2014 4runner diesel
Discussion in '4Runners' started by Pinoiako916, Jun 7, 2013.
  1. Jun 7, 2013 at 9:11 PM
    Pinoiako916
    Pinoiako916 [OP] Well-Known Member
    Al
    Roseville,ca
    SR5 2.7 4x4
    Stock
    but is replacing the diesel fuel filter every 15k only if your diesel truck has no urea?
  2. Jun 7, 2013 at 9:24 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Not true.
    The fuel economy alone pays for far more than the difference in fuel cost.
    Throw in towing/hauling and the difference is even greater. My Duramax got the same mileage as my Tundra. Truck was twice the weight, 4x4, taller, bigger tires, and a 6.6l engine compared to a 4.7.
    Apples to apples, the Duramax would pull an easy 6-8mpg better than a gas version of the same truck. 6-8mpg more is "good" on a 20mpg Tacoma.. but when you're dealing with 6-8mpg more than a 10-12mpg gasser, it's WAY significant.
    A 2.7 Diesel Tacoma could easily pull 35-40mpg.
    The purchase cost is higher due in part to the lower production numbers, but also due to the fact that the engine is built heavier.
    A lot of talk about high maintenance costs is always thrown around, and it is simply not true. Diesel pickups carry twice the oil of gassers... but the change intervals are also longer, so it balances out. I would not expect a 2.7-4.0 Diesel from Hino (Toyota) to require more than the 6 quarts we already have.
    So the only added maintenance item is a fuel filter every 15k. Big deal. Fleetfilter sells them for $20. Don't pay the dealer $60.
    No spark plugs to change.
  3. Jun 7, 2013 at 9:25 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Urea is not run through the intake... no effect on the fuel filter.
    The asphaltines in the fuel have to be filtered out so they won't gum up and damage the injectors.
  4. Jun 7, 2013 at 9:26 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    For the urea you' will need a blowtorch and some straight piping and a tuner then it will be a diesel
  5. Jun 7, 2013 at 9:29 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I'd cut my filters open at 15k and they were only darkened about 1/4 to halfway up.
    Plenty of safety factor on 15k if you're buying quality fuel.
  6. Jun 8, 2013 at 6:26 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Diesel in warmer climates fare better than diesels in cold climates, I bought good diesel fuel when I had mine, the filter always plugged 3000 or more miles early. There is a lot of offset in the types of maintanence, diesel was still higher cost. This is based on full size diesel pickup like a duramax 6.6 2005, or an older ford vs a Tacoma or a v8. Fleet records at work verify the diesel 3/4 tons type and amount. Also Portland mandated biodiesel blend (B10) to be sold in town, I often fueled up out of town.
    I went from a 22mpg diesel that weighed some 7000lb, to this Tacoma at 3700lb that gets 25mpg before larger tires and gears. the diesel has advantages to be sure, they just need to get the market full them so the cost to buy one goes down, B10 as of a year ago or 2 has an industry standard to meet too, it's not as likely to plug filters.
  7. Jun 8, 2013 at 11:29 AM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    WOW,
    Again and again....Toyota HAS a Diesel..it is called Hino....;)
    No true market unless you "Jump in" like VW did way back when ( 30 cents a gallon)....The Rabbit and VW p/u were getting 45-50 mpg's back then and the only "true expense" was earlier models got "sold" on Mobil one Diesel oil...
    Being in NH we did NOT change out fuel filters anymore than gas filters..Shit fuel is shit fuel..SIMPLE....
    They still are sharing our Truck fuel islands by the handful BUT it is everyone...young lady in a busines suit grabbed her "glove" and proceeded to fuel her Jetta...I asked her mpg's and she :D...36-38 overall and that is due to her "right foot"...:cool:
    Why should Toyota commit to that "emmisions regiment" when WE are "Sold' that diesel is the "Dirty fuel".....LNG will be the next "Hurrah" in these United States....Your Government and BIG $$$$ make more off from it :p...
  8. Jun 8, 2013 at 11:49 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Diesel usually gels in the fuel lines and filters. A block heater wouldn't do anything for the fuel lines that go from the filters back to the tank, but a fuel additive or winter blend fuel would. Especially if you start using it BEFORE it gets brutally cold and prevent gelling from happening in the first place. The diesel exhaust fluid tank would be nowhere near the engine, that fluid is introduced into the catalyst in the exhaust system, not the engine oil:)
  9. Jun 17, 2013 at 7:45 PM
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    I love diesels!
