2014 access cab door speakers
Discussion in 'Audio & Video' started by BBQ, May 10, 2014.
  1. May 10, 2014 at 5:24 PM
    BBQ
    BBQ [OP] Active Member
    Hey all the following is crutchfields recommendation when i asked for new door speakers and an inline type amp. Can one of you stereo geniuses confirm this will work in my entune access cab?
    Thanks for the email,and shopping with Crutchfield online. It sounds like you’re about to have a sweet upgrade to your factory system. I have the perfect amp and speaker combo that will take your system to a whole new level.
    The speakers are the Kenwood Excelon KFC-XP154C 7” component speaker set<http://www.crutchfield.com/p_113XP184C/Kenwood-Excelon-KFC-XP184C.html?tp=105>. These will take the place of the front door woofers and tweeters. They feature a 7” woofer for clean and controlled low frequencies and a 1” silk dome tweeter with neodymium magnet. When powered by the Alpine KTP-445U power pack<http://www.crutchfield.com/p_500KTP445U/Alpine-KTP-445U-Power-Pack.html?tp=35782#details-tab>, in bridged mode, you will get 90 watts per speaker. This is a perfect push for those Kenwoods and will be an audiophile grade sound.
  2. May 10, 2014 at 5:34 PM
    Riverdog
    Riverdog Well-Known Member
    Collin
    Portland, OR
    '05 Double Cab PreRunner
    7' inch woofers eh? I can't confirm it, but I feel like I read on here that someone put 7" woofers in their tacoma. Crutchfield IS an expert though. If I were you, I'd trust what they say would fit. If they're wrong, they have amazing customer service and will fix it as fast as they can.
    As far as the speakers and amp go, that should be a nice setup. Before you buy them, you might go to a car audio shop in your area and listen to some excelon speakers to make sure you like them.
  3. May 11, 2014 at 6:27 AM
    weendoggy
    weendoggy Well-Known Member
    Aptos, CA
    2014 TRD ACOR 4x4
    Access Original Tonneau Cover; Toyota Side Tube Steps; Focal ISS690 front speakers; Clarion XC1410 mini amp; Gentex 453 rearview mirror with Homelink, Compass, Temp and Autodim; Prodigy P2 trailer brake controller, Heated Seats from www.cobraheat.com, BriteAss Fogs, Phillips Extreme LED H/L. Heated mirrors from @Up2NoGood. 5100 Bilstein all four corners.
    I installed some Focal's in my AC. Post #4 here: http://www.tacomaworld.com/forum/audio-video/317073-2014-access-cab-sub-options.html I'm going to install this mini amp first to see if it'll serve my needs http://www.crutchfield.com/p_020XC1410/Clarion-XC1410.html I don't want to take away floor space (even under the seat) just yet.
    The speakers alone made a huge difference in sound quality. I just need a little more push. I'm not a "boom boom" enthusiast so the big sub box is definitely out for me.
  4. May 11, 2014 at 6:47 AM
    Skinny Rogers
    Skinny Rogers U know fish can hear u thinking just b4 u sneeze
    Lance
    NC
    10 taco
    ^^. X2 on the focals. I installed some about a month ago and it's a world of difference. My good friend owns a stereo shop and he just redid my radio and door speakers and I was extremely pleased. It's a lot of sound out of 2 6x9s.
  5. May 11, 2014 at 7:30 AM
    BBQ
    I'm with you, on the boom boom. SO you put these in without an amp and they made a big difference? My comfort level with working on this kind of stuff wold be to do one thing at a time. maybe i'll follow your path here.. thanks!!!!
    Bxmarauder likes this.
  6. May 11, 2014 at 11:23 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    The difference between the Alpine Power Pack and the Clarion amp units, is that the Clarion unit puts out 5 more watts per channel, but can't be bridged for 2 channel mode. The Alpine unit would serve you better with just the front doors speaker change.
  7. May 12, 2014 at 6:51 AM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    Have my Clarion on order. Will install in the next week or so (trip planned). I'll document what I do (with pics). Yes, the Focals made a big difference. You can't tell much by the YouTube video, but they sound much better. I'm sure some of it is the HushMat.
    Reason for installing the Clarion is to replace or move the overhead speakers to the back AC doors. Thus needing 4 channels.
  8. May 12, 2014 at 6:53 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Check your back doors, I have heard that on the 2014 Access Cab they moved the rear speakers up into the headliner with some crappy computer sized speakers.
  9. May 12, 2014 at 2:38 PM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    I know they're in the headliner, that's why I said I'm either going to replace them and/or add speakers to the rear doors.
  10. May 12, 2014 at 4:10 PM
    BBQ
    im just going to leave them alone myself, they don't add anything, and good powered speakers in that cab are more than good enough for me.
