugs. I got a great deal on a 2013 JBL radio and I would like to install it. I have been thru many of the posts and am attempting to create a wire harness to make it work. I have managed to get power to the unit, but no sound.
    Therefore I am looking for some advice, does anyone have any suggestions to make this work or is there different options.
    FYI, the aftermarket radio is a Pioneer AVH-2300NEX
    Thanks in advance
  2. Sep 29, 2020 at 4:31 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    That’s going to be a no-go unfortunately.
    the JBL system is VERY different than the non-JBL. It has an amp, sub, different speakers, and totally different wiring.
    the JBL radio doesn’t actually output any power to the speakers. It sends a digital audio signal to the JBL amp, and uses a data signal to control volume and EQ internally in the amp.
    Polo2010 likes this.
  3. Sep 29, 2020 at 9:20 PM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
    You need a steering wheel control interface/module, to retain steering wheel controls.
    Just do a google search for swc module 2013 tacoma
  4. Sep 30, 2020 at 3:53 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
  5. Sep 30, 2020 at 9:49 AM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    Install the Maestro, get your steering wheel controls back (and more), and just to be a troll, hook up the video disable correctly so he can’t watch DVDs while in motion.
    No need to replace the stereo.
    It’s also possible a steering wheel interface was installed with the stereo and it got connected to the wrong jack or wasn’t set up right to begin with and whomever was too lazy to pull the stereo out again to get it working.
    destin_meeks likes this.
  6. Sep 30, 2020 at 12:54 PM
    Randrew1a
    Richard
  7. Sep 30, 2020 at 2:15 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    It’s a mostly plug-and-play harness for the axxess module. If you’re comfortable splicing, then you don’t necessarily need the harness. But if you’re not relatively experienced in wiring, the harness is worth it
  8. Oct 2, 2020 at 10:57 AM
    Randrew1a
    Richard
    Thank you all. Anyone want to purchase a 2013 JBL radio?
  9. Nov 3, 2020 at 5:01 PM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    I was curious about putting a factory stereo back in my 2013 also, but I can't justify the cost of doing it. I have a Kenwood aftermarket unit that is tied into the steering wheel controls. My issue is the buttons on the steering wheel controls, particularly the volume ones, seem to stick a little and don't always work properly. I'm not sure if I can remove that button combo and clean the contacts or not. Any ideas?
