2014 Backup camera
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Frobozz, Apr 22, 2014.
  1. Jun 12, 2014 at 5:43 AM
    #41
    LiquidDragon
    LiquidDragon Well-Known Member
    Michael
    Williamsburg, Va but now in the Philippines
    2021 Toyota Hilux Conquest 4x2
    none yet
    Can you post the link to the camera that you ordered or the whole part number so others can order it as well. Thanks
    #41
  2. Jun 12, 2014 at 8:03 AM
    #42
    andsun
    andsun Member
    Drew
    Los Angeles
    This was the part number: 86790-04020.
    You can also contact the seller 'midwestgreenparts1'
  3. Jun 12, 2014 at 1:09 PM
    #43
    ssanders2211
    ssanders2211 Well-Known Member
    Midwest
    '14 DCLB 4x4
    behind the rear seat hi-lift mount bracket, easy-out crossbed toolbox brackets, sliders, ATO plate rear bumper, hood/bed lighting, always-on 12v outlets, dashcam, Viper 5806V w/ GPS
  4. Jun 17, 2014 at 9:54 AM
    #44
    camerasource
    camerasource New Member
    Unfortunately they are not all prewired for camera, even though the harness is in the tailgate. I posted a summary here:
    http://www.tacomaworld.com/forum/2n...camera-install-base-2014-a-2.html#post8800144
    If you are considering a factory Toyota camera this is something to look at before spending the money because there will be no easy way to interface the camera to the radio if you are not pre-wired.
  5. Jun 17, 2014 at 1:24 PM
    #45
    14SR
    14SR Member
    Wells
    Chicago
    14 Access SR v6_4x4
    Bed Buddy, Avid light bar, ClassIII hitch, custom motorcycle tie-down bar in back, escort 9500ix radar
    Update on the Pop 'n Lock latch w/ integrated camera from Camera Source-
    My truck came pre-wired all the way to the latch and in hindsight installing just the camera would have been easiest (found here: http://www.ebay.com/itm/181439348432).
    Pulling-out the existing wire was a bit of a pain, but the Camera Source set-up does come with a few mounting brackets along the write to secure their wire along the inside of the tailgate.
    I was able to key my ignition key to the back without a problem and the camera functions as intended.
    I'm a bit disappointed with the feel of the latch when opening, as the construction doesn't feel as sturdy as the factory latch. We'll see if this proves to be a long-term durability and reliability issue. Will keep the factory latch just in-case.
    Net-net: if you're sure you're wired front-to-back, just go with the plug & play camera from midwestgreenparts1. It's a bit pricey considering you're not getting a locking latch, but it will be the quickest and will preserve your factory latch. If, on the other hand, you're worried about some crackheads stealing your lift-gate, the security of the Pop 'n Lock is worth the time and effort.
    #45
  6. Jun 17, 2014 at 5:51 PM
    #46
    Snookie
    Snookie Monkey Tamer
    Snookie
    Lizard Creek Louisiana
    14 Texas Edition 4X4
    I installed the Camera Source with Pop N Lock with back up camera with ease.
    Anything to discourage the rednecks and crackheads from sealing my tailgate is a PLUS IMHO
  7. Jun 23, 2014 at 4:24 PM
    #47
    MidwestGreen
    MidwestGreen Member
    Andsun-
    Thanks for the great write up. Its nice to see something go full circle.
  8. Oct 31, 2014 at 8:44 PM
    #48
    NotRed
    NotRed Well-Known Member
    Jimbow
    Tennessee
    My 2015 had all the positive signs - sticker back by the tailgate, warning notice on the display on startup, etc. Bought the one from midwestgreenparts1 on ebay. Got it in 2 days, took about 5-10 minutes start to finish to remove the tailgate cover and plug it in then put back together. Works like a charm! Good visibility in the dark too, but I don't have anything to compare that to for reference.
