2014 4.0 do you need to use OEM power steering fluid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jp5385, Jul 21, 2022.
  1. Jul 21, 2022 at 12:00 PM
    Jp5385
    Jp5385 [OP] Well-Known Member
    2014 TRD Sport V6 4x4
    I was trying to do a power steering fluid flush on my 2014 Tacoma and I was trying to use OEM fluid but the dealerships only sells one size of the power steering fluid and it’s a 100 dollars. That’s more than what I want to spend. Would it matter if I use an aftermarket power steering fluid for my Tacoma that will be equivalent to the OEM stuff?
    lynyrd3 likes this.
  2. Jul 21, 2022 at 12:10 PM
    CTSpruceMica
    CTSpruceMica Is a Naan wrap a sandwich?
    Dennis
    2014 Spruce Mica
    Dexron 2 ATF
    wi_taco likes this.
  3. Jul 21, 2022 at 12:15 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    1 Quart of valvoline maxlife atf will do the trick.
    wi_taco, tacoman45, ZMan2k2 and 4 others like this.
  4. Jul 21, 2022 at 12:24 PM
    CTSpruceMica
    Dennis
    2014 Spruce Mica
    That's what I used in my '14
  5. Jul 21, 2022 at 12:29 PM
    Jp5385
    Thanks for the reply guys I shouldn’t of only gone to the stealership for this stuff. Just found out Amazon sells the OEM red fluid for 20 dollars.
    TRDSport10 likes this.
  6. Jul 21, 2022 at 1:41 PM
    nd4spdbh
    SoCal
    any autoparts store / walmart sells the maxlife atf for under 10 a quart....
  7. Jul 21, 2022 at 1:44 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Walmart sold MaxLife for ~18 a gallon. That was about 2 years ago. Don’t know about todays price or availability.
    knayrb likes this.
  8. Jul 21, 2022 at 1:44 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I use Valvoline Maxlife ATF. Changed it out every 50K miles for the fun of it. No whining of the pump and very quick response on the power assist. Currently at 174,000 miles.
  9. Jul 21, 2022 at 3:10 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    This.
    And another trick I read on this forum……every time you do a oil change, just use a turkey blaster or some kind of syringe and get the old fluid out of the Reservoir and fill it up. Keeps the fluid fresh
    wi_taco and TerryTac0 like this.
  10. Jul 21, 2022 at 3:19 PM
    batt700
    batt700 Well-Known Member
    2017 SR5 Premium 4Runner
    2 quarts of Valvoline Maxlife ATF will be needed to really flush it. Disconnect the upper hose and put a cap on the res. hole that the hose connected to. Then put the hose in a container and turn the steering wheel over with the vehicle off, this will cause all the old fluid to pump out of the upper hose that was disconnected into the container. Continue to refill the reservoir after every turn of the steering wheel to ensure air isn't sucked into the system. After about 1 1/2 qts you should be seeing nice new red fluid flowing out of the hose.
    It's $12 for 2 quarts from Amazon.
    https://www.amazon.com/dp/B000BOYCN...rid=2XCDBG6FB6G0T&sprefix=valvoline+maxlife+a
    Jp5385[OP], nd4spdbh and b_r_o like this.
  11. Jul 21, 2022 at 5:49 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I use the Dexron also. I just pull the lower hose from my reservoir from time to time and let it drain out then refill. After a couple of times, driving for a week or so between swaps, it looks pretty clean.
  12. Jul 21, 2022 at 6:09 PM
    IL14TacoGrey
    IL14TacoGrey Well-Known Member
    2014 Grey Tacoma SR5
  13. Jul 21, 2022 at 6:24 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I never use oem for a anything unless it's the tranny fluid. I just used dextrose mabe u Castrol for the power steering.
  14. Jul 21, 2022 at 8:50 PM
    TerryTac0
    TerryTac0 Well-Known Member
    A cheap hand soap pump works great!
    Gunshot-6A and pahaf[QUOTED] like this.
  15. Jul 22, 2022 at 8:16 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Silver Minivan
    JDSmith, TOMB and Jp5385[OP] like this.
  16. Jul 22, 2022 at 11:16 AM
    Jp5385
    The Valvoline maxlife is Dexron 4 but the manual says to only use Dexron 2 or 3? I was wondering why everyone is recommending that over the OEM fluid which is Dexron 3? Could someone explain please? I’m a beginner DIYer trying to learn from you fine folks. The price of 6 dollars does sound a lot better than 20 though.
    Also wouldn’t it be better to use OEM for fluids and parts? I remember using only the Toyota pink coolant was a big deal and people said to not use the universal coolants. Thought it would be the same for the power steering.
  17. Jul 22, 2022 at 4:17 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Just use Valvoline maxlife atf. It will give a much smoother steering.
    Plain Jane Taco likes this.
  18. Jul 22, 2022 at 4:19 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Amazon baby!
  19. Jul 22, 2022 at 4:27 PM
    Alealexi
    Houston, TX
    If you look at the back of the bottle it will say that it is compatible with Dexron 2&3
    As far as only using OEM fluids that is a personal thing to do. You can easily get away by just using good quality aftermarket fluids. It is in rare cases that you should only use OEM fluids since you won't really find and after market fluids for some. Like the Honda dual pump diff fluid or the Nissan e-psf which there is not aftermarket brand for so you are stuck with OEM. As far as your Tacoma you can use any Asian pink coolant or get the Aisin brand since I think they are the ones who make the fluid for Toyota as they also make their water pump and other parts.
    Jp5385[QUOTED][OP] likes this.
  20. Jul 22, 2022 at 5:05 PM
    Jp5385
    Thank you for the explanation!
