2014 access cab door speakers
Discussion in 'Audio & Video' started by BBQ, May 10, 2014.
  1. Mar 22, 2016 at 9:34 AM
    Bxmarauder
    Bxmarauder Member
    new york
    2014 Silver Sky Metalic Tacoma Dbl Cab TRD Off Road
    Tonneaupro hard trifold, Bed mat, Bed extender, Nerf bars, interior LEDs pop&lock (elec)
    I'm anal as well , for that reason I hate to do technical things lol
  2. Mar 22, 2016 at 9:37 AM
    Bxmarauder
    Bxmarauder Member
    new york
    Going to use the same amp Weendoggy used!
  3. Mar 22, 2016 at 10:10 AM
    Bxmarauder
    Bxmarauder Member
    new york
    Great job! Excellent thread and pdf, now to get up the nerve!
  4. May 18, 2016 at 1:42 PM
    Goofball
    Goofball New Member
    One major issue with this install: The fuse on the power to an amplifier should always be as close to the battery as possible, not at the amp. The point isn't to protect the amp, it's to guard against the heavy gauge power wire having a short to ground and turning into one long heating element supplied by hundreds of amps at the battery. I've seen vehicles turned into burned down wrecks by improper amp power wire fusing.
    With the installation as shown in the PDF you have several feet of wire run through areas with potential for pinch points and friction rub/wear. All it takes is a little tiny spot worn through in the jacket on the positive power wire and suddenly things are smoking.
  5. May 19, 2016 at 8:34 AM
    weendoggy
    weendoggy Well-Known Member
    Aptos, CA
    2014 TRD ACOR 4x4
    Access Original Tonneau Cover; Toyota Side Tube Steps; Focal ISS690 front speakers; Clarion XC1410 mini amp; Gentex 453 rearview mirror with Homelink, Compass, Temp and Autodim; Prodigy P2 trailer brake controller, Heated Seats from www.cobraheat.com, BriteAss Fogs, Phillips Extreme LED H/L. Heated mirrors from @Up2NoGood. 5100 Bilstein all four corners.
    If you're sloppy in your install, anything can happen. The point is to protect the best you can. The wire isn't in a pinch point and is well protected, except for a side impact which would damage a lot more. I see a lot of "butt" connectors, quick splices, etc. used by people on many forums that are far worse for "electrical issues" than what I've done. But, that's just my opinion. As far as placing the fuse close to the battery, it does no good if the short happens on the battery side. :)
  6. Aug 25, 2017 at 4:23 AM
    dlawrence529
    dlawrence529 Well-Known Member
    Maine
    2015 MGM Double Cab Long Bed
    I'm looking to install an Alpine 445U in my 2015. Did you ever find a solution to this?