  10. Jun 21, 2013 at 8:49 PM
    Dr. Gonzo
    Dr. Gonzo Member
    Grass Valley, CA
    06 4Runner Limited 4wd
    Bilstein 5100 set at .85", exhaust tip relocated with borla tip, weather tech mats throughout, map light mod, Morimoto HID 4300k, custom sat nav mount
    I want an oil burning Toyota!
  11. Jun 21, 2013 at 8:54 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    From what I've read on the subject the Toyota D4D Diesel motor that is available in the Hilux Pickup is a pretty bulletproof motor.
    There is a company in Texas that will swap it into your Tacoma for a 20K pricetag too. :eek:
    I suppose if you really had your heart set on Diesel you could try to import one. :rolleyes:
  12. Dec 29, 2013 at 10:25 PM
    mwa10taco
    mwa10taco Member
    Nor Cal
    2010 Dbl Cab TRD
    My Brother-in-law drives a max cab, long bed Dodge Diesel w/a 10' Lance Cab-over camper and gets 16mpg. My Taco dblcab 4x4 4.0 gets 20 empty and 11 towing a 4,000lb 18' travel trailer. I'm gutted about it, but the Taco is slightly easier to park than that Dodge.
  13. Dec 29, 2013 at 11:30 PM
    DJB1
    Dave
    SLC, UT
    MPG isn't the only cost to consider. A double-cab 4x4 diesel pickup costs twice as much your truck AND they are total shop queens to boot. Your brother-in-law will cry until he vomits when he has to pay for a new turbo or injectors. Plus his tires and fuel cost more. I have a few co-workers with diesel trucks that like to tease me about my "pussy" Tacoma. I just tell them I'm under-compensating for my giant cock.
  14. Jan 5, 2014 at 6:37 AM
    Russtoy
    Russtoy Well-Known Member
    Russel
    Ohio
    2000 4Runner SR5
    I've own my Chevy D-Max since 2006...and absolutely love my diesel!! Everyone is talking about how hard it is to take care of a diesel, but it's not. The fuel filter is the only really "extra" maintenance. It doesn't matter how cold it is. I live in Ohio...it's plenty cold here. You just need to make sure you get your fuel from a reputable station. If you go to a station that lets water get into their fuel...and/or doesn't sell much fuel so it sits in their tanks for months...that's when you have problems! That's when your fuel can gel or grow bacteria!
    Easiest thing to do when your out on the road is buy your fuel where you see semi's and dump truck fueling up. And when your home just ask around until you find a good station.
    Something else...several have stated diesel vehicles cost to much...it's true that you pay a premium for the Diesel engine...but you never lose that. When you go to sell your vehicle you will recoup that money. Diesel vehicles are always worth more than gas powered vehicles.
    And everyone acts like they'll never see a diesel in a 4Runner...please!! The United States is the only country you can't find a diesel in a Toyota!! When I was in Iraq...that's all I saw were diesel 4Runners and trucks. For years, guys have been buying the front half of diesel Toyota trucks from overseas and have them created up and brought to the US. Then they transplant the diesel into their worn out Toy! IMHO...the EPA and California...are the ones keeping diesels out of the US.
  15. Mar 25, 2014 at 4:42 PM
    #35
    RubiconBob
    RubiconBob New Member
    South Shore Mass
    '01 5-lugger
    There is a hefty Import tariff on diesels since the '80s. Cat, detroit, and cummins pushed for it hard once they saw how good the asian and German competition was. Back then Harley Davidson also forced import bikes to stay under 700cc.
  16. May 14, 2014 at 12:14 PM
    #36
    bmwco
    bmwco New Member
    Anther factor I don't see here, aside from MPG: Torque! The (only) available motor feels so weak, particularly when you're used to diesel. The 4Runner simply needs more power. Best and most efficient means: diesel.
  17. May 14, 2014 at 12:27 PM
    #37
    Large
    Large Red
    At least his thread isn't in the 2nd gen section, I'm out.