    #48
  9. Dec 20, 2014 at 12:01 PM
    #49
    DCtacotruck
    DCtacotruck New Member
    DC
    4x2 Tacoma PreRunner
    Body Armor TC-4121 Black Steel RockStep Side Rail, OEM Backup Camera, Gates 31780 Fuel Tank Cap
    #49
  10. Dec 22, 2014 at 12:56 PM
    #50
    MidwestGreen
    MidwestGreen Member
    Good to know that this is working out on the 2015's. I've got about a dozen or so of them left, and I doubt I'm getting any more in.
    Anyhow, we still haven't solved this for everyone. I get a return on about 1 out of 10 cameras that show all the "Right" signs that Dale put together. I can't figure it out. Anyhow, glad they are working in the 2015 models. Usually Toyota does long part runs.
  11. Feb 9, 2015 at 4:45 PM
    #51
    48crash
    48crash New Member
    Bob
    Stamford, CT
    2104 Regular Cab Debadged
    Unfortunately, my 2014 Tacoma is not prewired for the backup camera (only a single, blue wire goes from the tailgate to the cab). I have a regular cab and I notice that the three other owners posting to the forum that their Tacomas aren't prewired also have regular cabs. Likewise, I don't see anybody with an access or double cab saying they aren't prewired. I detect a pattern.
  12. Sep 30, 2015 at 8:46 AM
    #52
    shortG
    shortG Member
    2015 Tacoma Prerunner
    I bought an OEM fit camera from ebay for $130. The seller did me a solid by offering local pick-up and free installation. It works great.
    Seller: fabius_koch
    #52
  13. Apr 26, 2016 at 5:45 PM
    #53
    cbannister83
    cbannister83 I'm a d**che
    43S GT 59500 92000 ish
    DCSB
    Loading...
    I am getting a rear bumper with tire carrier and need a rear camera extension cable.... Anyone know where to get one? Interested in the aforementioned and possibly a bracket to weld on the tire carrier to hold the camera as well. Any input would be beneficial. Thanks guys.
  14. May 30, 2017 at 7:23 PM
    #54
    Dan Reisman
    Dan Reisman Member
    I'm having a bear of a time trying to get the Camera-Source camera to work in my 2014 Tacoma. I was not pre-wired. All wiring is getting the expected charge. When I put the truck in park, there is no change on screen. I just called Support today, and they had me use the wire without the special pin. No luck. Any ideas?
  15. May 31, 2017 at 8:42 AM
    #55
    LiquidDragon
    Michael
    none yet
    All 2014 Tacomas should have all the wiring for the camera already installed. I had the base model and it had all the wiring already there and the only thing I did was order a stock camera that goes in the tailgate handle and replaces the plastic filler piece. If you're installing an aftermarket camera then I have no idea
  16. May 31, 2017 at 8:46 AM
    #56
    LiquidDragon
    Michael
    none yet
    #56
  17. May 31, 2017 at 8:48 AM
    #57
    Dan Reisman
    Dan Reisman Member
    Thank you for your reply. However, that's not the case. It is well documented on TacomaWorld that some 2014 Tacomas are not pre-wired for the backup camera. I'm hoping to receive help from someone who purchased one of these trucks, and successfully installed this setup.
  18. May 31, 2017 at 8:50 AM
    #58
    LiquidDragon
    Michael
    none yet
    Did you take off the plastic cover on the inside of your tailgate to see if it has the wiring in there?
  19. May 31, 2017 at 8:53 AM
    #59
    LiquidDragon
    Michael
    none yet
    I had the base model 4x4 and it had all the factory wiring up to where the camera was mounted but mine had the plastic dummy piece in there instead of the camera. The only thing I did was put in a factory camera and it worked with no other modifications. If you don't have the harness that's in the tailgate then you can also order that online as well.
  20. May 31, 2017 at 8:53 AM
    #60
    Dan Reisman
    Dan Reisman Member
    Yes, the wiring exists in the tailgate. However, the wiring does not proceed forward into the cab, to be plugged into the radio. In the back of the radio, the plug is missing, and the radio does not recognize that the camera exists.