  11. May 25, 2014 at 10:25 AM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    Update:
    Going to place my Clarion XC1410 under my drivers seat. By doing so, I'll have easy access to make changes (if needed) in the future. I'll be wiring in (2) 9-wire cables under the center console to the dash area. One will connect via plug under my seat to the input side and the other will attach to the Clarion output plug end making it easier to remove, replace, repair the unit without having to take the radio out. I'll document pictures when my cable comes in. The reason for this is it is miserably difficult to put it in the radio area and have it secure. Because of it's size, it fits neatly up against the heal hump under the seat without losing any rear foot room (if an access cab has that). I'll run my separate bat + wire along the kick panel.
    I haven't quite figured out how the "rear" speakers (in the headliner) are connected. Once the amp is hooked up, there is no rear fade. Looking at a 2013 wiring diagram (mine is a 2014 and I don't have a diagram) the headliner speakers are wired to the fronts. Also, the diagram on another post showing Toyota colors are a little off. My 2014 main power and front speaker plug has a gray wire that is the ignition switch on #C (I'm using this to power activate the amp).
    I did a test run of the unit and I must say I'm impressed with the output. Running the stock head and the High setting (as suggested by Clarion for stock units) the sound is amazingly better and clear. However, using the Low setting is even better! I'm running Focal ISS690 speakers and there is no distortion from either setting. It'll blast you out of the cab for sure. The bass seems more prevalent at lower volume and also clearer, but, you have to pay attention to what you've recorded and how much bass the music has. Some of mine is a wee bit toooooo much bass and actually sounds crappy with the Low setting. On both tests the crossover switch was left at Flat. I didn't really see too much change from the 60hz and 90hz settings. I wish the Gain control could be remotely controlled to change if needed and that's one of my reasons for under the seat. Probably will not change settings once installed but knowing it's a 10sec job is o.k.
    Attachment is test setup to make sure it works.
  12. May 25, 2014 at 10:33 AM
    BBQ
    Hey have you ever uncovered those stupid roof speakers? any idea what size they are? they sound like iphone speakers when you fade to them lol
    Luke-Maine likes this.
  13. May 26, 2014 at 6:09 AM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    Not yet, but when I do the wiring, I'll pull the headliner and find out.
  14. Jun 9, 2014 at 10:50 AM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    Finally got my Clarion XC1410 installed in the truck. What a difference along with my previous speaker upgrade. I have it documented in the attached .pdf file if anyone's interested. I spent about 1.5 days doing the install along with mounting my trailer brake control in the E-brake space for standard transmissions (I have AT).
    I also found out that you need to wire the "5th" wire in the rear speaker plug to the radio/harness. If you don't, you don't get the fade feature. I utilized one of the unused male/female connector wires in each of the Metra plugs to make the connection in the rear plug. Now, I do have fade when all hooked up. They sound better so I'm leaving them alone for now.
    The radio sounds so much better at low volume now. I can have it around 20 and it sounds great. Yes, it'll blow you out of the cab for sure and all I wanted was clean sound. Also glad I didn't install a powered sub-woofer, there's plenty of bass in the sound.
    All the wiring is soldered and used heat shrink. Don't need any problems later on. I also installed plug-ins so I can replace the unit without hacking up the wiring again.
    Nice clean job and still have a lot of room under my seat. :)
    RugglesTarlek, Norton and Bxmarauder like this.
  15. Nov 19, 2014 at 8:30 PM
    nxrunner
    nxrunner Well-Known Member
    Nick
    Lafayette La.
    2015 Tacoma Double Cab 6 Speed
    Did the same up grade. I used BHO 1761 & BHA 1761 to connect my Alpine 445U without cutting the stock harness. Got everything back together only to realize I do not have any radio illumination, only the touch screen is lit. Which wires do I need to hook up? The orange from both its? please
  16. Mar 21, 2016 at 6:28 AM
    Bxmarauder
    Bxmarauder Member
    new york
    2014 Silver Sky Metalic Tacoma Dbl Cab TRD Off Road
    Tonneaupro hard trifold, Bed mat, Bed extender, Nerf bars, interior LEDs pop&lock (elec)
    Did U use a line converter or just amp and new speakers?
  17. Mar 21, 2016 at 7:35 AM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    Just the mini amp and new speakers. No problems to date. Good clean sound without hiss or other noise. Plays fine with BT and Ipod or USB.
    Norton and Bxmarauder[QUOTED] like this.
  18. Mar 21, 2016 at 12:40 PM
    Bxmarauder
    Bxmarauder Member
    new york
    How much work to tie the amp to speakers and HU
  19. Mar 22, 2016 at 8:04 AM
    weendoggy
    Aptos, CA
    2014 TRD ACOR 4x4
    Not sure if you're asking me, but I stayed with the stock HU and you should allow a couple of days to do an anal job. If you want to butcher it, it can be done in less time. I pulled out the center console and driver seat to have ample room to work. The rest of the time is spent routing wiring and making good connections.
  20. Mar 22, 2016 at 8:59 AM
    zinger
    zinger Well-Known Member
    2016 Silver Sky Tacoma SR5
    You'll need an amp that has speaker level inputs if you're going to connect the amp directly to the HU.
    Bxmarauder[QUOTED] likes this.
